Page 2 of 7
Re: Traffic with Google Maps in Domoticz
Posted: Monday 11 April 2016 18:56
by remb0
great work! I will create a summary for the wiki.
but which key must I choose?
I see only this:
Google Maps APIs:
Google Maps Android API
Google Maps SDK for iOS
Google Maps JavaScript API
Google Places API for Android
Google Places API for iOS
Google Maps Roads API
Google Static Maps API
Google Street View Image API
Google Maps Embed API
Google Places API Web Service
Google Maps Geocoding API
Google Maps Directions API
Google Maps Distance Matrix API
Google Maps Geolocation API
Google Maps Elevation API
Google Maps Time Zone API
Posted: Monday 11 April 2016 19:12
by Westcott
It's "The Google Maps Directions API" , with this link to get your own API key -
https://developers.google.com/maps/docu ... troduction
Posted: Monday 11 April 2016 19:14
by woody4165
Correct!
Posted: Tuesday 12 April 2016 21:12
by remb0
wishes for this great script.
1:
One script for 2 routes: home>work and work to home.
2: instead of a text sensor a custom sensor (so you see a nice graph in logs)
3:
both in a specific time frame an alert if duration is above x.
when one pushmesage send don't send another again (otherwise we will spammed some days)
Posted: Wednesday 13 April 2016 0:08
by G3rard
Hi Remb0,
I have updated the script of woody a bit so it also can be used for the route work to home.
Also I only get a message when the traveltime is longer than usual. The scripts checks every 30 minutes and only in a certain timeframe, so you won't get spammed.
I am updating the travel time in a pressure sensor in Domoticz so I can use the graph in the log (I am not yet on the beta with the custom sensors).
You still need to change some things to the script:
- idx
- usual travel time
- coordinates
- Google API key
- path of the JSON.lua as I am running Domoticz on a Synology NAS
--Script to calculate duration and distance between two points using Google Maps
--Author : woody4165 based on Neutrino Traffic with Waze, updated by G3rard
--Date : 9 April 2016
commandArray={}
time = os.date("*t")
day = tonumber(os.date("%w"))
--idx of devices for capturing the travel minutes in both direction
idxhomework='252'
idxworkhome='253'
--usual traveltime (mins)
usualtimehomework = 50
usualtimeworkhome = 50
--coordinates home
fromx="xx.xxxxxx"
fromy="y.yyyyyy"
--coordinates work
tox="xx.xxxxxx"
toy="y.yyyyyy"
--Google Api Key
key='key'
--determine workday (Mo-Fri)
if (day > 0 and day < 6) then
werkweek=true; weekend=false
werkweek=false; weekend=true
--determine time (7:00-9:00, 16:00-19:00)
if ((time.hour > 6 and time.hour < 9) or (time.hour == 9 and time.min < 1)) then
ochtend=true; middag=false
elseif ((time.hour > 15 and time.hour < 19) or (time.hour == 19 and time.min < 1)) then
ochtend=false; middag=true
ochtend=false; middag=false
--calculate traveltime
function traveltime(fromx,fromy,tox,toy)
--import JSON.lua library
json = (loadfile "/volume1/@appstore/domoticz/var/scripts/lua/functions/JSON.lua")()
-- get data from Google Maps and decode it in gmaps
local jsondata = assert(io.popen('curl "https://maps.googleapis.com/maps/api/directions/json?origin='..fromx..','..fromy..'&destination='..tox..','..toy..'&departure_time=now&key='..key..'"'))
local jsondevices = jsondata:read('*all')
jsondata:close()
local gmaps = json:decode(jsondevices)
-- Read from the data table, and extract duration and distance in text
distance = gmaps.routes[1].legs[1].distance.text
duration = gmaps.routes[1].legs[1].duration_in_traffic.text
-- mins is only the number part of duration (for evaulation purpose or to return a number in a number device)
for minutes in string.gmatch(duration, "%d+") do mins = tonumber(minutes) end
return mins
--weekday (Mo-Fri) and time between 7:00-9:00
if (werkweek and ochtend) then
--every 30 minutes
if((time.min % 30)==0) then
homework=traveltime(fromx,fromy,tox,toy)
message=tostring(homework)..' minuten naar kantoor | '..("%02d:%02d"):format(time.hour, time.min)
print(message)
--send message if traveltime is longer than usual
if(homework > usualtimehomework) then
commandArray['SendNotification']=message
--return a text to the device (eg. 12 mins)
commandArray[1]={['UpdateDevice'] =idxhomework..'|0|' .. tostring(homework)}
--weekday (Mo-Thu) and time between 16:00-19:00
if (werkweek and middag) then
--every 30 minutes
workhome=traveltime(tox,toy,fromx,fromy)
message=tostring(workhome)..' minuten naar huis | '..("%02d:%02d"):format(time.hour, time.min)
print(message)
if(workhome > usualtimeworkhome) then
commandArray[2]={['UpdateDevice'] =idxworkhome..'|0|' .. tostring(workhome)}
Posted: Wednesday 13 April 2016 9:15
by woody4165
Hi G3rard.
Well done!!!!
It's very clear and clean now...
One question regarding SendNotification.
It will send the notification using all the channels defined in Domoticz.
Is there a way to send it using only one of the channels?
Posted: Wednesday 13 April 2016 9:44
by xces
i have taken the liberty to refactor (rewrite) the script since it did not feel 'finished' in my eyes. I rewrote it out the top of my head, so it might contain errors but it is simplified a lot.
see here for syntax highlighting:
http://codepad.org/IosDVkqX
--Author : woody4165 based on Neutrino Traffic with Waze, updated by G3rard, refactored by xces
-- We don't have to run this script at all if:
-- 1) we are not at a half hour mark
-- 2) we are currently in the weekend (or)
if ( ((time.min % 30) > 0) or ((day == 0) or (day == 6))) then
return {}
-- Settings for this script
key = 'key' --Google Api Key
homeX = 'xx.xxxxxx' --coordinates home
homeY = 'y.yyyyyy'
workX = 'xx.xxxxxx' --coordinates work
workY = 'y.yyyyyy'
homeWorkIdx = '252' --idx of devices for capturing the travel minutes
homeWorkMins = 50 --usual traveltime (mins)
homeWorkMsg = "minutes traveltime to the office"
workHomeIdx = '253' --idx of devices for capturing the travel minutes
workHomeMins = 50 --usual traveltime (mins)
workHomeMsg = "minutes traveltime to home"
-- Start script
commandArray={}
-- Morning, traveling from home to work
sourceX = homeX
sourceY = homeY
targetX = workX
targetY = workY
deviceIdx = homeWorkIdx
usualMins = homeWorkMins
notificationMsg = homeWorkMsg
-- Afternoon, traveling from work to home
sourceX = workX
sourceY = workY
targetX = homeX
targetY = homeY
deviceIdx = workHomeIdx
usualMins = workHomeMins
notificationMsg = workHomeMsg
-- Script is running in a period where we don't have to do anything, so bail
-- calculates traveltime
function traveltime(fromx, fromy, tox, toy)
jsondata:close()
return mins
-- Since we already put the variables above, we can now simplyfy the code below
currentTravelTimeInMins = traveltime(sourceX, sourceY, targetX, targetY)
message = tostring(currentTravelTimeInMins) .. ' ' .. notificationMsg .. ' | ' .. ("%02d:%02d"):format(time.hour, time.min)
print(message)
-- send message if traveltime is longer than usual
if (currentTravelTimeInMins > usualMins) then
commandArray['SendNotification'] = message
-- return a text to the device (eg. 12 mins)
commandArray[1] = { ['UpdateDevice'] = deviceIdx .. '|0|' .. tostring(currentTravelTimeInMins) }
Posted: Wednesday 13 April 2016 12:17
by woody4165
Nice job xces!
I just had to move before declaration of variables the
because I was getting this error
Error: EventSystem: Lua script Traffic did not return a commandArray
Posted: Wednesday 13 April 2016 12:58
by remb0
nice to see that the community is working together.
other things I will try:
- get the home adres lattitude and longitude from settings.
- better printing in logs
- use custom sensor for a nice graph (so also run outside the period for the logs/statstics)
- can we change hours in more specific time? 6:50 till 7:10 (thats the time I must sit in my car and start driving
and then 16:15 / 16:40 when notification is send )
Posted: Wednesday 13 April 2016 15:45
by woody4165
A couple of questions regarding the log.
Since this device will be used mainly for 4-6hrs per day, how do you intend using the log/graph.
I see that after the "working" period the value of the device remain the last that was set.
Probably, should be set to 0, don't you think?
Posted: Wednesday 13 April 2016 18:24
by woody4165
Moved to a Dummy Custom Device, and now using log and graph.
In my Frontpage.js, I added some code to change the description of the tab from "Home to Office" to "Office to Home" depending on the operating hours and coloring in green or red depending on the same value of usualtime.
I set to 0 the device when not in operating hours, so the graph is more readable.
Posted: Thursday 14 April 2016 9:05
by assenzuid
Great stuff. I will also try to implement this.
I have also a feature request.
Is it possible to get some traffic information say around 30Kms of my Home coordinates in a readable view?
My programming knowledge is not so good
Posted: Thursday 14 April 2016 12:08
by bran2000
i have a problem : i used the last script and modify the idx, the coordinates and the Google api key.
your script lua is in the events.
it doesn't work the switch "text"not display anything.
i see in your script a import json.lua Library, do i need to create the file json.lua in the folder /home/pi/domoticz/scripts/lua/ ?
thanks
Posted: Thursday 14 April 2016 12:13
by woody4165
Yes. You need to have JSON.lua (you should find somewhere in the wiki or in the forum where to download) and copy possibly in the lua folder under domoticz/script and call it within this script.
Posted: Thursday 14 April 2016 15:25
by woody4165
assenzuid wrote:Great stuff. I will also try to implement this.
I don't think that Google give this kind of information in a text way.
The only thing that is near to that is a google map view with colored street, but I don't think can be useful.
If you have a website that give this information and produce such an XML or a file like that maybe it can be checked.
Posted: Thursday 14 April 2016 15:36
by bran2000
Any idea where i can download the JSON.lua ?
i don't find any link
Posted: Thursday 14 April 2016 15:49
by woody4165
Have you tried to search in the wiki for "json.lua"?
Posted: Thursday 14 April 2016 15:54
by bran2000
woody4165 wrote:Nice job xces!
i have the same mistake, what do you mean to move before declaration of variables; how i correct this ?
Posted: Thursday 14 April 2016 16:00
by woody4165
I have moved it before time = os.date(*t)
And it worked for me.
Posted: Thursday 14 April 2016 16:29
by bran2000
Thanks, it's working for me too !
any idea where i can download the "json.lua" ?
