ONVIF RTSP camera support
- EdwinK
- Domoticz version: BETA
Re: ONVIF RTSP camera support
Since the original post is almost 2 years old, I doubt it would be added any time soon. So I'm looking for another way to do this.
Luigi87
I think there will be no support in this:
check this tread: viewtopic.php?t=4273
There is a technical reason for this apparently ...
See the message from: Nayr
RSTP Streams from a security camera wont play in a browser without a plugin, the video has to be transcoded to be streamed with flowplayer or native html5..
Would take some serious horsepower to transcode multiple HD RSTP streams into a compatible web-format, much more power than a domoticz server typically has.
Your camera proabibly has a jpeg snapshot URI, you just need to figure it out.. JPEG might not be the most elegant but it requires no processing by Domoticz and is widely compatible with all devices.
AngelG
Thank you very much. Work for me with a camera SV3C (SV-D02POE-10080P)ArieKanarie wrote: Thursday 22 June 2017 11:00The second url indeed helped me finding de snapshoturl for my RTSP/ONVIF camerajprod wrote:+1
a workaround:
http://forum.micasaverde.com/index.php? ... 960.5;wap2
http://www.openipcam.com/forum/index.ph ... 37#msg5125![]()
Good tip!
Attention: If your camera uses another port for the ONVIF protocol, don't forget to ad this port to the url in the command.
For the record: Owners of a FunXWE (FS02-0) IP camera can use the snapshot url: http://<Camera_ip>/web/cgi-bin/hi3510/snap.cgi?&-getstream&-sn
(Manufacturer/Model: RTT-5300)
