Re: D-Link, Zipato and Philio multi-sound sirens
Posted: Thursday 13 July 2017 11:21
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
Could this work in domoticz through lua? (will try myself but any lua experts know)The Siren from Philio (PSE02) is sold as a multi sound device, but to make it play other sounds it has to receive a NOTIFICATION_REPORT. This report is normally sent out from a sensor such as a PIR or door/window-sensor. That means it's possible to e.g. play a Door Chime sound when a door/window-sensor is opened.
When sending a SWITCH_BINARY_SET (which is the default command that will be sent to this device from TellStick ZNet) will only make it play the default emergency sound.
In order to play other sounds, a NOTIFICATION_REPORT has to be sent out from TellStick - that can be done from a Lua-script.
We've put together a script that can send out the NOTIFICATION_REPORT when a device (or dummy-device) is turned on, it's available here: https://github.com/telldus/tellstick-lu ... /Siren.lua
