Step by step guide: Sonos integration
Hanfelt
Re: Step by step guide: Sonos integration
Post by Hanfelt »
Updated dzvents code
active = true,
  on = { ['timer'] = 'every minute' },
  execute = function(domoticz)
        local json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
        local sonos=assert(io.popen('curl http://192.168.50.3:5005/Altan/state'))
        local sonos_name = 'Sonos, Altan'
        local status = sonos:read('*all')
        sonos:close()
        local jsonStatus = json:decode(status)
        playerstate = jsonStatus['playerState']
        if (playerstate == 'PLAYING')
        then
            domoticz.devices[sonos_name].switchSelector(10)
        elseif (playerstate == 'PAUSED_PLAYBACK')
        then
            domoticz.devices[sonos_name].switchSelector(20)
            domoticz.devices[sonos_name].switchSelector(0)
scheveningen
Post by scheveningen »
No more error :)
commentator
Post by commentator »
Holland wrote:There a few options to integrate Sonos with Domoticz
1. via php https://github.com/DjMomo/sonos
2. via the sonos http api; https://github.com/jishi/node-sonos-http-api
I prefer option 2, since it's far more flexible and (for me) easier to implement :P
Below you can find the step by step guide to get this running.
1. First make sure that at least version 4.0.0 of node is running. If it's older; update to the latest version.
Thanks for the nice tutorial. Added this on my Domoticz pi. And it is working very wel. Except this:
I see this in the errorlog when pressing a button:
Error: Error opening url: http://myinternalip:5005/woonkamer/play
Looks like a Domoticz issue as the Sonos is playing musica after pressing the button.
Ideas how to solve this?
Holland
Domoticz version: Beta Ch
Post by Holland »
@commentator;
It's a known issue. The sonos api doesn't give any response when it received a correct command, and gives a response when the command is incorrect. Ideally it should return like OK. You can safely ignore the error. Actually the sonos http api developer should be contacted, but I haven't done that yet.
viewtopic.php?f=6&t=10211
edit: today I posted a request at github sonos http api; https://github.com/jishi/node-sonos-http-api/issues/275
Now, all we need to do is wait........
commentator
Holland wrote:@commentator;
thanks :) Just waiting for a fix :)
An other question, how to start a radio stream from domoticz?
Because:
http://mylocalip:5005/livingroom/favorite/qmusic
doesn't work @ all
dhanjel
Domoticz version: 3.5146
Post by dhanjel »
Is it your favourite list? I use the same command, and it works for me.
Sent from my Nexus 6P using Tapatalk
commentator
yes, the tunein radio channel is in my favorites with this name
stanv
Post by stanv »
I got this very very clear and simple guide working. At least....almost.
Got the JSON lua on, when doing the http-request the Sonos starts and stops.
But, how do I get this as a switch in Domoticz after step 9?
stanv
Post by stanv »
stanv wrote:I got this very very clear and simple guide working. At least....almost.
dumb question, got it.
well, still not sure what the second LUA script is for.
Holland
Post by Holland »
The lua script is just an example for what you can do with it. In this case, Sonos stops playing, the moment the TV is switched on
Tharland
Post by Tharland »
piotr wrote:Get a free api-key from http://www.voicerss.org/ and you can get spoken (TTS) messages like: "The lights are off" when switching lights off.
usage example : http://yourserver:5005/LiveRoom/say/The lights are off
Ps: did anyone find a way the display the artist/track info in Domoticz ?
anyone know where to create the settings.json file?In which folder?
Holland
Post by Holland »
In the root folder
If you want to change default settings, you can create a settings.json file and put in the root folder.
See: https://github.com/jishi/node-sonos-http-api
Tharland
Post by Tharland »
Holland wrote:In the root folder
which root folder? i only get a message about i need to register api key, but i have done this. and created a settings.json with the api key in the node-sonos-http-api folder
Can anyone tell me?
Holland
Post by Holland »
Updated the guide.
Update solves this; viewtopic.php?f=6&t=10211
- Install the most resent version of node-sonos-http-api/
- changed the example lua script, since developper changed the JSON string a bit
naitsirhc
Post by naitsirhc »
first of all, thank you for the easy to follow how to
I get it all running on my Domoticz system and have a nice Icon at my desktop.
Unortunatly I get stuck at booting on startup.
I'm running on Jessie:
when I do:
2. sudo pm2 startup systemd –u pi....... it kills the proces
3. pm2 start nefiteasyhttpserver.sh....... this one I don't understand, copied from another topic I guess
4. pm2 save....... this one saves it.
So I start with 2.
then I do: cd node-sonos-http-api
then I type: pm2 start server.js
follows by: save pm2
Which delivers me a script in:: /home/pi/.pm2/dump.pm2
Do I have to rename the dump in a *.sh script?
or shortened:
What do I have to do, to run the server at startup :)
Kind regards
Christian
edit: typed wrong code
Und Tschjuß
Holland
Post by Holland »
@naitsirhc
After you got the service running, check with pm2 list, do the following;
pm2 startup
This will likely generate the following command;
sudo su -c "env PATH=$PATH:/usr/local/bin pm2 startup linux -u pi --hp /home/pi"
Execute the command that was generated via pm2 startup
Then, execute;
pm2 save
Restart and check if it has worked
naitsirhc
Post by naitsirhc »
I will try it, thanks for the quick reply
Und Tschjuß
ironrider
Post by ironrider »
i have to start server.js after a Domoticz reset.
Is ist possible to make the server.js running as a service.
Thanx
Sven
Btje
Post by Btje »
Would be cool to see just the song playing.
Verstuurd vanaf mijn SM-G920F met Tapatalk
DJBenson
Post by DJBenson »
Quick heads up to inform that 'playerState' is now 'playbackState' in the node-sonos-http JSON response. Aside from that, this is working perfectly using the dzVents method. Thanks all!!
