Page 2 of 4
Re: Vocal announcement - Good Morning Script
Posted: Monday 18 April 2016 19:08
by ldjldj
Strangely enough (language-settings on Dutch) the char " ' " in part of the sentence stating "Leo's gsm is aanwezig" (Leo's cell is at home) did block the output coming through the speakers. Removing the " ' " solved the problem.
Posted: Tuesday 19 April 2016 10:28
by Scones
jmleglise wrote:Hi, it seems that the script doesn't like your sentence !
To be sure, just replace this line os.execute ("/usr/bin/tts "..sentence.." &")
by this :
sentence ="test"
If this works, you must have a weird car in the sentence.
show us your sentence ...
Haven't tried this, but you could try
sentence ="test"
os.execute ("/usr/bin/tts '"..sentence.."' &")
The subtle difference is that the contents of sentence end up with single quote marks around it, making the whole sentence a single argument to /usr/bin/tts and also any odd character should get protected. Bear in mind that if you then include a single quote in the sentence variable, it will confuse things
Posted: Friday 13 May 2016 14:26
by commodore white
Scones wrote:I've got a MAX2PLAY Squeezebox / LMS multi-room setup at home using RPi's as both the server and room players (using PiCorePlayer)
Did you get anywhere with this. I was hoping for something similar though my LMS is based on a Joggler or two.
Peter
Sorted: Re: Vocal announcement - Good Morning Script
Posted: Friday 13 May 2016 14:56
by commodore white
I'm modifying this script for use with dzVents. Though I don't think thats a root cause, I get this error:
2016-05-13 13:29:35.691 LUA: An error occured when calling event handler GoodMorning
2016-05-13 13:29:35.691 LUA: /home/pi/domoticz/scripts/lua/scripts/GoodMorning.lua:41: attempt to call a nil value
... when executing the first of the following lines of code from the original script:
 json = (loadfile "/home/pi/domoticz/scripts/lua/json.lua")()
   local file=assert(io.popen('curl http://api.wunderground.com/api/'..wuAPIkey..'/forecast/q/'..city..'.json'))
Any ideas?
Peter
BTW does anyone know of a TTS that has a voice like HAL in 2001 or Marvin, the paranoid android??
--- silly me. Where do I get a copy of json.lua from? Sorted. Got from here: http://regex.info/blog/lua/json
dzVents: Vocal announcement - Good Morning Script
Posted: Sunday 15 May 2016 19:12
by commodore white
Hi y'all. My Good Morning script is heavily based on the original with the exception that it relies on dzVent plug-in for domoticz. Little benefit in doing so other than it obviates the need for a domoticz variable.
My version has a chatty date intro that probably need improvement but it'll do for now.
Calendar reminders are on my to-do list.
-- /lua/scripts/goodMorning.lua by commodore white
  active = true,
          'pirKitchen',
          'fobKeyfob'  -- while testing
  data = { goodMorning = {initial=0} },
	execute = function(domoticz, device, eventInfo)
  local s
  local sentence
  local dayOfMonth = domoticz.time.day
  local fobkeyfob = domoticz.devices["fobKeyfob"]
  if    (device.state == 'On' and  domoticz.time.hour >= 7 and  domoticz.data.goodMorning ~= dayOfMonth)
  or    device==fobkeyfob  -- on demand during testing
  then
      local say = {"first", "second", "third", "fourth", "fifth", "sixth", "seventh", "eighth", "nineth", "tenth",
                    "eleventh", "twelveth", "thirteenth", "fourteenth", "fifteenth", "sixteenth", "seventeenth", "eighteenth", "nineteenth", "twentieth" }
      if dayOfMonth <= 20 then s = say[dayOfMonth] end
      if dayOfMonth > 20 and dayOfMonth < 30 then s = "twenty " .. say[dayOfMonth-20] end
      if dayOfMonth == 30 then s = "thirtieth" end
      if dayOfMonth > 30 then s = "thirty " .. say[dayOfMonth-30] end
       sentence="Good morning. Its " .. os.date("%A") .. " " .. os.date("%B") .. " the " .. s .. ". "
    -- #############  TEMPERATURE & WEATHER FORECAST  #################
       sentence=sentence.."Its " .. domoticz.devices['THB'].temperature .. " degrees outside. " -- outdoor temperature
       local city = "EGUW"
       local wuAPIkey = "xxxx" -- Your Weather Underground API Key
       local raw = file:read('*all')
       file:close()
       local jsonForecast = json:decode(raw)
       prevision=jsonForecast.forecast.txt_forecast.forecastday[1].fcttext_metric  -- complete prevision
       --prevision=jsonForecast.forecast.simpleforecast.forecastday[1].conditions  -- small forecast
       if tonumber(string.sub(otherdevices_svalues['Alerte Meteo'], 1, 1))==3 then -- Only for FRANCE. Weather Vigilance  http://domogeek.entropialux.com/static/doc/index.html#api-Domogeek-GetVigilance
          sentence=sentence.."La météo est en vigilance orange :".. string.sub(otherdevices_svalues['Alerte Meteo'], 11)
       elseif tonumber(string.sub(otherdevices_svalues['Alerte Meteo'], 1, 1))==4 then
          sentence=sentence.."La météo est en vigilance rouge :".. string.sub(otherdevices_svalues['Alerte Meteo'], 11)
       sentence = sentence .. prevision
    -- #############  TRASH DAY #################
       numOfDay=os.date("%w")
       if (numOfDay == '4') then -- thursday
           sentence = sentence .. " Don't forget to put out the rubbish."
       print("talk: "..sentence)
       os.execute ("/usr/local/izsynth '"..sentence.."' &")
       domoticz.data.goodMorning = dayOfMonth
Posted: Sunday 15 May 2016 20:44
by Derik
Greaaaaat!!!!
Looks the best Talking option..
I was almost @ the point to buy a Homey voor dutch language voice switching....
Only voicerss sounds not bad for a NL voice. [ someone use a better ? ]
Is it possible to use more mics on 1 pi?
1 in the hall, living, kitchen...?
Multiple seakers?
Is there a simple wiki to add BT speakers..
What is the best option, add this to my CB2 with a lot of hardware, or use a other RPi?
Re: dzVents: Vocal announcement - Good Morning Script
Posted: Sunday 15 May 2016 22:30
by korniza
commodore white wrote:Hi y'all. My Good Morning script is heavily based on the original with the exception that it relies on dzVent plug-in for domoticz. Little benefit in doing so other than it obviates the need for a domoticz variable.
  active = true,
          'pirKitchen',
  local s
  local sentence
  then
       local city = "EGUW"
       file:close()
I get an error if I copy&paste as a lua script to events.
Error: EventSystem: Lua script goodMorning did not return a commandArray
How can I use this script? :oops:
Posted: Sunday 15 May 2016 23:17
by jmleglise
@Derik
For Text To Speech (TTS), I suggest you to use the awsome script "izsynth". search the forum. You can chose between more than 5 TTS system. For example the excellent "naturalreaders".
Posted: Sunday 15 May 2016 23:19
by commodore white
korniza wrote: I get an error if I copy&paste as a lua script to events.
You need to install dzVents. Follow the install instructions here github.com/dannybloe/dzVents/tree/dev then copy/paste the script into your lua/scripts subdirectory.
You'll need to edit the script so it reflects the name of a motion detector thats in the same room as your domoticz and a speaker plugged into it but you knew that didn't you!. I also have a push button device I use to trigger scripts manually; handy when debugging.
Peter
Posted: Sunday 15 May 2016 23:36
by korniza
Thank you so much sir! I'll try it!
Posted: Sunday 15 May 2016 23:56
by jmleglise
This is a part to enhance the synthesis of the prevision. This replace acronym :
(To be completed and to be adapted to your language)
		local t = {
		["ºC"] = "degré",
		[" ENE "] = " Est Nord Est ",
		[" NNE "] = " Nord Nord Est ",
		[" NE "] = " Nord Est ",
		[" N "] = " Nord ",
		[" NNO "] = " Nord Nord Ouest ",
		[" NO "] = " Nord Ouest ",
		[" SSE "] = " Sud Sud Est ",
		[" SE "] = " Sud Est ",
		[" S "] = " Sud ",
		[" SSO "] = " Sud Sud Ouest ",
		[" SO "] = " Sud Ouest ",
		[" O "] = " Ouest ",
		[" E "] = " Est ",
		["km/h"] = " kilometre heure"	}
		for k, v in pairs (t) do
			 prevision = string.gsub(prevision, k, v)
and this is a part to wish Birth Day or remember event :
local tableBirthDay = {
jeanmarc="09/04/19xx",
isabelle="01/06/19xx",
justine="25/09/20xx"
print(os.date("%d/%m"))
for key, valeur in pairs(tableBirthDay) do
	print(key, valeur)
	print(string.sub(valeur, 1, 5))
	if os.date("%m/%d") == string.sub(valeur, 1, 5)
	then
		print("BirthDay !")
PS : sorry , french date ... DD/MM/YYYY
Posted: Monday 16 May 2016 0:29
by commodore white
Thanks jmleglise, I was wondering the best best way to convert wind directions to something pronounceable.
Peter
Posted: Monday 16 May 2016 14:26
by Derik
jmleglise wrote:@Derik
Thanks...
I think this is a simple way for me.
Posted: Monday 16 May 2016 15:25
by korniza
please help!
I install dzVents following wiki. I saved script under lua/scripts. I created a virtual switch named fobKeyfob.When I switch fobKeyfob to ON, I get error:
2016-05-16 16:05:46.192 User: Admin initiated a switch command
2016-05-16 16:05:46.272 LUA: Handling events for: "fobKeyfob", value: "On"
2016-05-16 16:05:46.272 LUA: =====================================================
2016-05-16 16:05:46.272 LUA: >>> Handler: goodMorning
2016-05-16 16:05:46.273 LUA: >>> Device: "fobKeyfob" Index: 27
2016-05-16 16:05:46.273 LUA: .....................................................
2016-05-16 16:05:46.273 LUA: An error occured when calling event handler goodMorning
2016-05-16 16:05:46.273 LUA: /home/pi/domoticz/scripts/lua/scripts/goodMorning.lua:17: attempt to compare number with nil
2016-05-16 16:05:46.274 LUA: <<< Done
2016-05-16 16:05:46.274 LUA: -----------------------------------------------------
As error reports, error appeared in line 17 where I have the following line:
Any Idea what is wrong?
Thank you!
Posted: Monday 16 May 2016 16:16
by korniza
I found that issue appeared due to wrong version of dzVents. It repuired DEV version :oops: . Now I get another error :roll:
2016-05-16 17:12:38.102 LUA: Handling events for: "fobKeyfob", value: "On"
2016-05-16 17:12:38.102 LUA: =====================================================
2016-05-16 17:12:38.103 LUA: >>> Handler: goodMorning
2016-05-16 17:12:38.104 LUA: >>> Device: "fobKeyfob" Index: 27
2016-05-16 17:12:38.105 LUA: .....................................................
2016-05-16 17:12:38.107 LUA: An error occured when calling event handler goodMorning
2016-05-16 17:12:38.108 LUA: /home/pi/domoticz/scripts/lua/scripts/goodMorning.lua:34: attempt to index field 'THB' (a nil value)
2016-05-16 17:12:38.109 LUA: .....................................................
2016-05-16 17:12:38.109 LUA: <<< Done
2016-05-16 17:12:38.110 LUA: -----------------------------------------------------
2016-05-16 17:12:37.982 (Synth) Light/Switch (fobKeyfob)
I think this has to do with Weather Underground... :( :|
Posted: Monday 16 May 2016 16:47
by korniza
Peter
Final! It is working!! :D
Thanks again sir for sharing your script! :) :D
Posted: Monday 16 May 2016 20:15
by commodore white
Hi korniza. Pleased to hear you got it working and that you spotted my deliberate error in forgetting to tell you that you needed a device called THB from which you can derive the outside temperature.
Hi jmleglise. I incorporated your two suggestion - they work a treat. The birthday announce thingy was just in time for my sons birthday. Kudos.
       local birthdays = {
          martyns="16/05/19xx",
          peters="25/04/19xx",
          gemmas="01/08/19xx",
          ritas="01/03/19xx"
      for key, valeur in pairs(birthdays) do
         if os.date("%d/%m") == string.sub(valeur, 1, 5)
         then
            sentence = sentence .. key .. " birthday! "
Posted: Monday 16 May 2016 21:36
by jmleglise
Posted: Friday 20 May 2016 15:39
by commodore white
Liked this script so much, I created another.
It seemed a shame that I only ever got one weather report so this dzVents script checks the weather every hour and, if its changed and someone walks into the room, they'll get a weather update.
I'll probably drive us nuts in a few days but its fun for now.
Remember you'll have to install the dev version of dzVents to use it or just nick the good bits.
-- /lua/scripts/weather.lua by commodore white
  active = true,
          ['timer'] = 'at *:10', -- fetch an update ten minutes past each hour
          'pirTwo',              -- my PIR sensor
  data = { goodMorning = {initial=0},
           previousForecast = {initial=""},
           recentForecast = {initial=""}
    local sentence = ""
    fetchWeatherForecast = function()
         local city = "xxxx"
         file:close()
         domoticz.data.recentForecast=jsonForecast.forecast.txt_forecast.forecastday[1].fcttext_metric  -- complete forecast
         --domoticz.data.recentForecast=jsonForecast.forecast.simpleforecast.forecastday[1].conditions  -- small forecast
         print("fetchWeatherForecast: " .. domoticz.data.recentForecast)
    reportDate = function()
        local s
        if dayOfMonth > 20 and dayOfMonth < 30 then s = " 20 " .. say[dayOfMonth-20] end
        if dayOfMonth == 31 then s = "30 first"  end
        sentence=sentence .. "Its " .. os.date("%A %B") .. " the " .. s .. ". "
        -- print("reportDate: " .. sentence)
    reportAniversaries = function()
        local aniversaries = {
          ["martyns birthday"]="16/05/19xx",
          ["peters birthday"]="25/04/19xx",
          ["gemmas birthday"]="01/08/19xx",
          ["ritas birthday"]="01/03/19xx"
        for event, date in pairs(aniversaries) do
            if os.date("%d/%m") == date:sub(1, 5)
            then
              sentence = sentence .. event .. ". "
    reportWeather = function()
         sentence=sentence.."Outside its " .. domoticz.devices['THB'].temperature .. " degrees. "
         local report = domoticz.data.recentForecast
         local t = {
          ["C. "] = " degrees. ",
          [" N "] = " North ",
          [" NNW "] = " Nor Nor West ",
          [" NW "] = " North West ",
          [" WNW "] = " West Nor West ",
          [" W "] = " West ",
          [" WSW "] = " West Sow West ",
          [" SW "] = " South West ",
          [" SSW "] = " Sow Sow West ",
          [" S "] = " South ",
          [" SSE "] = " Sow Sow East ",
          [" SE "] = " South East ",
          [" ESE "] = " East Sow East ",
          [" E "] = " East ",
          [" ENE "] = " East Nor East ",
          [" NE "] = " North East ",
          [" NNE "] = " Nor Nor East ",
          ["Winds"] = " Wind from the ",
          ["km/h"] = " kilometres per hour",
            report = string.gsub(report, k, v)
         sentence = sentence .. report
    reportRubbish = function()
        -- if thursday
        if (numOfDay == '4') then sentence = sentence .. " Don't forget to put out the rubbish." end
---------------------- start here ----------------------
    -- fetch the weather forecast periodically
    if device == nil then
        fetchWeatherForecast()
    -- if motion detected and its after 7 o'clock and before 9:00 pm
    if device ~= nil and domoticz.time.hour >= 7 and domoticz.time.hour <=21
    then
        --if first time today
        if domoticz.data.goodMorning ~= dayOfMonth
        then
            sentence = domoticz.time.hour <= 12 and "Good morning. " or "Good afternoon. "
            reportDate()
            reportAniversaries()
            reportWeather()
            if domoticz.time.hour <= 14 then reportRubbish() end
            domoticz.data.goodMorning = dayOfMonth                        -- show first time report has been completed
            domoticz.data.previousForecast = domoticz.data.recentForecast -- show recent forecast has been reported on
        else -- other than the first time
            if domoticz.data.recentForecast ~= domoticz.data.previousForecast -- if the forecast has changed in the last hour
            or device == fobKeyfob                                            -- during testing
            then
                sentence = "Here is an updated weather forecast. "
                reportWeather()
        if sentence ~= "" then
            os.execute ("/usr/local/izsynth -r '"..sentence.."' &")
    end -- its after 7 o'clock in the morning
Oh! nearly forgot. You need an outside temperature sensor called "THB". I derive mine from weather underground.
good luck
Posted: Sunday 22 May 2016 18:29
by micbou
Any idea how to get the audio over Bluetooth? I know there is a 0 (auto), 1 (mini jack) and 2 (HDMI) option, but dont see any BT
