Page 2 of 2
Re: Greenwave NS310-F not connecting
Posted: Tuesday 12 July 2016 14:32
by elmortero
did you check the devices list?
In my case the last device that was created when including the node shows as kwh meter after about 24h
Posted: Tuesday 12 July 2016 23:22
by Plantje
That's where I check on daily basis....
The only thing I can think of now is that the node should be connected to somethin using at least "some" power 24/7
Posted: Friday 05 August 2016 13:33
by Plantje
A month further now... still nothing.
Posted: Friday 05 August 2016 13:35
by jannl
May be the node is broken.....
Posted: Friday 05 August 2016 13:42
by Plantje
Both of them?
Ok, I must admit: one is connected to the refrigerator, so it will not have power consumption all the time.
I am going to put the two closer to the ZWave controller and connect them to an always on device. In order to do that I have to plug one power node into the other one, but that is not a real issue I think. Let's see what happens then
Posted: Wednesday 10 August 2016 8:31
by Plantje
I have put them in series with a powernode that measures my mediacenter usage. That machine runs 24/7. After a few days still no kWh. So, I guess it is the combination with the white powernodes that doesn't work. Let's see what happens.
Posted: Monday 01 June 2020 17:22
by tjabas
Hi, i have a couple of np310f , and after a power failjure all the plugs turns on, does anyone else have this problem or may it be corrected in the later 1.6 z-wave version ?
