Somfy Telis Remotes
SHadley1138
Re: Somfy Telis Remotes
Post by SHadley1138 »
10;Rts;clean
piokuc
Post by piokuc »
Thanks.
But why it not working for me ? What i do wrong ? Why not open and close my somfy if reconized signal ?
And why RC which i send is 0412 but in RFLink save 0413 ?
SHadley1138
I had similar problems, Rflink looked OK, but domoticz just wouldn't work
I think the number has increased as its a rolling code, so it changes each time it's used
piokuc
Post by piokuc »
Is any chance to fix it and help me to start working with Somfy ? For now not working.
Is anybody who start working it with somfy and can help me ?
SHadley1138
I used the dry contacts in the end and bought a cheap relay from eBay
Might have another play today
piokuc
Post by piokuc »
But any user use it as write on forum... any help
Anybody run somfy on RFLink with Domoticz ?
octopuss83
Post by octopuss83 »
Hello ,
My blind works ok with rflink with the command : 10;RTS;0100F2;0;DOWN; . I wrote to the rflink developper you must create new remote in EEPROM RFlink address , i see that level is reached on the post ... But it s very important to choose a remote address who not begin by 00.... ; address could be 20.... for example .
In My case Domoticz not send command 10;RTS;0100F2;0;DOWN; to rf link I have a message "Error sending switch command, check device/hardware !"
The other switch works very well.
If you need help on rflink i can help you
if you need help on DomoticZ u can help me
Best regards
Best Regards
------========= Octopuss =======---------
supermat
Post by supermat »
piokuc wrote:HI
I read this manual:
https://matdomotique.wordpress.com/2016 ... -et-somfy/
i send command
10;RTS;0F0F0F;0412;3;PAIR;
and then i press for about 3 secund button on remote to PROG.
On loader show example
20;07;OK;
You must press for about 3 second on remote to prog AND THEN send the command to pair
The blind must be in prog mode to register the "new remote".
The RC is the rolling code, it do +1 for each command send and pairring is a command.
piokuc
Post by piokuc »
Hi i pressed about 3 sec.
But after i prog RFLink then i must also prog Blinds by send command from RFLink ? But after that Remote will stop working ? Now my remote works ok with blinds.
piokuc
Post by piokuc »
Is anybody who can write step by step how configure Somfy with RFLink to working in Domoticz ? Please....
SHadley1138
I've tried loads to get this to work, but just can't get it to work. I can program it into Rflink using the loader, but I just can't get it to work
piokuc
Post by piokuc »
I do all as write in manual:
and i tested without rooling code (correct in manual one day ago) and problem is the same. Blinds run for some seconds (maybee 3 to 5 seconds) and stop. Send command again , run again blinds only for 3-5secund and stop. But command should run blind to close full window. Why working only some secunds ?
I send command:
10;RTS;02FFFF;3;DOWN;
From remote SMOOVE ORIGIN RTS works ok. When i click button DOWN blinds run and full close my window.
Please help.
bananig
Post by bananig »
Hi piokuc,
did you ever solve your issue?
it is the same for me. i could setup the rflink and can send UP and DOWN commands, but the blinds only run for a few seconds and then stop, instead of completing up/down to the end.
would appreciate your help.
javicalle
Post by javicalle »
I think that the problem can be related to this:
hoeby
Domoticz version: V2022.1
Post by hoeby »
I have 2x somfy tilt 50 venetian blind motors.
I tried and googled and tried. But couldn't get it to work propperly. What i did, was connecting a device with espeasy to the pcb (solder). Works without issues. Rf-link is disconnected and dropped in a box.
Maybe not what you would like to hear. Hopefully for you, you can find the answer to it.
homeJLB
Domoticz version: 2024.7
Post by homeJLB »
I have a RFX-com-XL and before a RFX-com-E both connected to 9 Somfy blinds. they worked for over 5 years now. But now the board is crashed (tinker board + tinker board OS) and I'm putting everything over on Raspberry Pi4 - 4. I to had some trouble reconnecting the new Domoticz and rfx to the blinds. So I cleared all remote in the RFX and I reset the Blinds with the 3-8-3 method. now all is working again. For RF-link I have no experience
@hoeby; what do you meen by disconnected and dropped in a box.
hoeby
Post by hoeby »
homeJLB wrote: Saturday 30 October 2021 19:49 @hoeby; what do you meen by disconnected and dropped in a box.
That i don't use rf-link anymore. I only used it for somfy, but it didn't worked perfect on blinds,
Disconnected it from the pi and put it away
