Page 100 of 114
Posted: Monday 18 March 2019 17:43
by salvacalatayud
Madgeni wrote:Ok, that's a different issue. Will raise it with Google (they'd assured me that all languages were now supported)
Pon la persiana al 50%
Baja la persiana al 50%
First does nothing, second returns that can't be done for now
Enviado desde mi Mi A2 mediante Tapatalk
Posted: Monday 18 March 2019 17:52
by Varazir
Madgeni wrote: Monday 18 March 2019 8:50
Varazir wrote: Sunday 17 March 2019 21:25
Tested it again, still nothing and the second time it just said it couldn't connect to the website
2019-03-17 21:23:05.043 Python: Changed: ID: 50 Name: Bedroom Blinder, Type: 244, subType: 73, switchType: 16, s_value: 0, n_value: 0, n_value_string: Closed, last_update_string: 2019-03-17 21:23:03
Can you 'sync my devices' and try again please? Thanks
\o/ it's working even if I get a reply from GH that it couldn't contact CONTROLICZ
Posted: Monday 18 March 2019 17:59
by salvacalatayud
Tried again and now GH responds but even if I say a % it closes all
Posted: Monday 18 March 2019 18:38
by Madgeni
Ok - yay @Varazir (although I clearly need to fix the response - will do this now)
Interesting @salvacalatyud - can you 'sync my devices' and try again?
Posted: Monday 18 March 2019 18:49
by salvacalatayud
Madgeni wrote:Ok - yay @Varazir (although I clearly need to fix the response - will do this now)
Done, now controlicz is not available
Posted: Monday 18 March 2019 18:56
by Madgeni
o_0
Can you try again? Have you added any new devices? Controlicz is working, and can't see any errors for you in the logs
ah - if this was open/close - it should be ok now. can you try percentages also?
Posted: Monday 18 March 2019 20:07
by salvacalatayud
Now responds but shutter gets closed. Do you send nvalue 2?
Posted: Monday 18 March 2019 20:08
by Madgeni
What command are you sending?
Posted: Monday 18 March 2019 20:13
by salvacalatayud
Madgeni wrote:What command are you sending?
I say put shutter to 20%
Posted: Tuesday 19 March 2019 8:53
by Madgeni
How about now?
Posted: Tuesday 19 March 2019 16:18
by salvacalatayud
Madgeni wrote:How about now?
Working!
Posted: Tuesday 19 March 2019 16:39
by Madgeni
Excellent
Posted: Tuesday 02 April 2019 14:48
by jkimmel
Quite a time ago I registered.
Got Controlicz running, still see my devices in Google Home.
Would like to subscribe but I can't login with my gmail address. User unknown.
Posted: Tuesday 02 April 2019 15:11
by Madgeni
You will need to re-register - users without subscriptions are archived after a time for security
Posted: Wednesday 03 April 2019 18:29
by jkimmel
Madgeni wrote: Tuesday 02 April 2019 15:11
But obviously I can't register with my email address used before. I have only one.
Posted: Thursday 04 April 2019 0:18
by Madgeni
You can re-register if the account doesn't exist anymore
Posted: Wednesday 10 April 2019 17:51
by jimm2
Can anyone confirm that they have Controlicz working properly with a Google Home Routine?
I have setup a Google Home Routine to activate a Domoticz Scene via Controlicz. This works as expected but each time I voice activate the routine, I get a voice response from Google Home saying "Sorry, I can't reach the Controlicz, please try again later". This response occurs even though there is clearly a connection to Controlicz since the Scene is activated properly. I tried re-linking my Controlicz account in Google Home but it had no effect.
Is anyone else seeing this issue or found a way to disable this voice response?
Posted: Wednesday 10 April 2019 20:48
by Madgeni
jimm2 wrote: Wednesday 10 April 2019 17:51
Hi -
i've just tested a Scene in a routine - Activate <SceneName> works fine
Posted: Wednesday 10 April 2019 23:33
by jimm2
[/quote]
Hi -
[/quote]
Thanks. Then is there anyway to troubleshoot why I'm getting the Controlicz connection error message when there is clearly a connection established between Controlicz and Google Home?
Or is there anyway to disable this message?
Posted: Thursday 25 April 2019 22:54
by jpvaneijk
Hi Madgeni,
Had a few issues with my Harmony Hub but they're solved now.
When I'm asking GH to turn on the lights, it's not only turning the lights on but also My TV, Radio, Netflix, Spotify, Spotify on TV, Youtube and my mediaplayer.
If I tel GH to turn off my lights, she sais: OK, I'm turning off 13 (?) lights.
Is this something on your side or mine and can you help my fix this?
Thanx in @vance!
