Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
salvacalatayud
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by salvacalatayud »
Madgeni wrote:Ok, that's a different issue. Will raise it with Google (they'd assured me that all languages were now supported)
Pon la persiana al 50%
Baja la persiana al 50%
First does nothing, second returns that can't be done for now
Enviado desde mi Mi A2 mediante Tapatalk
Varazir
Post by Varazir »
Madgeni wrote: Monday 18 March 2019 8:50
Varazir wrote: Sunday 17 March 2019 21:25 Tested it again, still nothing and the second time it just said it couldn't connect to the website
2019-03-17 21:23:05.043 Python: Changed: ID: 50 Name: Bedroom Blinder, Type: 244, subType: 73, switchType: 16, s_value: 0, n_value: 0, n_value_string: Closed, last_update_string: 2019-03-17 21:23:03
Can you 'sync my devices' and try again please? Thanks
\o/ it's working even if I get a reply from GH that it couldn't contact CONTROLICZ
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
salvacalatayud
Tried again and now GH responds but even if I say a % it closes all
Madgeni
Post by Madgeni »
Ok - yay @Varazir (although I clearly need to fix the response - will do this now)
Interesting @salvacalatyud - can you 'sync my devices' and try again?
salvacalatayud
Madgeni wrote:Ok - yay @Varazir (although I clearly need to fix the response - will do this now)
Done, now controlicz is not available
Madgeni
Post by Madgeni »
o_0
Can you try again? Have you added any new devices? Controlicz is working, and can't see any errors for you in the logs
ah - if this was open/close - it should be ok now. can you try percentages also?
salvacalatayud
Now responds but shutter gets closed. Do you send nvalue 2?
Madgeni
Post by Madgeni »
What command are you sending?
salvacalatayud
Madgeni wrote:What command are you sending?
I say put shutter to 20%
Madgeni
Post by Madgeni »
How about now?
salvacalatayud
Madgeni wrote:How about now?
Working!
Madgeni
Post by Madgeni »
Excellent :)
jkimmel
Domoticz version: 2021.1
Post by jkimmel »
Quite a time ago I registered.
Got Controlicz running, still see my devices in Google Home.
Would like to subscribe but I can't login with my gmail address. User unknown.
Rfxcom
Raspi 4
Madgeni
Post by Madgeni »
You will need to re-register - users without subscriptions are archived after a time for security
jkimmel
Post by jkimmel »
Madgeni wrote: Tuesday 02 April 2019 15:11 You will need to re-register - users without subscriptions are archived after a time for security
But obviously I can't register with my email address used before. I have only one.
Rfxcom
Raspi 4
Madgeni
Post by Madgeni »
You can re-register if the account doesn't exist anymore :)
jimm2
Post by jimm2 »
Can anyone confirm that they have Controlicz working properly with a Google Home Routine?
I have setup a Google Home Routine to activate a Domoticz Scene via Controlicz. This works as expected but each time I voice activate the routine, I get a voice response from Google Home saying "Sorry, I can't reach the Controlicz, please try again later". This response occurs even though there is clearly a connection to Controlicz since the Scene is activated properly. I tried re-linking my Controlicz account in Google Home but it had no effect.
Is anyone else seeing this issue or found a way to disable this voice response?
Madgeni
Post by Madgeni »
jimm2 wrote: Wednesday 10 April 2019 17:51 Can anyone confirm that they have Controlicz working properly with a Google Home Routine?
Hi -
i've just tested a Scene in a routine - Activate <SceneName> works fine
jimm2
Post by jimm2 »
[/quote]
Hi -
[/quote]
Thanks. Then is there anyway to troubleshoot why I'm getting the Controlicz connection error message when there is clearly a connection established between Controlicz and Google Home?
Or is there anyway to disable this message?
jpvaneijk
Domoticz version: latest
Post by jpvaneijk »
Hi Madgeni,
Had a few issues with my Harmony Hub but they're solved now.
When I'm asking GH to turn on the lights, it's not only turning the lights on but also My TV, Radio, Netflix, Spotify, Spotify on TV, Youtube and my mediaplayer.
If I tel GH to turn off my lights, she sais: OK, I'm turning off 13 (?) lights.
Is this something on your side or mine and can you help my fix this?
Thanx in @vance!
