mvveelen
Re: Dashticz v2.0, custom positioning and multiple screens
Post by mvveelen »
OK,
I'll try once more:
The 2 calendars aren't working OK.
Sometimes I see both, sometimes I see none, sometimes I see twice the same, but most of the time I only see one of the calendars. I'm using the Apple calendar.
Is this still a bug or am I the only one with more than 1 Apple calendar having these issues ?
On a side-note: when I DO see the calendar(s), the colours can't be set so they are pink or blue (and you can barely read the appointments). Any fix on this?
Blueone
Post by Blueone »
robgeerts wrote:Cure is also working now:
In config.js add:
var trashcan = {}
trashcan.cure = { trashapp: 'cure', width:4, zipcode:'5654SB', housenumber:'3' }
And define in block as:
columns[1]['blocks'] = [trashcan.cure]
Working :), except the paper, it isn't shown, the title in the json is "Papier en karton"
qwerk
Post by qwerk »
when using the latest beta
the var _THEME = 'default' has to be in your config.
pkrabben
Domoticz version: 3.5877
Post by pkrabben »
In config.js add:
var trashcan = {}
Hi Rob thanks for this continuous improvements
What are the codes for recycle manager?
HansieNL
Post by HansieNL »
Find some code in the app. Maybe you can use it:
http#2http://afvalkalender.dar.nl/push/address?postcode=#3http://afvalkalender.dar.nl/push/calendar?postcode=##http://afvalkalender.goes.nl/#ehttp://dataservice.deafvalapp.nl/dataservice/DataServiceServlet?service=CHECK_ADRES&land=NL&postcode=#fhttp://dataservice.deafvalapp.nl/dataservice/DataServiceServlet?service=OPHAALSCHEMA&land=NL&postcode=##http://dutchapp.nl/afval/#+http://dutchapp.nl/afval/AfvalNederland.ics##http://dutchapp.nl/afval/area##http://dutchapp.nl/afval/gad#$http://dutchapp.nl/afval/hellendoorn##http://dutchapp.nl/afval/meld##http://dutchapp.nl/afval/meppel# http://dutchapp.nl/afval/opslaan##http://dutchapp.nl/afval/regg##http://dutchapp.nl/afval/regp##http://dutchapp.nl/afval/rova##http://dutchapp.nl/afval/twente##http://dutchapp.nl/afval/uden#$http://dutchapp.nl/afval/waardlanden#9http://inzamelkalender.hvcgroep.nl/push/address?postcode=#:http://inzamelkalender.hvcgroep.nl/push/calendar?postcode=#>http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=#)http://rova.quintor.nl/rest/toevoegingen/#=http://vpn-wec-api.recyclemanager.nl/v2/calendars?postalcode=##https#(https://afvalkalender.circulus-berkel.nl#)https://afvalkalender.cure-afvalbeheer.nl#!https://afvalkalender.cyclusnv.nl#+https://afvalkalender.gemeenteberkelland.nl##https://afvalkalender.meerlanden.nl##https://afvalkalender.venray.nl##https://app-measurement.com/a#,https://appservice.rd4.nl/api/afvalkalender/##https://inzamelschema.rmn.nl#Ahttps://pagead2.googlesyndication.com/pagead/gen_204?id=gmob-apps##https://www.avalex.nl#*https://www.gemeentebest.nl/afvalkalender/##https://www.google.com#'https://www.veldhoven.nl/afvalkalender/#1https://www.venlo.nl/trash-removal-calendar/ical/#*https://www.vianen.nl/afval/afvalkalender/##i#,iCertData failed to retrive data from remote
Blah blah blah
rbisschops
Domoticz version: 2.2563
Post by rbisschops »
I know it's all about taste, but I personally don't like the new weather icons. Is there a way to put the old icons back with breaking the coming releases. Using latests beta of this afternoon.
Thx
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
HansieNL
Post by HansieNL »
rbisschops wrote:I know it's all about taste, but I personally don't like the new weather icons. Is there a way to put the old icons back with breaking the coming releases. Using latests beta of this afternoon.
Thx
Ralph
var _USE_STATIC_WEATHERICONS = true; in config.js gives you the static icons back
Blah blah blah
tontze
Domoticz version: Beta Ch
Post by tontze »
I just did git pull, and all my buttons disappeared, they still exist in config.js ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Any errors in console?
HansieNL
Post by HansieNL »
tontze wrote:I just did git pull, and all my buttons disappeared, they still exist in config.js ?
I had the same, add the following to config.js...
Blah blah blah
robgeerts
Post by robgeerts »
Oopsie ;) will fix tonight when i get home
clubeddie
Post by clubeddie »
robgeerts wrote:TRASH CALENDAR (DE AFVAL APP)
WARNING: Only DeAfvalApp is working.
If anyone can provide me a JSON-output url of other services, send it to me :)
(With example zipcode)
I already have url's for:
Recyclemanager
MijnAfvalWijzer
Wil fix those asap so you dont need LUA-scripts
How can i extract a JSON output url?
I want to extract it for you from http://inzamelkalender.hvcgroep.nl/
Screenshot 2017-05-04 at 19.35.46.png (42.92 KiB) Viewed 2858 times
mvveelen
Post by mvveelen »
Recyclemanager
MijnAfvalWijzer
+1
Or rather... + 1000 :)
htilburgs
Post by htilburgs »
In config.js add:
var trashcan = {}
Rob, cannot get this to work.
I got an error "undefined". Any way I can check what's going wrong?
EDIT: clicking on it gives a 404 Not found
Hardware:
b00n
Post by b00n »
Someone know how to get the json from an site?
i need it from this one: https://mijn.circulus-berkel.nl/afvalkalender/
tontze
Post by tontze »
Hm, that didnt help for me ..
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
robgeerts
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Post by robgeerts »
In config.js add:
var trashcan = {}
Sure you have the latest version?? Maybe a cache problem?
b00n
Post by b00n »
Maybe an idea to add spotify support in the amazing dash ? :D
josimd
Post by josimd »
An easy question... how can add a blocktitle like "Schakelaars woonkamer" ?
Schermafbeelding 2017-05-04 om 20.53.00.png (242.09 KiB) Viewed 2814 times
htilburgs
Post by htilburgs »
robgeerts wrote:
In config.js add:
var trashcan = {}
It's the beta from 1/2 hour ago. Cleared cache and tried several browsers. No result. Cannot trace where it comes from.
Hardware:
Locked
