Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
Varazir
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by Varazir »
QSKONE wrote:hey google sync my devices
That is a no go Image
Skickat från min Nokia 7 plus via Tapatalk
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Madgeni
Post by Madgeni »
Varazir wrote: Saturday 12 January 2019 22:07
Hi, can you contact me from your Controlicz profile, and I'll take a look
Varazir
Post by Varazir »
Done
jorijnsmit
Post by jorijnsmit »
Is a temperature sensor in Domoticz always converted to a thermostat object in Google Home?
I was able to set up a temperature/humidity sensor as a device but Google Home thinks it is a thermostat, and gives me options such as heat/cool and the possibility to adjust the temperature. Is there any way to turn this object into a thermometer only? As in no thermostat functions?
silver323
Post by silver323 »
Who can help me.. I don't see what's wrong.
After registrating a account at Controlicz i've filled in al the information. I used in domoticz a user who is admin also tried normal user. Filled this in to Controlicz.
With all the IP and port numbers.
So after testing the connection i've get the message Please check your connection setup.
Also restart the domoticz service on the pi, double checked everything and also the port forwarding for SSL.
Can someone help me?
Varazir
Post by Varazir »
silver323 wrote: Monday 14 January 2019 16:10 Who can help me.. I don't see what's wrong.
Just basic question:
You can access your domoticz from the internet ?
silver323
Post by silver323 »
Yes i can connect domoticz from outside with https://
So thats why i dont know whats going wrong.
Madgeni
Post by Madgeni »
Hi there - drop me a message from your Controlicz profile, and i'll take a look straight away
silver323
Post by silver323 »
Madgeni wrote: Monday 14 January 2019 22:23
I've send an contact me message at my controlicz profile
silver323
Post by silver323 »
silver323 wrote: Monday 14 January 2019 22:42
It works now with the help of Madgeni. Was an mistake of the portnumber :o
So now will check the devices.
Madgeni
Post by Madgeni »
For those using ngrok (which seems like a really great security option) - there's the issue of ngrok changing dns name on reboot.
However, with the idea, help and code of one of the forum users mraichura - there is a neat solution.
https://github.com/mayankraichura/ngrok ... utoupdater
You run this on your Domoticz instance (requires node) - and it will auto update your hostname in Controlicz whenever ngrok changes it.
dagasoft
Post by dagasoft »
Hi Magdeni.
Why I can't tell Google assistant to set thermostat temperatures to half degrees? If I say set room thermostat to 21,5 degrees it says that can't help me, but I can set them to 21 or 22 without any problem.
Instead, in Google home I can set them to 21,5 manually using +/- buttons. Do you know why it doesn't work with voice?
Madgeni
Post by Madgeni »
that's weird, it works for me - 'hey google set the thermostat to 21.5' worked here
dagasoft
Post by dagasoft »
Madgeni wrote:that's weird, it works for me - 'hey google set the thermostat to 21.5' worked here
I have checked again and it seems a spelling problem in Spanish. I have to say "21 dot 5 degrees". If I say "21 comma 5 degrees" it doesn't understand me. But when I say set thermostat to 21 dot 5 degrees, it answers "ok, setting thermostat to 21 comma 5 degrees". Weird hehe.
Varazir
Post by Varazir »
dagasoft wrote: Friday 25 January 2019 17:45
You say in Spanish ? In English it would be something like "set the thermostat to 21 point 5 degree"
dagasoft
Post by dagasoft »
That's right. You have to say 21 point 5. This way it works.
Madgeni
Post by Madgeni »
Had that issue with Alexa a year or so ago. Will feed back that alot of countries use commas
fransalinas
Post by fransalinas »
I can't see any scene in the Controlicz website > my devices page, only lights appear, but no scenes.
Any idea about why?
Madgeni
Post by Madgeni »
Is the Scene enabled toggle on in your Domoticz (under Users)?
rabbit38
Domoticz version: v4.9700
Post by rabbit38 »
Same problem here. I can't reach domoticz via SSL (IP:443). I can reach de DSM on SSL via port 5001 and i have the option HTTP tot HTTPS in DSM activated. If i enter IP:443 i get the message from the NAS nginx. I can reach Domoticz on 8084 perfectly. Can anybody help me?
