Unfortunateley, this does not work for me.atlej wrote: Saturday 19 January 2019 19:56
Deleting app buffer and data and then configure again solves it temporary for me. If I try to add a Geofence the app crashes, and the problem is back.
Notified app author on email. Since last configuration it has ben stable for 24hour ( without gefofence...)
Atle
BertB
Re: Domoticz app 2.0
Set 1= RPI 3B, latest Beta, RFLink USB, RFLINK WIFI, Zwave
Set 2= RPI 2B, Latest Beta, OTGW (USB), SBFSpot (Bluetooth)
PjotrS
- Domoticz version: 2.2284
It seems that this is still an issue right? I am unable to switch between colour and white as there is no button for it. I only get a colour wheel.salvacalatayud wrote: Sunday 21 October 2018 22:59 In new version milight can't change to warm white like in old version.
Enviado desde mi Redmi 4X mediante Tapatalk
BlackysBoss
Is it possible for the developers to stop messing with the layout of the app? There's an update allmost every night, and at this point I can't get to my temperature sensors anymore and the manual sorting doesn't stick.
BertB
-"you do not have the rights for this action!"
This message pops up whenever I click a device button in the app.
Despite a number of app updates.
Some weeks back, it worked just fine.
Domoticz itself runs on a Pi 3 and is the latest beta.
The app runs on Android amd is the paid version.
Please help.
Please help.
wizzard72
Just updated today to 0.2.75 (5532) and still have this issue.wizzard72 wrote: Saturday 05 January 2019 13:46Any update on this?wizzard72 wrote: Friday 02 November 2018 23:55 I'm on version 0.2.25 (4912) and the doorlock button has the wrong state:
The Status of the lock is Unlocked, but the switch button is enabled. If the lock has the status locked, the switch button is enabled (which is expected). With the lock unlocked the switch button state should be disabled.
Can this be solved?
atlej
- Domoticz version: Stable
Same problem here. I can delete app data and reconfigure to get rid of it, but as soon as the app is updated, OR I try to add a Geofence ( the app crash during process) the problem is back. Stock Domoticz 4.97 on rasbian stretch, app version 0.2.75(5532) on Samsung 7 android 8.0.0 AtleBertB wrote: Friday 25 January 2019 8:25 -"you do not have the rights for this action!"
Please help.
wizzard72
Just updated today to 0.2.78 (5584) and still have this issue.wizzard72 wrote: Friday 25 January 2019 16:02Just updated today to 0.2.75 (5532) and still have this issue.wizzard72 wrote: Saturday 05 January 2019 13:46Any update on this?wizzard72 wrote: Friday 02 November 2018 23:55 I'm on version 0.2.25 (4912) and the doorlock button has the wrong state:
Can this be solved?
sailmich
Domoticz newest beta
RPi
Zwave stick
@galadril
Could you please make the slider of percentage visible at any time. Now the slider is just visible if the blinds are not completely open or closed.
In domoticz web UI I have to push off to open my blinds, in the app I have to push on?
Could you please change it for blinds from off to open and on to close?
Thanks for your hard work
RPi
Zwave stick
@galadril
gschmidt
GCM migrating to FCM
Will the GCM functionality in Domoticz and the Domoticz App be migrated to FCM?
Hello, i have the same problem...salvacalatayud wrote: Friday 02 March 2018 22:16 Hello, I'm not sure if this is a bug, but when I enter in the rooms tab, scenes that exist into a room don't show in the app.
For example I have a bedroom where there are 5 devices and 1 scene, in the app shows that there are 6 devices but if I enter only 5 devices appear.
Domoticz premium 0.2.78 (5584)
and there are no charts in the room plan
Andyyyy
cobra045
- Domoticz version: 3.4834
Domoticz app 2.0 v0.2.78 (5584)
Info screen is not correct
Cobra045
Cobra045
mvroosmalen
After the recent update (0.2.78(5584)) the domoticz app is not working anymore. With debug on the app report connection OK and after 30sec or longer report a timeout. No switches etc. Before this version everything worked perfectly except when I had the update check on. This also caused delays and sometimes timeout errors, however still with all switches etc updated. Next to this problem it also causes domoticz(4.9700) to crash, most of the time when I refresh in the app.
Any suggestions?? or can you send me the old version of this APP? I've tried already with a fresh install. This is no solution.
Mark
Mark
Kruu
- Domoticz version: 2020.2
Anyone else having problems with, app is not able to detect my local wifi SSIDs as a result it always tries to connect to the remote server settings ?
I have the premium not lite app.
Settings worked until today, I have it set for months now. Nothing was changing.
Any fix?
EDIT:
Today it is working like nothing happened. No settings were changed, it just works on it's own.
Any fix?
EDIT:
Few example:RoadXY wrote: Friday 18 March 2016 16:21But when do you set your thermostat to below 10*C or above 30*C?pj-r wrote:And for my MySensors HVAC device set point from 4*C to 55*Cpiokuc wrote: For set temp should be from 4*C to 28*C. This is example for Danfoss thermostat. Now is from 10 to 30*C.
Currently I get 10 to 30*C
Boiler, fireplace, smokebox...
dressie
- Domoticz version: V2020.2
I have 4 accounts in Domoticz. Two of those are for our kids. I gave them only acces to their rooms (lights) and blocked the rest of the house. When loging in to the website using their accounts it works great, they can only see their rooms. Logging in to the Android App gives them acces to everything. I already cleared the data and cache on the phone and did a re-install.
It's a Samsung A3 model 2017 running Android version 8.0.0 with Domoticz Lite.
gcoupe
- Domoticz version: v4.10717
The IP address of my Domoticz server has changed. How do I change the connection details in the Android Domoticz App? It just gives me the sad face Oops screen complaining that it can't reach the old address. I see no way to get to the Settings to change the IP address...
Lebo2d9
- Domoticz version: L stab
You can go to the setting menu with the botton on the left upper corner. Where you change between the dashboard, switches, ... the last item in the list are the settings
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
More to come
gcoupe
Nope - no button in the left upper corner here on Android One... The application doesn't work for me.Lebo2d9 wrote: Saturday 06 April 2019 18:50 You can go to the setting menu with the botton on the left upper corner. Where you change between the dashboard, switches, ... the last item in the list are the settings
Lebo2d9
These are my screenshots
More to come
More to come
gcoupe
And as you can see from my screenshot - there's NO Hamburger menu showing. It may be because the app is running on Android One, but whatever the cause, the app is currently unusable on my phone.
