Page 94 of 114
Posted: Friday 23 November 2018 10:51
by BarryT
Before i going to pay anything, i want to test it first with my system and google home, but how to do??
Is there a free (limited) or trail going on somewhere?
Connection works and it does see my devices..
Posted: Friday 23 November 2018 15:12
by Sopalin
Due to update in routines, i have notices that we can now trigger routines based on devices. Even if my devices are available routines won't see any of them.
Do you have any idea ?
**EDIT** looks like it's on the roadmap :
viewtopic.php?f=69&t=16670&p=196320&hil ... es#p196320
Posted: Saturday 24 November 2018 10:26
by thecosmicgate
Some special controlicz black Friday / cyber Monday deals ?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Posted: Saturday 24 November 2018 19:46
by m.versteegh
m.versteegh wrote: Tuesday 20 November 2018 19:44
Firewall question.... Which ports should I open for controllicz. I'm also doing geobased IP blocking, so which country should be allowed inbound access?
Solved by adding a rule to the firewall. Traffic from the UK is allowed
Is there a list of commands? THere is nothing in the FAQ. Also
https://assistant.google.com/explore/ only shows 3 commands.
Since we're asking questions....
Anyway to let google home talk (e.g. from a blocky or script. Eg.. window goes open, google says something)?
Posted: Saturday 24 November 2018 20:09
by Madgeni
Hi there -
here's a list of typical commands -
https://support.google.com/googlehome/a ... 3578?hl=en
Currently notifications aren't available - i've got the backend ready. It looks like Alexa might come along first.
Posted: Monday 26 November 2018 18:05
by romimmo79
Hello, I have a problem with controllicz e google home mini.
In controllicz when I do the test the result is " Success - your connection is working"" and in devices I see the same my devices in domoticz but when I ask to google home to turn on or off the lights the response is that there is a problem with controllicz. Can you help me???
Posted: Tuesday 27 November 2018 19:41
by rgroothuis
romimmo79 wrote: Monday 26 November 2018 18:05
I suddenly have the same problem. All was working fine, I could switch lights on and off through voice commands and now suddenly Google Home complains it cannot reach Controlicz! What has changed?
Posted: Tuesday 27 November 2018 20:30
by Madgeni
rgroothuis wrote: Tuesday 27 November 2018 19:41
Not good, Controlicz is up and working ok - PM me with your Controlicz ID, and i'll take a look
Posted: Tuesday 27 November 2018 20:35
by rgroothuis
I changed password in the Domoitcz user, updated the profile in Controlicz (password update), tested the connection and it was working again. So the problem is solved but strange that it ended up in this situation as I didn’t change anything.
Posted: Tuesday 27 November 2018 20:36
by rgroothuis
Madgeni wrote: Tuesday 27 November 2018 20:30
Thanks, see previous post, I was able to reolve it as described.
I also noticed you updated the error messages, well done, they look better as in the past
Posted: Tuesday 27 November 2018 20:52
by Madgeni
Great - glad it's ok
Posted: Sunday 02 December 2018 11:37
by Madgeni
All -
Selector Switches are now available, with some limitations - Currently it's only available in English, and Google have to hardcode the level names, and therefore only some levels are available in German. Other languages will be following shortly.
See Controlicz.com FAQs for more info - if there are other level names you want, please let me know, and i'll get Google to add them.
Syntax is "Hey google change the devicename mode to levelname"
Posted: Sunday 02 December 2018 22:36
by Pjedr
https:\\Controlicz.com down? Aha after about 10 minutes it is up again.
Posted: Sunday 02 December 2018 23:53
by Madgeni
Brief outage as I made some changes
Posted: Tuesday 04 December 2018 16:40
by Madgeni
Thermostat controls are now available in your Home app
Posted: Tuesday 04 December 2018 16:42
by Madgeni
Dutch selector switches should be available now also
Posted: Tuesday 04 December 2018 20:15
by marktn
Only switches are available, groups and scenes are not working.
It looks like that more then 32 switches is not possible.
Anybody else also these problems? Unfortunately no respond of the support anymore.
Posted: Tuesday 04 December 2018 20:18
by Madgeni
Hi there - sorry, your last email slipped through the net.
The limit is 100 devices I believe - Scenes and Groups should be fine, but don't show in the Home app yet.
Will go back through your email, and contact you with some steps
Posted: Tuesday 04 December 2018 21:12
by Madgeni
Re: Scenes - you can find them in your Home app - but you have to really look!
Tap on the "Account" option on the bottom right of the home screen > then select "Settings" > and then select "Home".
have updated FAQs
Posted: Thursday 06 December 2018 22:10
by BarryT
Did everybody with some troubles with controlicz also the 'hey google, update devices' first?
