Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
- Domoticz version: 2024.3
Re: Controlicz - Domoticz to Google Home/Assistant integration
Before i going to pay anything, i want to test it first with my system and google home, but how to do??
Is there a free (limited) or trail going on somewhere?
Connection works and it does see my devices..
Due to update in routines, i have notices that we can now trigger routines based on devices. Even if my devices are available routines won't see any of them.
Do you have any idea ?
**EDIT** looks like it's on the roadmap : viewtopic.php?f=69&t=16670&p=196320&hil ... es#p196320
- thecosmicgate
- Domoticz version: newest
Some special controlicz black Friday / cyber Monday deals ?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
It's nice to be important, but it's more important to be nice
Scooter ;)
Scooter ;)
Solved by adding a rule to the firewall. Traffic from the UK is allowedm.versteegh wrote: ↑Tuesday 20 November 2018 19:44 Firewall question.... Which ports should I open for controllicz. I'm also doing geobased IP blocking, so which country should be allowed inbound access?
Is there a list of commands? THere is nothing in the FAQ. Also https://assistant.google.com/explore/ only shows 3 commands.
Since we're asking questions....
Hi there -
here's a list of typical commands -
https://support.google.com/googlehome/a ... 3578?hl=en
Currently notifications aren't available - i've got the backend ready. It looks like Alexa might come along first.
Hello, I have a problem with controllicz e google home mini.
In controllicz when I do the test the result is " Success - your connection is working"" and in devices I see the same my devices in domoticz but when I ask to google home to turn on or off the lights the response is that there is a problem with controllicz. Can you help me???
I suddenly have the same problem. All was working fine, I could switch lights on and off through voice commands and now suddenly Google Home complains it cannot reach Controlicz! What has changed?romimmo79 wrote: ↑Monday 26 November 2018 18:05 Hello, I have a problem with controllicz e google home mini.
Not good, Controlicz is up and working ok - PM me with your Controlicz ID, and i'll take a lookrgroothuis wrote: ↑Tuesday 27 November 2018 19:41I suddenly have the same problem. All was working fine, I could switch lights on and off through voice commands and now suddenly Google Home complains it cannot reach Controlicz! What has changed?romimmo79 wrote: ↑Monday 26 November 2018 18:05 Hello, I have a problem with controllicz e google home mini.
I changed password in the Domoitcz user, updated the profile in Controlicz (password update), tested the connection and it was working again. So the problem is solved but strange that it ended up in this situation as I didn’t change anything.
Thanks, see previous post, I was able to reolve it as described.Madgeni wrote: ↑Tuesday 27 November 2018 20:30Not good, Controlicz is up and working ok - PM me with your Controlicz ID, and i'll take a lookrgroothuis wrote: ↑Tuesday 27 November 2018 19:41I suddenly have the same problem. All was working fine, I could switch lights on and off through voice commands and now suddenly Google Home complains it cannot reach Controlicz! What has changed?romimmo79 wrote: ↑Monday 26 November 2018 18:05 Hello, I have a problem with controllicz e google home mini.
In controllicz when I do the test the result is " Success - your connection is working"" and in devices I see the same my devices in domoticz but when I ask to google home to turn on or off the lights the response is that there is a problem with controllicz. Can you help me???![]()
I also noticed you updated the error messages, well done, they look better as in the past
Great - glad it's ok
All -
Selector Switches are now available, with some limitations - Currently it's only available in English, and Google have to hardcode the level names, and therefore only some levels are available in German. Other languages will be following shortly.
See Controlicz.com FAQs for more info - if there are other level names you want, please let me know, and i'll get Google to add them.
Syntax is "Hey google change the devicename mode to levelname"
https:\\Controlicz.com down? Aha after about 10 minutes it is up again.
Brief outage as I made some changes
Thermostat controls are now available in your Home app
Dutch selector switches should be available now also
Only switches are available, groups and scenes are not working.
It looks like that more then 32 switches is not possible.
Anybody else also these problems? Unfortunately no respond of the support anymore.
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
Hi there - sorry, your last email slipped through the net.
The limit is 100 devices I believe - Scenes and Groups should be fine, but don't show in the Home app yet.
Will go back through your email, and contact you with some steps
Re: Scenes - you can find them in your Home app - but you have to really look!
Tap on the "Account" option on the bottom right of the home screen > then select "Settings" > and then select "Home".
have updated FAQs
have updated FAQs
Did everybody with some troubles with controlicz also the 'hey google, update devices' first?
