Page 94 of 184
Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Wednesday 03 May 2017 8:14
by madrian
robgeerts wrote:
1.) download latest beta
2.) add following code to config.js:
The new animated weather icons are very cute.
BTW personally I haven't tried combined calendars, but separate calendars still not working.
columns[3]['blocks'] = [calendars.private, calendars.business];
Posted: Wednesday 03 May 2017 9:33
by poudenes
And Agenda items that repeats every time are not shown as well.
For the rest wonderful scripting. Keep up the good work
Posted: Wednesday 03 May 2017 9:35
by robgeerts
Did youtry
https://cors-anywhere.herokuapp.com/ instead of crosorigin.me in front of the calender-url?
Blueone wrote:I'm having some issues with the dashboard, after a while the dashboard reacts extremely slow and sometimes also doesn't exit the stand-by mode or also very slowly (looks like it is waiting for something). And sometimes when it end standby is shows only the background on a empty screen, I can swipe and am seeing the main screen but is goes back to the empty screen when I release the screen, a complete refresh is the only option in this case.
Do you have the latest version?
It should automatically reload after 30 minutes or so...
Teunissm wrote:is it posible in the latest beta version to add an rgb switch? I saw something about it?
Not yet finished
poudenes wrote:And Agenda items that repeats every time are not shown as well.
I know, you mentioned it a couple of times
Will look into this
Posted: Wednesday 03 May 2017 9:58
by poudenes
Will look into this
I'm sorry.
there lots of posts and try to help. Did someone also have trouble with multiple screens in Beta? When its loaded i can't switch. Have to resize the browser first or change from full screen to normal and back on tablet before i can use the dots to switch.
Posted: Wednesday 03 May 2017 10:14
by robgeerts
b00n wrote:For the 2 hour time issue:
in ical_parser.js i changed:
var utcdatems = ConvertUTCTimeToLocalTime(Date.UTC(dtutc.year, (dtutc.month-1), dtutc.day, dtutc.hour, dtutc.minute));
to
var utcdatems = Date.UTC(dtutc.year, (dtutc.month-1), dtutc.day, dtutc.hour, dtutc.minute);
and the time issue is gone
(last beta)
Ok just tested with this.
But, the problem I have is the when I use the last line of code you mentioned, I got most items right, but some items,created by someone else in shared calendar is still 2 hours off...
Posted: Wednesday 03 May 2017 10:18
by Blueone
Using the last version, sometimes is also happens already after 5 minutes or so. I also notice it in the setpoint setting, when I change it could take a while before it refreshed while sometimes it is working perfect. So I think one piece of code or call is causing this issue which delays the rest. But is quite hard to debug, so tips to debug are welcome. Maybe I can also disable the block one by one to see if I can pin-point it.
Posted: Wednesday 03 May 2017 10:48
by gielie
koowee wrote:SuperMouse wrote:But how to get the lastudate working?
Do I need to add this in blocks ? like:
blocks[121] = {}
blocks[121]['lastupdate'] = true
How did you do this?
You need to enable _SHOW_LASTUPDATE variable
And if you want to hide last update data from some device, then you need to add this kind of block
blocks[idx]['hide_lastupdate'] = true;
Thats really inconvenient, would it be more easy to make a show_lastupdate for the idx you want instead of the one you don't want.
@Rob Is this something you can put on your todo list?
Posted: Wednesday 03 May 2017 10:52
by robgeerts
Added to my list..
Posted: Wednesday 03 May 2017 10:57
by robgeerts
Link on multiple calendars
In latest beta it is possible to add a click-function to the calendar-block.
var calendars = {}
calendars.wedevise = { icalurl: 'http://urlto.com/basic.ics' }
calendars.private = { icalurl: 'http://urlto.com/basic.ics' }
calendars.combined = {}
calendars.combined.calendars = [
{ color:'white',calendar:calendars.wedevise },
{ color:'#ccc',calendar:calendars.private }
calendars.combined.url = 'https://linktocalendar.com';
WARNING: if you already used combined calendars, change it to the code above, with or without the url part ('calendars' in varname has been added)
Posted: Wednesday 03 May 2017 10:58
by bimse
I can see that the 'Security pane' has been added, how is this used?
Is it possible to add a timer function to the radio so it can be used as a clock radio. Possibly ruled in lua.
Posted: Wednesday 03 May 2017 11:06
by poudenes
Maybe a idea to put all functions on the
http://www.domoticz.com/wiki/Dashticz-v2 site?
Or at least whats in the production version is added.
robgeerts wrote:Link on multiple calendars
var calendars = {}
Posted: Wednesday 03 May 2017 11:32
by Blueone
Oke, I think i found the cause with the timeline in debugging mode. I appears is't waiting very long for some images from nu.nl or something, an example.
- 2017-05-03 11_24_32-Dashticz.png (4.75 KiB) Viewed 2877 times
http://sat.sanoma.fi/sat/sat.gif?log=1& ... 53&ctz=120
It is loading this every 10seconds (when refreshing the dashboard) while I don't have an active iframe with this info in it, only a button which directs to nu.nl (nu.nl is part of sanoma). It is also doing this in a syncronous job, so the json calls are waiting for this. I think there are two issues/improvements here:
- it is loading all the external information every 10 seconds while the buttons aren't open on the screen
- External information is loaded synchronously and the json call are waiting for it, maybe external information can be loaded async to inprove the user experience?
I hope you can do something with this information, thanks in advance!
. And if you need extra debug information, please let me know
BTW, I think some of the external images which are requested by nu.nl are blocked by piHole, will check that this evening, but it shouldn't interfere the working of the dashboard.
Posted: Wednesday 03 May 2017 11:54
by madrian
Did youtry
[/quote]
Yep, because crossorigin.me not worked in the morning. Only one calendar works at the same time.
Posted: Wednesday 03 May 2017 12:41
by crashingdutchman
It seems that after the Standby period triggers my screen is now completely black instead of dimmed. I didn't find a settings for this. Anyone else seeing this too?
Posted: Wednesday 03 May 2017 13:35
by rbo0567
crashingdutchman wrote:It seems that after the Standby period triggers my screen is now completely black instead of dimmed. I didn't find a settings for this. Anyone else seeing this too?
Yep. Same here.
Posted: Wednesday 03 May 2017 14:03
by robgeerts
Not over here, could you send me your config.js (without credentials).
Do you have the latest version and cleared cache?
Posted: Wednesday 03 May 2017 14:07
by robgeerts
poudenes wrote:Maybe a idea to put all functions on the
var calendars = {}
Added
http://www.domoticz.com/wiki/Dashticz_V ... tomization
Posted: Wednesday 03 May 2017 14:30
by robgeerts
gielie wrote:koowee wrote:SuperMouse wrote:But how to get the lastudate working?
blocks[121] = {}
In latest beta it is possible to have:
var _SHOW_LASTUPDATE = false;
var blocks = {}
blocks[233] = {}
blocks[233]['show_lastupdate'] = true;
Posted: Wednesday 03 May 2017 14:35
by SwordFish
I have one calendar, but after the last beta update it isn't working anymore?
I did put in the code for combined calendars en without but the calendar isn't showing
Posted: Wednesday 03 May 2017 14:44
by woody4165
robgeerts wrote:
Will check out the graph height later. According the news-bug, this is fixed in next beta (not available yet).
In the meantime, open main.js, find:
myswiper = new Swiper('.swiper-container', {
pagination: '.swiper-pagination',
paginationClickable: true,
loop: true,
effect: _SCREENSLIDER_EFFECT,
keyboardControl:true
AND change to:
loop: false,
(looping the slides gives too much headaches
Hi @robgeerts
just tried, but no changes on second page...
