yes i try but o don't know if the variable is off when the door is close or "close"
- Catturablock.PNG (89.01 KiB) Viewed 4538 times
The same question for me too man!! But I have seen so many people http://www.domoticz.com/forum/viewtopic ... 4&start=20 opting for Neato XV Pro because of easy monitoring with domoticz and the communication speed.DasK wrote: Wednesday 18 May 2016 14:06 Any news? Is it possible to control Xiaomi devices with Domoticz? It would be great
What about the Xiaomi???
Oleg
at me the square device was defined incorrectly - temperature and humidity have identical ID and pressure of another with type "general". Also, the battery level is not displayedmartijnm wrote: Sunday 03 September 2017 15:57 I believe they are the same except for a different brandname (Aqara vs. Xiaomi)
chatainsim
- Domoticz version: v4.11307
Events -> Lua, device:matteos1 wrote: Monday 04 September 2017 22:01 i'de like to create a scene where when i close a door with xiaomi door sensor one light is on and when the door is open light is off.
how i can i make it possible??
thank you
if (devicechanged['Door'] == 'Closed' and otherdevices['Xiaomi RGB Gateway'] == 'Off') then
commandArray['Xiaomi RGB Gateway']='On'
elseif (devicechanged['Door'] == 'Open' and otherdevices['Xiaomi RGB Gateway'] == 'On') then
commandArray['Xiaomi RGB Gateway']='Off'
return commandArrayRe: Xiaomi Smart Home Suite (very cheap) compatibilty?
hy thank youchatainsim wrote: Tuesday 05 September 2017 15:39Events -> Lua, device:matteos1 wrote: Monday 04 September 2017 22:01 i'de like to create a scene where when i close a door with xiaomi door sensor one light is on and when the door is open light is off.
thank youCode: Select all
commandArray = {} if (devicechanged['Door'] == 'Closed' and otherdevices['Xiaomi RGB Gateway'] == 'Off') then commandArray['Xiaomi RGB Gateway']='On' elseif (devicechanged['Door'] == 'Open' and otherdevices['Xiaomi RGB Gateway'] == 'On') then commandArray['Xiaomi RGB Gateway']='Off' end return commandArray
could see this picture and transform in lua?
chatainsim
It's too small to read text.matteos1 wrote: Tuesday 05 September 2017 16:38hy thank youchatainsim wrote: Tuesday 05 September 2017 15:39Events -> Lua, device:matteos1 wrote: Monday 04 September 2017 22:01 i'de like to create a scene where when i close a door with xiaomi door sensor one light is on and when the door is open light is off.
deennoo
Have a look to https://github.com/rytilahti/python-mirobosam329 wrote:The same question for me too man!! But I have seen so many people http://www.domoticz.com/forum/viewtopic ... 4&start=20 opting for Neato XV Pro because of easy monitoring with domoticz and the communication speed.DasK wrote: Wednesday 18 May 2016 14:06 Any news? Is it possible to control Xiaomi devices with Domoticz? It would be great
That tje n'est python lib to drive Xiaomi wifi device, dev are working hard and add new device/function every day. I manage to drive my Xiaomi Philips ball led with this.
Python plugin for robot vaccum use the same lib (an older version) his way to run looks the best one, just need to be adapted for other device.
http://domo-attitude.fr
i think is better
chatainsim wrote: Tuesday 05 September 2017 17:14It's too small to read text.matteos1 wrote: Tuesday 05 September 2017 16:38hy thank youchatainsim wrote: Tuesday 05 September 2017 15:39
Events -> Lua, device:Code: Select all
chatainsim
why don't you try to translate to lua then ask for help if you are stuck ?matteos1 wrote: Tuesday 05 September 2017 19:18 Cattura.PNG
i think is better
hy thank you
LeonvA
I've got it to work.deennoo wrote: Monday 04 September 2017 17:15What is you Fw version please ?LeonvA wrote:Hello,
I have bought a Xiaomi gateway in China last week but it doesn't connect to Domoticz.
I can control the gateway and read the status of my temperature sensor in the Mi Home app.
I've enabled LAN Communication protocol in the Mi Home app and wrote down the password.
Then I added the new hardware in Domoticz with correct IP address, port 9898 and the correct password.
But then I can't see any new devices in the devices tab.
I've also tried it on a new installed raspberry pi with domoticz on a stand alone network but also no result.
anyone who can help me?
Thanks,
Leon
I used an older version of the mi home app and now it works.
chatainsim
It's not because I don't want to help, It's because it's the best way you to learn lua
I'
Yes i know but only this timechatainsim wrote:It's not because I don't want to help, It's because it's the best way you to learn lua
I'
ratjenl
Well i finally received my Xiaomi gateway and added it to domoticz.
I also ordered two door/windows sensors to use it as an alarm. With the mii home app it works very well and when i put the alarm "on" it immediatly plays sound from the gateway. Is there also a way to use these sensors inside domoticz so they send the alarm to the gateway ? I tried searching google and this forum but can't find what i am looking for. Is there anybody that can help me/point me in the good direction ?
thnx
thnx
pvm
- Domoticz version: 4.10538
ratjenl
Do you have these devices available in Domoticz? Then you should be able to play a sound using blockly, some instructions on https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
Did you see those? Does that help you?
I just added a few zigbee power sockets to my setup, they are working fine and reporting power, on my utility graph I only see power usage and energy usage, apart from an odd "spike" on energy usage it seems to report "0", is anyone else experiencing this?
I just did a test with it set to "computed" and I now see results in the "Energy Usage", is it possible to have these devices set to computed when they are created by the plugin?
Stanleyk
I add yesterday xiaomi home to domoticz and working well. I have gateway, 5xdoor contact, 1xbutton, 2x motion sensor. and also 2x IR transmitter but this I dont see in domoticz. have anybody this working ? In MiHome aplication is working TV, AC, HomeTeather. But MiHome fo IR is in Chinese language
I am waiting for wall switches, light bulb and thermometers.
How I can control the classic lights ? Have somebody any relays what is definitely working (433 or wifi) ?
DannyElfman
- Domoticz version: 3.8136
Does anybody know if the Xiaomi Aqara flood sensors are working with one of the latest Domoticz beta build ?
I cannot find anything on github ( https://github.com/domoticz/domoticz/co ... ateway.cpp )
Debian Jessie VM on EsxI on a Gen 8 Proliant + RFXCom + AeonLabs Zwave+ + Fibaro eye + Fibaro Smoke + Fibaro FGS211 Philips Hue + Harmony Hub + Somfy RTS + Oregon Temp sensors + Xiaomi Gateway + Xiaomi sensors + Sonoff basic
Coldman
DannyElfman wrote: Thursday 07 September 2017 10:02 Hi,
corbin wrote: Sunday 03 September 2017 11:30I could add it the same as the smoke alarm no problem, but hoping someone can suggest a more appropriate device.Martins80 wrote: Saturday 02 September 2017 13:44I think there is support for smoke alarm and gas alarm, i think this is the same, but water alarmmarcotini wrote: Saturday 02 September 2017 8:45 I don't know if there is one in Domoticz. It's just a water presence so I think that just 1 or 0 it's ok lol.
