Page 93 of 120
Re: Domoticz app 2.0
Posted: Wednesday 07 November 2018 11:45
by galadril
Next to drag/drop sorting, im also working on another nice visual:
Posted: Monday 26 November 2018 22:46
by Geitje
I use newest beta domoticz on Rpi 3B and newest Domoticz app on my Oneplus 6 with newest stock ROM Android Pie.
For some reason the phone does not wake up for notifications. I used this feature a lot to notify me when someone enters the frontyard when I am busy in the backyard. When I wake my phone myself, the notifications of domoticz come through. I tried lot of settings on my phone: 1: Domoticz app is locked in app drawer, 2: Of course notifications are allowed 3: Battery optimalisation is off for Domoticz app. 4: No data limitations for Domoticz app.
Others apps are able to wake up my device to give instant notifications.
Hope there is a solution for this!
Posted: Wednesday 28 November 2018 17:29
by miecio08
Hello. I use Xiaomi gateway, domotic and synology. I have a problem with temperature sensors. one sensor is outside and as is the negative temperature hangs the application on the android. Do you have any ideas?
Wysłane z mojego SM-N950F przy użyciu Tapatalka
Posted: Thursday 29 November 2018 21:56
by Geitje
I found a temproary solution: disable deep idle and deep sleep completely. This is done via ADB on a laptop. Sie instructions this post https://forums.androidcentral.com/showt ... ost6347918. I works for me. When my phone is rebooted settings are back to normal.
Geitje wrote: Monday 26 November 2018 22:46 I use newest beta domoticz on Rpi 3B and newest Domoticz app on my Oneplus 6 with newest stock ROM Android Pie.
For some reason the phone does not wake up for notifications. I used this feature a lot to notify me when someone enters the frontyard when I am busy in the backyard. When I wake my phone myself, the notifications of domoticz come through....
Posted: Saturday 01 December 2018 12:29
by cogliostrio
I have a request.
I use the Plans feature a lot, and for me this is the fastest way of getting an overview. Could we have a button for Plans on the dashboard?
Something like this perhaps?
Posted: Saturday 01 December 2018 12:41
by MarcelMAH
I would like the buttons at the bottom te be able to be customized to my own preferences.
Posted: Tuesday 04 December 2018 11:38
by C4rtm4N
Are there any plans to allow authentication by certificate? I'd like to be able to use the app whilst I'm out but don't fancy opening ports for all to try. Currently I use NGINX as a reverse proxy & the app doesn't see to support this.
Posted: Saturday 08 December 2018 20:50
by thecosmicgate
Where did the search option go ?
I've got a.lot of switches and when I had to scroll between them it takes a lot of extra time ;)
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Posted: Sunday 09 December 2018 8:46
by sailmich
Any chance to get an answer to my previous post from October?
Nothing changed since my post.
Post Friday 26 October 2018 6:55
I'm on the beta. Since last update the status bar and the home/back/last apps buttons are always visible. Is that a feature or a bug? The sliders of blinds are not visible when blinds are closed or open, could you make them visible at any time again. Any chance to get arrows or up and down for blinds?
Posted: Monday 10 December 2018 21:40
by marktn
After clicking on a scene/group i have a error
"time out, com.android.volley.timeouterror"
Automatic refresh is on.
After closing and opening the app, everthing works fine again.
Posted: Sunday 16 December 2018 22:42
by marmachine
miecio08 wrote: Wednesday 28 November 2018 17:29 Hello. I use Xiaomi gateway, domotic and synology. I have a problem with temperature sensors. one sensor is outside and as is the negative temperature hangs the application on the android. Do you have any ideas?
My best guess is: your sensor produces rubbish :roll: what sensor do you have?
Posted: Sunday 30 December 2018 18:10
by Brutus
galadril wrote: Monday 27 March 2017 21:07
svenker wrote:HI didn't check but I would imagine that the Gear S3 is by far the most sold Smartwatch around, I imagine that the Domoticz Team is working on the Tizen OS ?
I don't have any plans at this moment (don't own one either).
I did implement Android Wear OS
Still no plans in this? I want the new Galaxy Watch 46mm but also runs Tizen.
Greetings.
Posted: Monday 31 December 2018 18:54
by flakpyro
wizzard72 wrote: Friday 02 November 2018 23:55 I'm on version 0.2.25 (4912) and the doorlock button has the wrong state:
The Status of the lock is Unlocked, but the switch button is enabled. If the lock has the status locked, the switch button is enabled (which is expected). With the lock unlocked the switch button state should be disabled.
Can this be solved?
I have this same issue with my Z-wave lock and the app. Works fine from the web interface.
Posted: Saturday 05 January 2019 13:46
by wizzard72
Can this be solved?
Any update on this?
Posted: Tuesday 15 January 2019 21:25
by sailmich
I'm on beta app. Newest update at Startscreen I have set plans. At left side there is no option to select plans! When I changed e.g. to switches afterward no possibility to go back for plans. I have to go in settings first and go into startscreen after that I get my plans back.
Posted: Wednesday 16 January 2019 22:27
by atlej
The latest version of the app seems to restrict my rights to flip switches??
-"you do not have the rights for this action!"
akward as my geofence fails from time to time, now I am unable to manually turn off the alarm switch??
works as before on the web-interface.
Atle
Samsung 7 android 8.0.0
Re: Domoticz app 2.0 Remote settings
Posted: Friday 18 January 2019 0:25
by RoboInfo
Hi, I think the app works great and has a nice feeling. However can anyone tell me if it's easy or even possible to use the App outside your private network. I cannot figure out how to set the settings so that the App can connect to my IP. I search on keywords like remote and external etc. but can not find anything how to do this except for a solution to create a client and all kind of magic.
I finally had another app going but I like this one better.
Posted: Saturday 19 January 2019 16:35
by BertB
atlej wrote: Wednesday 16 January 2019 22:27 The latest version of the app seems to restrict my rights to flip switches??
Atle
I have exactly the same problem, without using geofencing.
has it been solved yet?
Posted: Saturday 19 January 2019 17:21
by wizzard72
wizzard72 wrote: Saturday 05 January 2019 13:46
Can this be solved?
Any update on this?
Updated the app today mentioning that the doorlock issue is solved. But it's not solved for me, still the same behavior.
Posted: Saturday 19 January 2019 19:56
by atlej
BertB wrote: Saturday 19 January 2019 16:35
Atle
Deleting app buffer and data and then configure again solves it temporary for me. If I try to add a Geofence the app crashes, and the problem is back.
Notified app author on email. Since last configuration it has ben stable for 24hour ( without gefofence...)
Atle
