Locked
SwordFish
Domoticz version: V4.11375
Re: Dashticz v2.0, custom positioning and multiple screens
Post by SwordFish »
mvveelen wrote:
robgeerts wrote: Noticed this too when I was busy fixing some thing with calenders (right now), so will fix this too!
Good to know that I'm not the only one :)
I've changed the 'garbage script' a bit. Made a text-utility instead of the selector-switch and altered the code. Testing in full progress, but this is what it looks like now:
Nice work, will you share you're code when done :)
lukev
Post by lukev »
Is there a way to put the traffic map also in the same borders as the rest of the buttons (with the darker background and round corners)?
Now it looks a bit off...
mvveelen
Post by mvveelen »
SwordFish wrote: Nice work, will you share you're code when done :)
I'm not a coder, I just changed the original code a bit and I'm far from finished. At least this week's result (GFT) is OK.
So, I made a virtual (TEXT) switch and use the IDX in the code: https://pastebin.com/EqWBusBK
Did I already mention I'm NOT a coder :mrgreen: ?
edit: this is the code I'm using at the moment. Updated 22:31
SwordFish
Post by SwordFish »
Thanks, will try it tomorrow :P
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Multiple calender in ONE
1.) download latest beta
2.) add following code to config.js:
var calendars = {}
calendars.wedevise = { icalurl: 'https://calendar.google.com/basic.ics' }
calendars.private = { icalurl: 'https://calendar.google.com/basic2.ics' }
calendars.combined = [{ color:'red',calendar:calendars.wedevise}, {color:'#65FC32','calendar':calendars.private }]
and define in block as:
columns[3]['blocks'] = [calendars.combined]
Oh and if crossorigin.me isnt working, try https://cors-anywhere.herokuapp.com/, for example:
calendars.private = { icalurl: 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/basic2.ics' }
EdwinK
Post by EdwinK »
mvveelen wrote:[
Looks real nice.
poudenes
Domoticz version: 3.8993
Post by poudenes »
Did the update. I found out that the schedule moments not shown where repeated moments. The schedule moment i filled in for 1 time are showing. So when you have a schedule moment that will repeat every week. This one is not visible.
robgeerts wrote:Multiple calender in ONE
var calendars = {}
clubeddie
Post by clubeddie »
So, I made a virtual (TEXT) switch and use the IDX in the code: https://pastebin.com/UNQbfTME
It is a funny addon. +1 for who it put it in the wiki.
Too bad that the order for the garbage pickup changes to often in my city. Especially at holiday or partydays.
But this is definitily coming in my dashboard. If i had the time to get started with it ;)
gielie
Domoticz version: latest β
Post by gielie »
I'd really like to see you garbage code, this text idea looks great.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
mvveelen
Post by mvveelen »
The code is updated and a lot shorter: https://pastebin.com/MhiYmBd9
EdwinK
Post by EdwinK »
At least you are more of a coder then me.
mvveelen
Post by mvveelen »
EdKo66 wrote: At least you are more of a coder then me.
:D
Cleaned it up a bit, and this is the latest: https://pastebin.com/MhiYmBd9
If I see any errors in the next weeks, I'll update the code. For now: thanks to the original coder and I hope this new version can help others.
EdwinK
Post by EdwinK »
:D
Changing again ;)
robgeerts
Post by robgeerts »
lukev wrote:Is there a way to put the traffic map also in the same borders as the rest of the buttons (with the darker background and round corners)?
Try latest beta!
EdwinK
Post by EdwinK »
Try latest beta!
You never stop, do you ;)
robgeerts
Post by robgeerts »
EdKo66 wrote:You never stop, do you ;)
No ;)
THEMES SUPPORT IN BETA!
If you are a css-coder and creative you can send me themes I can add to Dashticz so other users can use it.
(Maybe, if there are coming more and more themes, we can have a separate topic for this ;)
In config.js, add:
var _THEME = 'white';
This is a simple sample (hihi) but you can do a lot more.
You can still use custom.css to override some stuff in a theme.
If you want to create a theme, add a new folder to the themes-folder and when done, send it to me or the Github-repository!
Teunissm
Domoticz version: V3.5858
Post by Teunissm »
is it posible in the latest beta version to add an rgb switch? I saw something about it?
koowee
Post by koowee »
SuperMouse wrote:But how to get the lastudate working?
Do I need to add this in blocks ? like:
blocks[121] = {}
blocks[121]['lastupdate'] = true
How did you do this?
You need to enable _SHOW_LASTUPDATE variable
var _SHOW_LASTUPDATE = true;
And if you want to hide last update data from some device, then you need to add this kind of block
blocks[idx]['hide_lastupdate'] = true;
lukev
Post by lukev »
robgeerts wrote:
Try latest beta!
Gonna try, thanks!
Blueone
Post by Blueone »
I'm having some issues with the dashboard, after a while the dashboard reacts extremely slow and sometimes also doesn't exit the stand-by mode or also very slowly (looks like it is waiting for something). And sometimes when it end standby is shows only the background on a empty screen, I can swipe and am seeing the main screen but is goes back to the empty screen when I release the screen, a complete refresh is the only option in this case.
The console doesn't show strange items, only some error from components like nu.nl. Do you have some tips to debug such performance issues?
Locked
