There is an issue with the rgb dialog, it's on my list to fix thankssalvacalatayud wrote: Sunday 21 October 2018 22:59 In new version milight can't change to warm white like in old version.
- galadril
- Domoticz version: latest
Re: Domoticz app 2.0
salvacalatayud
Enviado desde mi Redmi 4X mediante Tapatalkgaladril wrote:There is an issue with the rgb dialog, it's on my list to fix thankssalvacalatayud wrote: Sunday 21 October 2018 22:59 In new version milight can't change to warm white like in old version.
Last edited by salvacalatayud on Monday 22 October 2018 13:42, edited 1 time in total.
Persisto
- Domoticz version: 2.4386
I have the same problem. Note that the shortcut on the bottom of the screen (I had never even noted them before. "Switches" are represented by what is usually an Android flashlight) does work and gets you to the Switches screen. (I'm using the App in French, but I doubt that makes a difference.)EddyG wrote: Monday 22 October 2018 10:56 I am on version 0.2.8 (4831), Android 8.1.0 on Xiaomi A2 64Gb
It works fine a few App versions before.
I am not able to select the Switches anymore. It always shows the Dashboard.
I did clear the cache.
Raspberry III/Samsung A5
Plailly France
X10 Marmitek + Ebode for lights and blinds + CM15
mochad
Domoticz, Domoticz Lite, Geofence
Raspberry Pi III
mochad
Raspberry Pi III
Bigted
- Domoticz version: 2020.1
Any reason why we can't select Scenes as the startup screen now, requires an extra button press to move to scenes which if 95% of my use of the app?
- galadril
The start screen was for the different pages in the side navigation, but now some of the screens are moved to actually one page (with a bottom navigation). So you can at this moment set that one page as the startup.Bigted wrote: Monday 22 October 2018 20:47 Any reason why we can't select Scenes as the startup screen now, requires an extra button press to move to scenes which if 95% of my use of the app?
ill see if i can improve this
Tnx, that works, but the flashlight icon is very confusing.Persisto wrote: Monday 22 October 2018 20:23I have the same problem. Note that the shortcut on the bottom of the screen (I had never even noted them before. "Switches" are represented by what is usually an Android flashlight) does work and gets you to the Switches screen. (I'm using the App in French, but I doubt that makes a difference.)EddyG wrote: Monday 22 October 2018 10:56 I am on version 0.2.8 (4831), Android 8.1.0 on Xiaomi A2 64Gb
But still I am not able to select the switches as my default startup screen.
- galadril
Is fixed in the next releaseEddyG wrote: Tuesday 23 October 2018 9:03 But still I am not able to select the switches as my default startup screen.![]()
- galadril
The fix should be already in the play storeEddyG wrote: Tuesday 23 October 2018 9:03 Tnx, that works, but the flashlight icon is very confusing.
Tnx, perfect it works.
Minor thing, if there is time for a better "Switch" icon it would be nice.
Switches are not only light bulbs, hence the flashlight?
And it would be nice to have the camera's selected from the bottom line.
wizzard72
I thought it was solved, but after 2 updates of the app the switch button is not consistently with the status. In other words: lock has the status unlocked but the button is enabled, while the button has to be disabled.galadril wrote: Tuesday 16 October 2018 20:44This is fixed in the next releasewizzard72 wrote: Thursday 11 October 2018 21:56I have the same.bjacobse wrote: Tuesday 25 September 2018 22:19 hi I have a paid domoticz app for Android, currently it's version 0.1.476 (4316). Phone: Nokia 5
And when I have in my domotics RPI server Version: 4.9700. in switched, set the door lock to the "Switch Type: Door lock" Then as I expect the icon on my phone is there, and I can open and lock the device by tapping on the icon.
however my lock needs to be inverted, but if I set "Switch Type: Door lock Inverted" the icon disappeared from my phone app, so it's not possible for me to click and open or lock the device?
In the Android App the Status of the lock is either Locked or Unlocked that is good. But the lock had also a switch but the switch is always switched "On"
sailmich
I'm on the beta. Since last update the status bar and the home/back/last apps buttons are always visible. Is that a feature or a bug? The sliders of blinds are not visible when blinds are closed or open, could you make them visible at any time again. Any chance to get arrows or up and down for blinds?
NiklasO
- Target OS: -
Done. I still see three "niklas".galadril wrote: Saturday 20 October 2018 11:52Yes it should only show one niklas..NiklasO wrote: Thursday 18 October 2018 15:12 It shows my name three times. Should be max one niklas?
Can you test if this is maybe an update/old settings issue? So clear all app cache/data and reconfigure the connection?
Think that that should solve this issue
I did not use the users part of Domoticz. Before, I used the website protection (as niklas) for everything. Now when I have different services accessing domoticz I have changed from basic auth to login page. The user in website protection is changed to another username (from niklas) just for backup (not used). niklas and the other users are now added in the user management from settings.
Lebo2d9
- Domoticz version: L stab
Hi, i have a honywell evohome system. When i set the temperature with the app. The change is permanent. I can't set a time to go back to the normal temp
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
More to come
- galadril
Work in progress, some of you requested custom dashboard sorting:
NiklasO
- Target OS: -
NiklasO wrote: Sunday 28 October 2018 14:49Done. I still see three "niklas".galadril wrote: Saturday 20 October 2018 11:52Yes it should only show one niklas..NiklasO wrote: Thursday 18 October 2018 15:12 It shows my name three times. Should be max one niklas?
Dark theme need some small adjustments. Where does it get the users from?
martk
Thanks for the great updates lately, but can you please fix one issue?
After every major updates all widgets are dead. It's very, really very annoying, not only do I need to remove all widgets and put new ones on my android desktop, but I also need to do this to my wife's phone.
Mine always comes first (beta).
This is an issue since widgets are available, they are all messed up and showing strange texts after a major update during night updates.
- galadril
I'm really sorry on the widgetsmartk wrote: Wednesday 31 October 2018 21:29 After every major updates all widgets are dead. It's very, really very annoying, not only do I need to remove all widgets and put new ones on my android desktop, but I also need to do this to my wife's phone.
The code is on github, so any help on this issue is appreciated
- galadril
Point noted, ill look into this
wizzard72
I'm on version 0.2.25 (4912) and the doorlock button has the wrong state:
The Status of the lock is Unlocked, but the switch button is enabled. If the lock has the status locked, the switch button is enabled (which is expected). With the lock unlocked the switch button state should be disabled.
Can this be solved?
Can this be solved?
- galadril
Should be fixed in this commit
https://github.com/domoticz/domoticz-an ... 1f1c7f604a
(dont know when it's released in the app store.. still needs quite some work on the beta version)
