Locked
qwerk
Re: Dashticz v2.0, custom positioning and multiple screens
Post by qwerk »
woody4165 wrote:Another question about calendar events
I see that I need to use crossorigin.me before the calendar ics url.
What about privacy policy of this service, since I'm providing a private calendar url ?
I haven't found anything on their website?
My ICS/caldav is only reachable on the inside of the network. so crossorigin is not possible there.
Any other thoughts? can i run my own crossorigin daemon?
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
poudenes wrote:
I'm using now the iCal function and see something strange. I have multiple items on 1 day. Its only showing the 1st item on a day and then select the next one on other day etc. Does the script not supporting multiple agenda items on same day?
Just tested this in latest version and I see 2 events on 1 day..
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hmm.. ok :) now i don't see anything anymore.
var calendars = {}
calendars.werk = { title: 'Werk', icalurl: 'https://crossorigin.me/https://p28-calendars.icloud.com/published/2/LALALALA
columns[10] = {}
columns[10]['blocks'] = ['clock','sunrise',buttons.calendar,buttons.moon,219,231,232,233,calendars.werk];
columns[10]['width'] = 2;
koowee
Post by koowee »
woody4165 wrote:I have some temperature block, but I would like to show only temp and no humidity. In this case I can't activate the temp graph. Is there a way to show it up?
This is on Rob's ToDo-list
woody4165
Post by woody4165 »
Thanks @koowee
do you know if it's possible to reduce the graph block height?
bsmeding
Post by bsmeding »
SuperMouse wrote:
bsmeding,
Can you show me the custom.js ?
And maybe show the complete screen in :
Show your Dashticz v2.0 and how-to's!
https://www.domoticz.com/forum/viewtopi ... =8&t=17242
Hi @SuperMouse,
The code I used was the predefined code as Rob showed, my blockID of the user is 402:
function getBlock_402(device,idx){ //change 233 to the idx of your device!
   $('.block_'+idx).attr('onclick','switchDevice(this)');
   var html='';
   html+='<div class="col-xs-4 col-icon">';
      if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon');
      else html+=iconORimage(idx,'fa-toggle-on','','on icon');
   html+='</div>';
   html+='<div class="col-xs-8 col-data">';
   html+='<strong class="title">'+device['Name']+'</strong><br />';
   if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
   else html+='<span class="state">AANWEZIG</span>';
   html+='</div>';
   return html;
I will post the screens when they are finished some more ;-)
HansieNL
Post by HansieNL »
Hello all,
I changed iconORimage(idx,'fa-toggle-off','','off icon') to '<img src="img/cust_sleep.png" class="off icon" />'
It seems to work, but is this the correct way to change the image?
Blah blah blah
robgeerts
Post by robgeerts »
In wich file? custom.js?
If yes, then it's possible to do it like this :)
woody4165
Post by woody4165 »
mvveelen wrote:The news blocks are (on my dashboard) very large and show all news items in just 1 block. Is this a bug or is there something wrong with the way I have it set up?
Same issue here, I see a long block, with all the feeds
This is my code
blocks['news_1'] = {}
blocks['news_1']['feed'] = 'https://crossorigin.me/http://www.repubblica.it/rss/homepage/rss2.0.xml';
blocks['news_1']['height'] = 325;
robgeerts
Post by robgeerts »
On the first screen or the second/third/fourth?
woody4165
Post by woody4165 »
second screen, first column
working correctly on first screen, just tried
robgeerts
Post by robgeerts »
Could you test if it is working if you put it on the first screen??
HansieNL
Post by HansieNL »
robgeerts wrote:In wich file? custom.js?
Yes, in custom.js. This is the only way I know how to do it. The code is becoming to complex to understand for me. I'm not a real coder you know.
Blah blah blah
woody4165
Post by woody4165 »
robgeerts wrote:Could you test if it is working if you put it on the first screen??
Yes, working correctly on first screen
robgeerts
Post by robgeerts »
No problem :)
Ok, will fix this!
SuperMouse
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Post by SuperMouse »
robgeerts wrote:
SuperMouse wrote:Hi,
I have been looking around for an hour now, but I can not find how to change the font-size of 1 (text) device? I want my rain prediction smaller and all the others as they are.
Can anybody tell me how to do this? Is there also a way to put the text next to the cloud?
Not at my laptop right now but i thought every block has a unique identifier-classname like '.block233'... wich you can use in css. But if not (will check this out later) I will fix this ;)
Hi Rob,
I tried the classname like '.block233' but could not get it working. Can you do some magic on it?
robgeerts
Post by robgeerts »
I checked and every block has a class like:
block_233
So, using this would work:
.block_233 {
	font-size:120px !important;
	color:red !important;
Of course, change 233 to the idx of your choice ;)
EdwinK
Post by EdwinK »
Glad I'm not alone in being not a coder. Already happy that I could work with the 'aanwezig/afwezig'' thingy that Rob made for you. Now it's residing in custom.js, and I hope never to have to touch it again. Working on another script to do things proofs to difficult to me. I've put it on the request thiny, and hope it will one day work
woody4165
Post by woody4165 »
Ok, will fix this!
Thanks @robgeerts!
One question,if I can, is there a way to reduce the height of a graph?
madrian
Post by madrian »
You can run your own "crossorigin.me" proxy service.
Install node & npm:
curl -sL https://deb.nodesource.com/setup_7.x | sudo -E bash -
sudo apt-get install -y nodejs
sudo curl -L https://www.npmjs.com/install.sh | sh
https://github.com/technoboy10/crossorigin.me.git crossorigin
cd crossorigin
npm install
npm start
+you need to make a startup script
Locked
