First of all, thanks for helping out !
after a reboot it works fine for a while !!
When playing around with various commands the process crashes however after some time
pi@raspberrypi3:~$ cat /var/tmp/dtb.log.errors
/usr/bin/lua5.2: /home/pi/dtgbot/lua//dtgmenu.lua:696: attempt to index field '?' (a nil value)
stack traceback:
/home/pi/dtgbot/lua//dtgmenu.lua:696: in function 'handler'
/home/pi/dtgbot/dtgbot.lua:271: in function 'HandleCommand'
/home/pi/dtgbot/dtgbot.lua:460: in function 'on_msg_receive'
/home/pi/dtgbot/dtgbot.lua:554: in main chunk
[C]: in ?
Last portion of /var/tmp/dtb.log
2016-08-10 12:02:04 - Submenu item: (1) Woonkamer_(noord)
2016-08-10 12:02:04 - - Submenu item: (1) Woonkamer_(noord) (2) y (3) devices (4) 264 (5) 20.8°C - 62%
2016-08-10 12:02:04 - ==> start devinfo_from_name (1) 264 (2) Woonkamer (noord)
2016-08-10 12:02:04 - JSON request <
http://192.168.1.223:8080/json.htm?type=devices&rid=264>
2016-08-10 12:02:04 - device (1) Woonkamer (noord) (2) Woonkamer (noord) (3) 264 (4) 264
2016-08-10 12:02:04 - !!!! found device (1) Woonkamer (noord) (2) Woonkamer (noord) (3) 264 (4) 264
2016-08-10 12:02:04 - !!!! found device (1) Woonkamer (noord) (2) 264
2016-08-10 12:02:04 - --< devinfo_from_name: (1) 1 (2) 264 (3) Woonkamer (noord) (4) devices (5) Temp + Humidity (7) 20.8°C - 62%
2016-08-10 12:02:04 - *Woonkamer_licht|KaKu1_Woonkamer_voor - On|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|KaKu7_Woonkamer_dressoir - Off|Netatmo_Binnen - 47 dB|Netatmo_Binnen_() - nil|Onkyo_power - Off|Woonkamer_(noord) - 20.8°C - 62%|
2016-08-10 12:02:04 - Submenu item: (1) Woonkamer_(zuid)
2016-08-10 12:02:04 - - Submenu item: (1) Woonkamer_(zuid) (2) y (3) devices (4) 260 (5) 21.7°C - 59%
2016-08-10 12:02:04 - ==> start devinfo_from_name (1) 260 (2) Woonkamer (zuid)
http://192.168.1.223:8080/json.htm?type=devices&rid=260>
2016-08-10 12:02:04 - device (1) Woonkamer (zuid) (2) Woonkamer (zuid) (3) 260 (4) 260
2016-08-10 12:02:04 - !!!! found device (1) Woonkamer (zuid) (2) Woonkamer (zuid) (3) 260 (4) 260
2016-08-10 12:02:04 - !!!! found device (1) Woonkamer (zuid) (2) 260
2016-08-10 12:02:04 - --< devinfo_from_name: (1) 1 (2) 260 (3) Woonkamer (zuid) (4) devices (5) Temp + Humidity (7) 21.7°C - 59%
2016-08-10 12:02:04 - *Woonkamer_licht|KaKu1_Woonkamer_voor - On|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|KaKu7_Woonkamer_dressoir - Off|Netatmo_Binnen - 47 dB|Netatmo_Binnen_() - nil|Onkyo_power - Off|Woonkamer_(noord) - 20.8°C - 62%|Woonkamer_(zuid) - 21.7°C - 59%|
2016-08-10 12:02:04 - Submenu item: (1) licht_switch1
2016-08-10 12:02:04 - - Submenu item: (1) licht_switch1 (2) y (3) devices (4) 70 (5) Off
2016-08-10 12:02:04 - ==> start devinfo_from_name (1) 70 (2) woonkamer licht switch1
http://192.168.1.223:8080/json.htm?type=devices&rid=70>
2016-08-10 12:02:04 - device (1) woonkamer licht switch1 (2) woonkamer licht switch1 (3) 70 (4) 70
2016-08-10 12:02:04 - !!!! found device (1) woonkamer licht switch1 (2) woonkamer licht switch1 (3) 70 (4) 70
2016-08-10 12:02:04 - !!!! found device (1) woonkamer licht switch1 (2) 70
2016-08-10 12:02:04 - --< devinfo_from_name: (1) 1 (2) 70 (3) woonkamer licht switch1 (4) devices (5) Lighting 2 (6) On/Off (7) Off
2016-08-10 12:02:04 - *Woonkamer_licht|KaKu1_Woonkamer_voor - On|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|KaKu7_Woonkamer_dressoir - Off|Netatmo_Binnen - 47 dB|Netatmo_Binnen_() - nil|Onkyo_power - Off|Woonkamer_(noord) - 20.8°C - 62%|Woonkamer_(zuid) - 21.7°C - 59%|licht_switch1 - Off|
2016-08-10 12:02:04 - process buildmenu: (1) Off,On (2) w: (3) 8
2016-08-10 12:02:04 - -< buildmenu: (1) ["Off","On"]
2016-08-10 12:02:04 - |Onkyo_power - Off|Woonkamer_(noord) - 20.8°C - 62%|Woonkamer_(zuid) - 21.7°C - 59%|licht_switch1 - Off| (2) w: (3) 3
2016-08-10 12:02:04 - ","Onkyo_power - Off","Woonkamer_(noord) - 20.8°C - 62%"],["Woonkamer_(zuid) - 21.7°C - 59%","licht_switch1 - Off"]
2016-08-10 12:02:04 - process buildmenu: (1) menu (2) w: (3) 3
2016-08-10 12:02:04 - -< buildmenu: (1) ["menu"]
2016-08-10 12:02:04 - -< replymarkup:{"keyboard":[["Off","On"],["*Woonkamer_licht","KaKu1_Woonkamer_voor - On","KaKu3_Woonkamer_achter - Off"],["KaKu4_open_haard - Off","KaKu7_Woonkamer_dressoir - Off","Netatmo_Binnen - 47 dB"],["Netatmo_Binnen_() - nil","Onkyo_power - Off","Woonkamer_(noord) - 20.8°C - 62%"],["Woonkamer_(zuid) - 21.7°C - 59%","licht_switch1 - Off"],["menu"]],"selective":true,"resize_keyboard":true}
2016-08-10 12:02:04 - ==< Change KaKu1 Woonkamer voor => On
https://api.telegram.org/botxxx:keykey/ ... %3Atrue%7D
2016-08-10 12:02:04 - Message sent (1) 200
2016-08-10 12:02:04 - dtgbot: dtgmenu ended and text send ...return:200
2016-08-10 12:02:04 - Succesfully handled incoming request
.2016-08-10 12:02:10 - {"ok":true,"result":[{"update_id":783075445,
"message":{"message_id":671,"from":{"id":xxxxx,"first_name":"Han","last_name":"..","username":"Han_...."},"chat":{"id":1.....,"first_name":"Han","last_name":"...","username":"Han_.....","type":"private"},"date":1470823330,"text":"Off"}}]}
2016-08-10 12:02:10 - Message: 1
2016-08-10 12:02:10 - update_id (1) 783075445
2016-08-10 12:02:10 - TelegramBotOffset 783075446
2016-08-10 12:02:10 - JSON request <
http://192.168.1.223:8080/json.htm?type ... =783075446>
2016-08-10 12:02:10 - WhiteList: 1...
2016-08-10 12:02:10 - Handle command function started with Off and 1.
2016-08-10 12:02:10 - dtgbot: Start DTGMENU ... (1) Off
2016-08-10 12:02:10 - ==> menu.lua process:Off
2016-08-10 12:02:10 - => SendTo: (1) 1....
2016-08-10 12:02:10 - => commandline : (1) Off
2016-08-10 12:02:10 - => command : (1) Off
2016-08-10 12:02:10 - => param1 : (1)
2016-08-10 12:02:10 - => Lastmenu submenu : (1) menu
2016-08-10 12:02:10 - |Onkyo_power - Off|Woonkamer_(noord) - 20.8°C - 62%|Woonkamer_(zuid) - 21.7°C - 59%|licht_switch1 - Off|
2016-08-10 12:02:10 - => Lastmenu actions : (1) Off,On
2016-08-10 12:02:10 - => Lastcmd prompt : (1) false
2016-08-10 12:02:10 - => Lastcmd submenu: (1) woonkamer
2016-08-10 12:02:10 - => Lastcmd device : (1) KaKu1_Woonkamer_voor
2016-08-10 12:02:10 - ChkInTable: (1) Off,On
2016-08-10 12:02:10 - - ChkInTable not found: Off
2016-08-10 12:02:10 - ChkInTable: (1) menu
2016-08-10 12:02:10 - => cmdisaction : (1) true
2016-08-10 12:02:10 - => cmdisbutton : (1) false
2016-08-10 12:02:10 - => cmdissubmenu: (1) false
2016-08-10 12:02:10 - => devicename : (1) KaKu1_Woonkamer_voor
2016-08-10 12:02:10 - => realdevicename : (1) KaKu1 Woonkamer voor
2016-08-10 12:02:10 - => idx: (1) 27
2016-08-10 12:02:10 - => Type : (1) Lighting 1
2016-08-10 12:02:10 - => DeviceType : (1) devices
2016-08-10 12:02:10 - => SwitchType : (1) On/Off
2016-08-10 12:02:10 - => MaxDimLevel : (1) 0
2016-08-10 12:02:10 - ChkInTable: (1) off,open
http://192.168.1.223:8080/json.htm?type ... tchcmd=Off>
2016-08-10 12:02:10 - JSON feedback: (1) {
"status" : "OK",
"title" : "SwitchLight"
2016-08-10 12:02:10 - -< SwitchName: (1) KaKu1 Woonkamer voor (2) 27 (3) 200 (4) Change KaKu1 Woonkamer voor => Off
2016-08-10 12:02:10 - Start makereplymenu: (1) 1.... (2) devicemenu (3) woonkamer (4) KaKu1_Woonkamer_voor
2016-08-10 12:02:10 - -> makereplymenu Level: (1) devicemenu (2) submenu (3) woonkamer (4) devicename (5) KaKu1_Woonkamer_voor
2016-08-10 12:02:10 - submenu: woonkamer
2016-08-10 12:02:10 - Submenu item: (1) *Woonkamer_licht
2016-08-10 12:02:10 - - Submenu item: (1) *Woonkamer_licht (2) y (3) scenes (4) 3 (5)
2016-08-10 12:02:10 - --< devinfo_from_name: (1) 1 (2) 3 (3) Woonkamer licht (4) scenes (5) Group (6) Group (7)
2016-08-10 12:02:10 - *Woonkamer_licht|
2016-08-10 12:02:10 - Submenu item: (1) KaKu1_Woonkamer_voor
2016-08-10 12:02:10 - - Submenu item: (1) KaKu1_Woonkamer_voor (2) y (3) devices (4) 27 (5) Off
2016-08-10 12:02:10 - ==> start devinfo_from_name (1) 27 (2) KaKu1 Woonkamer voor
http://192.168.1.223:8080/json.htm?type=devices&rid=27>
2016-08-10 12:02:10 - device (1) KaKu1 Woonkamer voor (2) KaKu1 Woonkamer voor (3) 27 (4) 27
2016-08-10 12:02:10 - !!!! found device (1) KaKu1 Woonkamer voor (2) KaKu1 Woonkamer voor (3) 27 (4) 27
2016-08-10 12:02:10 - !!!! found device (1) KaKu1 Woonkamer voor (2) 27
2016-08-10 12:02:10 - --< devinfo_from_name: (1) 1 (2) 27 (3) KaKu1 Woonkamer voor (4) devices (5) Lighting 1 (6) On/Off (7) Off
2016-08-10 12:02:10 - *Woonkamer_licht|KaKu1_Woonkamer_voor - Off|
2016-08-10 12:02:10 - ---< (1) Lighting 1 (2) On/Off (3) using replymarkup: (4)
2016-08-10 12:02:10 - -< On/Off using replymarkup: (1) Off,On
2016-08-10 12:02:10 - Submenu item: (1) KaKu3_Woonkamer_achter
2016-08-10 12:02:10 - - Submenu item: (1) KaKu3_Woonkamer_achter (2) y (3) devices (4) 29 (5) Off
2016-08-10 12:02:10 - ==> start devinfo_from_name (1) 29 (2) KaKu3 Woonkamer achter
http://192.168.1.223:8080/json.htm?type=devices&rid=29>
2016-08-10 12:02:10 - device (1) KaKu3 Woonkamer achter (2) KaKu3 Woonkamer achter (3) 29 (4) 29
2016-08-10 12:02:10 - !!!! found device (1) KaKu3 Woonkamer achter (2) KaKu3 Woonkamer achter (3) 29 (4) 29
2016-08-10 12:02:10 - !!!! found device (1) KaKu3 Woonkamer achter (2) 29
2016-08-10 12:02:10 - --< devinfo_from_name: (1) 1 (2) 29 (3) KaKu3 Woonkamer achter (4) devices (5) Lighting 1 (6) On/Off (7) Off
2016-08-10 12:02:10 - *Woonkamer_licht|KaKu1_Woonkamer_voor - Off|KaKu3_Woonkamer_achter - Off|
2016-08-10 12:02:10 - Submenu item: (1) KaKu4_open_haard
2016-08-10 12:02:10 - - Submenu item: (1) KaKu4_open_haard (2) y (3) devices (4) 30 (5) Off
2016-08-10 12:02:10 - ==> start devinfo_from_name (1) 30 (2) KaKu4 open haard
http://192.168.1.223:8080/json.htm?type=devices&rid=30>
2016-08-10 12:02:10 - device (1) KaKu4 open haard (2) KaKu4 open haard (3) 30 (4) 30
2016-08-10 12:02:10 - !!!! found device (1) KaKu4 open haard (2) KaKu4 open haard (3) 30 (4) 30
2016-08-10 12:02:10 - !!!! found device (1) KaKu4 open haard (2) 30
2016-08-10 12:02:10 - --< devinfo_from_name: (1) 1 (2) 30 (3) KaKu4 open haard (4) devices (5) Lighting 1 (6) On/Off (7) Off
2016-08-10 12:02:10 - *Woonkamer_licht|KaKu1_Woonkamer_voor - Off|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|
2016-08-10 12:02:10 - Submenu item: (1) KaKu7_Woonkamer_dressoir
2016-08-10 12:02:10 - - Submenu item: (1) KaKu7_Woonkamer_dressoir (2) y (3) devices (4) 26 (5) Off
2016-08-10 12:02:10 - ==> start devinfo_from_name (1) 26 (2) KaKu7 Woonkamer dressoir
http://192.168.1.223:8080/json.htm?type=devices&rid=26>
2016-08-10 12:02:10 - device (1) KaKu7 Woonkamer dressoir (2) KaKu7 Woonkamer dressoir (3) 26 (4) 26
2016-08-10 12:02:10 - !!!! found device (1) KaKu7 Woonkamer dressoir (2) KaKu7 Woonkamer dressoir (3) 26 (4) 26
2016-08-10 12:02:10 - !!!! found device (1) KaKu7 Woonkamer dressoir (2) 26
2016-08-10 12:02:10 - --< devinfo_from_name: (1) 1 (2) 26 (3) KaKu7 Woonkamer dressoir (4) devices (5) Lighting 1 (6) On/Off (7) Off
2016-08-10 12:02:10 - *Woonkamer_licht|KaKu1_Woonkamer_voor - Off|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|KaKu7_Woonkamer_dressoir - Off|
2016-08-10 12:02:10 - Submenu item: (1) Netatmo_Binnen
2016-08-10 12:02:10 - - Submenu item: (1) Netatmo_Binnen (2) y (3) devices (4) 312 (5) 20.5°C - 70% - 1021.7hPa - Some Clouds
2016-08-10 12:02:10 - ==> start devinfo_from_name (1) 314 (2) Netatmo Binnen
http://192.168.1.223:8080/json.htm?type=devices&rid=314>
2016-08-10 12:02:10 - device (1) Netatmo Binnen (2) Netatmo Binnen (3) 314 (4) 314
2016-08-10 12:02:10 - !!!! found device (1) Netatmo Binnen (2) Netatmo Binnen (3) 314 (4) 314
2016-08-10 12:02:10 - !!!! found device (1) Netatmo Binnen (2) 314
2016-08-10 12:02:10 - --< devinfo_from_name: (1) 1 (2) 314 (3) Netatmo Binnen (4) devices (5) General (7) 47 dB
2016-08-10 12:02:10 - *Woonkamer_licht|KaKu1_Woonkamer_voor - Off|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|KaKu7_Woonkamer_dressoir - Off|Netatmo_Binnen - 47 dB|
2016-08-10 12:02:10 - Submenu item: (1) Netatmo_Binnen_()
2016-08-10 12:02:10 - ==> start devinfo_from_name (1) 313 (2) Netatmo Binnen (woonkamer)
http://192.168.1.223:8080/json.htm?type=devices&rid=313>
2016-08-10 12:02:10 - device (1) Netatmo Binnen (woonkamer) (2) Netatmo Binnen (woonkamer) (3) 313 (4) 313
2016-08-10 12:02:10 - !!!! found device (1) Netatmo Binnen (woonkamer) (2) Netatmo Binnen (woonkamer) (3) 313 (4) 313
2016-08-10 12:02:10 - !!!! found device (1) Netatmo Binnen (woonkamer) (2) 313
2016-08-10 12:02:10 - *Woonkamer_licht|KaKu1_Woonkamer_voor - Off|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|KaKu7_Woonkamer_dressoir - Off|Netatmo_Binnen - 47 dB|Netatmo_Binnen_() - nil|
2016-08-10 12:02:10 - Submenu item: (1) Onkyo_power
2016-08-10 12:02:10 - - Submenu item: (1) Onkyo_power (2) y (3) devices (4) 323 (5) Off
2016-08-10 12:02:10 - ==> start devinfo_from_name (1) 323 (2) Onkyo_power
http://192.168.1.223:8080/json.htm?type=devices&rid=323>
2016-08-10 12:02:10 - device (1) Onkyo_power (2) Onkyo_power (3) 323 (4) 323
2016-08-10 12:02:10 - !!!! found device (1) Onkyo_power (2) Onkyo_power (3) 323 (4) 323
2016-08-10 12:02:10 - !!!! found device (1) Onkyo_power (2) 323
2016-08-10 12:02:10 - --< devinfo_from_name: (1) 1 (2) 323 (3) Onkyo_power (4) devices (5) Light/Switch (6) Media Player (7) Off
2016-08-10 12:02:10 - *Woonkamer_licht|KaKu1_Woonkamer_voor - Off|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|KaKu7_Woonkamer_dressoir - Off|Netatmo_Binnen - 47 dB|Netatmo_Binnen_() - nil|Onkyo_power - Off|
2016-08-10 12:02:10 - Submenu item: (1) Woonkamer_(noord)
2016-08-10 12:02:10 - - Submenu item: (1) Woonkamer_(noord) (2) y (3) devices (4) 264 (5) 20.8°C - 62%
2016-08-10 12:02:10 - ==> start devinfo_from_name (1) 264 (2) Woonkamer (noord)
2016-08-10 12:02:10 - device (1) Woonkamer (noord) (2) Woonkamer (noord) (3) 264 (4) 264
2016-08-10 12:02:10 - !!!! found device (1) Woonkamer (noord) (2) Woonkamer (noord) (3) 264 (4) 264
2016-08-10 12:02:10 - !!!! found device (1) Woonkamer (noord) (2) 264
2016-08-10 12:02:10 - --< devinfo_from_name: (1) 1 (2) 264 (3) Woonkamer (noord) (4) devices (5) Temp + Humidity (7) 20.8°C - 62%
2016-08-10 12:02:10 - *Woonkamer_licht|KaKu1_Woonkamer_voor - Off|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|KaKu7_Woonkamer_dressoir - Off|Netatmo_Binnen - 47 dB|Netatmo_Binnen_() - nil|Onkyo_power - Off|Woonkamer_(noord) - 20.8°C - 62%|
2016-08-10 12:02:10 - Submenu item: (1) Woonkamer_(zuid)
2016-08-10 12:02:10 - - Submenu item: (1) Woonkamer_(zuid) (2) y (3) devices (4) 260 (5) 21.7°C - 59%
2016-08-10 12:02:10 - ==> start devinfo_from_name (1) 260 (2) Woonkamer (zuid)
2016-08-10 12:02:10 - device (1) Woonkamer (zuid) (2) Woonkamer (zuid) (3) 260 (4) 260
2016-08-10 12:02:10 - !!!! found device (1) Woonkamer (zuid) (2) Woonkamer (zuid) (3) 260 (4) 260
2016-08-10 12:02:10 - !!!! found device (1) Woonkamer (zuid) (2) 260
2016-08-10 12:02:10 - --< devinfo_from_name: (1) 1 (2) 260 (3) Woonkamer (zuid) (4) devices (5) Temp + Humidity (7) 21.7°C - 59%
2016-08-10 12:02:10 - *Woonkamer_licht|KaKu1_Woonkamer_voor - Off|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|KaKu7_Woonkamer_dressoir - Off|Netatmo_Binnen - 47 dB|Netatmo_Binnen_() - nil|Onkyo_power - Off|Woonkamer_(noord) - 20.8°C - 62%|Woonkamer_(zuid) - 21.7°C - 59%|
2016-08-10 12:02:10 - Submenu item: (1) licht_switch1
2016-08-10 12:02:10 - - Submenu item: (1) licht_switch1 (2) y (3) devices (4) 70 (5) Off
2016-08-10 12:02:10 - ==> start devinfo_from_name (1) 70 (2) woonkamer licht switch1
2016-08-10 12:02:10 - device (1) woonkamer licht switch1 (2) woonkamer licht switch1 (3) 70 (4) 70
2016-08-10 12:02:10 - !!!! found device (1) woonkamer licht switch1 (2) woonkamer licht switch1 (3) 70 (4) 70
2016-08-10 12:02:10 - !!!! found device (1) woonkamer licht switch1 (2) 70
2016-08-10 12:02:10 - --< devinfo_from_name: (1) 1 (2) 70 (3) woonkamer licht switch1 (4) devices (5) Lighting 2 (6) On/Off (7) Off
2016-08-10 12:02:10 - *Woonkamer_licht|KaKu1_Woonkamer_voor - Off|KaKu3_Woonkamer_achter - Off|KaKu4_open_haard - Off|KaKu7_Woonkamer_dressoir - Off|Netatmo_Binnen - 47 dB|Netatmo_Binnen_() - nil|Onkyo_power - Off|Woonkamer_(noord) - 20.8°C - 62%|Woonkamer_(zuid) - 21.7°C - 59%|licht_switch1 - Off|
2016-08-10 12:02:10 - process buildmenu: (1) Off,On (2) w: (3) 8
2016-08-10 12:02:10 - -< buildmenu: (1) ["Off","On"]
2016-08-10 12:02:10 - |Onkyo_power - Off|Woonkamer_(noord) - 20.8°C - 62%|Woonkamer_(zuid) - 21.7°C - 59%|licht_switch1 - Off| (2) w: (3) 3
2016-08-10 12:02:10 - ","Onkyo_power - Off","Woonkamer_(noord) - 20.8°C - 62%"],["Woonkamer_(zuid) - 21.7°C - 59%","licht_switch1 - Off"]
2016-08-10 12:02:10 - process buildmenu: (1) menu (2) w: (3) 3
2016-08-10 12:02:10 - -< buildmenu: (1) ["menu"]
2016-08-10 12:02:10 - -< replymarkup:{"keyboard":[["Off","On"],["*Woonkamer_licht","KaKu1_Woonkamer_voor - Off","KaKu3_Woonkamer_achter - Off"],["KaKu4_open_haard - Off","KaKu7_Woonkamer_dressoir - Off","Netatmo_Binnen - 47 dB"],["Netatmo_Binnen_() - nil","Onkyo_power - Off","Woonkamer_(noord) - 20.8°C - 62%"],["Woonkamer_(zuid) - 21.7°C - 59%","licht_switch1 - Off"],["menu"]],"selective":true,"resize_keyboard":true}
2016-08-10 12:02:10 - ==< Change KaKu1 Woonkamer voor => Off
https://api.telegram.org/bot....:keykey ... %3Atrue%7D
2016-08-10 12:02:10 - Message sent (1) 200
2016-08-10 12:02:10 - dtgbot: dtgmenu ended and text send ...return:200
2016-08-10 12:02:10 - Succesfully handled incoming request
.2016-08-10 12:02:20 - {"ok":true,"result":[{"update_id":783075446,
"message":{"message_id":673,"from":{"id":1...,"first_name":"Han","last_name":"...","username":"Han_..."},"chat":{"id":1.,"first_name":"Han","last_name":".....","username":"Han_.....","type":"private"},"date":1470823340,"text":"Woonkamer_(zuid) - 21.7\u00b0C - 59%"}}]}
2016-08-10 12:02:20 - Message: 1
2016-08-10 12:02:20 - update_id (1) 783075446
2016-08-10 12:02:20 - TelegramBotOffset 783075447
2016-08-10 12:02:20 - JSON request <
http://192.168.1.223:8080/json.htm?type ... =783075447>
2016-08-10 12:02:20 - WhiteList: 1..
2016-08-10 12:02:20 - Handle command function started with Woonkamer_(zuid) - 21.7°C - 59% and 1.
2016-08-10 12:02:20 - dtgbot: Start DTGMENU ... (1) Woonkamer_(zuid) - 21.7°C - 59%
2016-08-10 12:02:20 - ==> menu.lua process:Woonkamer_(zuid) - 21.7°C - 59%
2016-08-10 12:02:20 - => SendTo: (1) 1..
2016-08-10 12:02:20 - => commandline : (1) Woonkamer_(zuid) - 21.7°C - 59%
2016-08-10 12:02:20 - => command : (1) Woonkamer_
2016-08-10 12:02:20 - => param1 : (1) zuid
2016-08-10 12:02:20 - => Lastmenu submenu : (1) menu
2016-08-10 12:02:20 - |Onkyo_power - Off|Woonkamer_(noord) - 20.8°C - 62%|Woonkamer_(zuid) - 21.7°C - 59%|licht_switch1 - Off|
2016-08-10 12:02:20 - => Lastmenu actions : (1) Off,On
2016-08-10 12:02:20 - => Lastcmd prompt : (1) false
2016-08-10 12:02:20 - => Lastcmd submenu: (1) woonkamer
2016-08-10 12:02:20 - => Lastcmd device : (1) KaKu1_Woonkamer_voor
2016-08-10 12:02:20 - ChkInTable: (1) Off,On
2016-08-10 12:02:20 - - ChkInTable not found: Woonkamer_(zuid) - 21.7°C - 59%
2016-08-10 12:02:20 - ChkInTable: (1) menu
2016-08-10 12:02:20 - => cmdisaction : (1) false
2016-08-10 12:02:20 - => cmdisbutton : (1) true
2016-08-10 12:02:20 - => cmdissubmenu: (1) false
