Page 10 of 13
Re: Using BROADLINK RM2 on DOMOTICZ
Posted: Tuesday 24 January 2017 9:36
by woody4165
aldodemi wrote:Here a script to read RM2 temperature sensor, where 192.168.0.15 is the IP address for YOUR RM2 and "XX YY ZZ KK JJ WW" is its mac address, TEMP_IDX the index for the virtual switch in domoticz:
Grazie Aldo
You made my day, I was looking for something to solve the temp issue, after moving to the new way on managing the RM2...
Posted: Tuesday 24 January 2017 10:57
by deennoo
all this great works will make easy a Python Plugin creation for Domoticz !
Does someone manage to drive Broadlink Plug ?
I made a how to base on this topic, in french :
http://domo-attitude.fr/broadlink-rm-promini-domoticz/
Posted: Tuesday 24 January 2017 23:59
by moacir
Thank you aldodemi!!! Magic scripts! I'm new to Domoticz and i have a beginner question: it is possible to create dummy sensors or only dummy switches? In the dummy hardware i created to be able to use RM2, there is a button called create virtual sensors. When i use this button to create a temperature sensor for example, it is created in the temperature tab, but i can not edit any properties, just name, description and adjustment.
EDIT:
I got it!!! I read the Domoticz documentation and updated my sensors! I scheduled the scripts in CRON to run every minute and everything is OK, except hum_stat. Again, THANK YOU aldodemi for the scripts!!!
Re: RE: Re: Using BROADLINK RM2 on DOMOTICZ
Posted: Wednesday 25 January 2017 10:37
by deennoo
aldodemi wrote:Here a script to read A1 sensors, where 192.168.0.16 is the IP address for YOUR A1 and "XX YY ZZ KK JJ WW" is its mac address, varius xxxx_IDX the index for the virtual switchs in domoticz:
#!/bin/bash
DOMO_IP="127.0.0.1" # Domoticz IP Address
DOMO_PORT="8080" # Domoticz Port
AIRQ_IDX="821" # IDX for Virtual switch air_quality
LIGHT_IDX="822" # IDX for Virtual switch light
NOISE_IDX="823" # IDX for Virtual switch noise
TEMP_IDX="819" # IDX for Virtual switch temperature
HUM_IDX="820" # IDX for Virtual switch humidity
cd /home/domoticz/domoticz/scripts/python/broadlink/
function sensori {
python - <<END
import broadlink
import time
device = broadlink.a1(host=("192.168.0.16",80), mac=bytearray.fromhex("XX YY ZZ KK JJ WW"))
device.auth()
sensors = device.check_sensors()
print sensors
END
# Call it and capture the output
SENSORI=$(sensori)
echo Sensori: $SENSORI
# Esempio output {'air_quality': 'excellent', 'light': 'dark', 'noise': 'quiet', 'temperature': 23.3, 'humidity': 48.0}
air_quality=$(echo $SENSORI | cut -d' ' -f2 - | tr -d ,)
light=$(echo $SENSORI | cut -d' ' -f4 - | tr -d ,)
noise=$(echo $SENSORI | cut -d' ' -f6 - | tr -d ,)
temperature=$(echo $SENSORI | cut -d' ' -f8 - | tr -d ,)
humidity=$(echo $SENSORI | cut -d' ' -f10 - | tr -d })
#/json.htm?type=command¶m=udevice&idx=IDX&nvalue=HUM&svalue=HUM_STAT
# IDX =idx de votre capteur. A obtenir depuis l’écrans des dispositifs.
# HUM = Humidité: 45 par exemple pour 45%
# HUM_STAT = Humidity_status
# Humidity_status peut être :
# 0=Normal
# 1=Confortable
# 2=Sec
# 3=Humide
# Ce paramètre est obligatoire, si vous ne savez pas quoi mettre, mettez 0
hum_stat=0
#if [ $humidity<25 ]; then hum_stat=2; fi
#if [ $humidity>60 ]; then hum_stat=3; fi
#if [ $humidity>=25 && $humidity<=60 ]; then hum_stat=1; fi
case $humidity in
[0-25])
hum_stat=2
[26-60])
hum_stat=1
[61-100])
hum_stat=3
hum_stat=0
esac
echo $air_quality
echo $light
echo $noise
echo $temperature
echo $humidity
echo $hum_stat
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$AIRQ_IDX&svalue="$air_quality""
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$LIGHT_IDX&svalue="$light""
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NOISE_IDX&svalue="$noise""
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$TEMP_IDX&svalue="$temperature""
Sensor hum_stat at the moment doesn't works...
According api :
https://www.domoticz.com/wiki/Domoticz_ ... 2Fhumidity
Have you try to update only one device who get temp + hum + hum_stat ?
/json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=TEMP;HUM;HUM_STAT
Will be
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$TEMP_IDX&svalue="$temperature";"$humidity";"$hum_stat""
Posted: Wednesday 25 January 2017 17:35
by moacir
Yes deennoo, i did it. But these lines not always forcing hum_stat to be 0 (normal)?
hum_stat=0
I'm still starting in shell script.
Posted: Wednesday 25 January 2017 22:13
by deennoo
sorry didn't get A1 sensors
what answer
from you browser ?
what is hum-stat ? add some print to get it, maybe value isn't good
Posted: Wednesday 25 January 2017 22:42
by moacir
I use separate temperature and humidity. My command for humidity is:
curl -s -i -H "Accept: application/json" "http://myuser:mypw@$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$HUM_IDX&nvalue="$humidity"&svalue=;"$hum_stat""
And the result:
HTTP/1.1 200 OK
Content-Length: 53
Content-Type: application/json;charset=UTF-8
Cache-Control: no-cache
Pragma: no-cache
Access-Control-Allow-Origin: *
Set-Cookie: SID=50c2a1b034ae5327c681d1c9668f7bfb_NzFjNjUzZTAtNjRkYi00ZjAzLTg5NzAtODM4OWYzMGVlZmU0.1485380559; path=/; Expires=Wed, 25 Jan 2017 21:42:39 GMT
"status" : "OK",
"title" : "Update Device"
And the result of the A1 readings:
Sensores: {'air_quality': 'excellent', 'light': 'dark', 'noise': 'normal', 'temperature': 26.4, 'humidity': 59.7}
'excellent'
'dark'
'normal'
26.4
59.7
0
At the time of reading, the weather was rainy and the humidity is a bit higher. According to the script, for this value of humidity (59.7) should return state 1 (comfortable) and not 0 (normal) as it is occurring. The function on the script that returns the
hum_stat according to the value of the humidity is not working.
Posted: Wednesday 25 January 2017 22:55
by deennoo
have you remove # on
who give
Posted: Wednesday 25 January 2017 23:06
by moacir
Even removing the comment from these lines hum_stat remains equal to 0.
Posted: Wednesday 25 January 2017 23:07
by deennoo
you have to check if
if condition and if are correct, this part of script is python
Posted: Wednesday 25 January 2017 23:38
by moacir
I did some tests here but with no success. Programming in scripts runs away from my knowledge, so i will keep this way. Having the humidity indication in percentage is already 99% of everything! Thanks deennoo for all helps!
Posted: Thursday 26 January 2017 8:13
by aldodemi
For HUM_STAT try modify the script this way:
# 0=Normal
# 1=Confortable
# 2=Sec
# 3=Humide
# is indeed the ranges from about 70% wet, below 30 Dry, between 30 and 45 Normal, and 45 and 70 comfortable.
hum_stat=0
if [ $humidity<30 ]; then hum_stat=2; fi
if [ $humidity>=30 && $humidity<=45 ]; then hum_stat=0; fi
if [ $humidity>=45 && $humidity<=70 ]; then hum_stat=1; fi
if [ $humidity>70 ]; then hum_stat=3; fi
remote all code between "case" and "esac"
Posted: Thursday 26 January 2017 10:11
by hasan
Hi guys,
I see big movement in RM2 integration. So I would like to ask somebody if can help me with integration switch TC2 (
http://www.ibroadlink.com/tc2/) it is RF controlled switch.
Thanks for any idea.
Posted: Thursday 26 January 2017 11:00
by moacir
I'm at work now aldodemi and i can only test your code later. But i have good news for hasan. I use TC2 switches with Domoticz, which i used before with RM Bridge. The TC2 have a code to ON and another to OFF each gang. To clone the TC2 codes, it does a bit of work:
1) Install a TC2 normally with a RM2 (called "A") and the E-control app in a LOCAL net.
2) Install ANOTHER RM2 (called "B") in same E-control app (this other will only be used to clone the code with the RM Bridge).
3) Connect RM2 "B" to RM Bridge (you will need to know the mac of this RM2, so consult your router) and go to learn code page and at the same time open the app on the TC2 you want to copy.
4) Scan the frequency on RM Bridge while activating the TC2 in the app several times.
5) In RM Bridge, while placing RM2 "B" to clone codes, activate TC2 by the app in the gang you want to clone, remembering that each gang have two different codes (ON and OFF).
I did this way to clone all my TC2. In the first few tries it may not work, because when testing the cloned code, it may return an error message due to the size of the code. After a few tries you'll get the hang of it. My tip is to activate the cloning in the RM2 "B", wait around 2 seconds and then trigger the TC2 to be cloned, so that the code read is not out of the maximum size.
Good luck!
Posted: Thursday 26 January 2017 12:03
by hasan
moacir wrote:I'm at work now aldodemi and i can only test your code later. But i have good news for hasan. I use TC2 switches with Domoticz, which i used before with RM Bridge. The TC2 have a code to ON and another to OFF each gang. To clone the TC2 codes, it does a bit of work:
Good luck!
Nice... Thanks... I'll order second RM2 and try to do it...
Posted: Thursday 26 January 2017 14:22
by moacir
Hi again
aldodemi. I've tested your code with no success. I switched my sensor from only humidity to temperature + humidity and with the "old" script it was working OK, just forcing hum_stat = 0. My "new" code looks like this:
#!/bin/bash
DOMO_PORT="81" # Domoticz Port
AIRQ_IDX="18" # IDX for Virtual switch air_quality
LIGHT_IDX="19" # IDX for Virtual switch light
NOISE_IDX="20" # IDX for Virtual switch noise
TEMP_IDX="21" # IDX for Virtual switch temperature
HUM_IDX="21" # IDX for Virtual switch humidity
cd /domoticz/scripts/python/broadlink
function sensori {
python - <<END
import broadlink
import time
device = broadlink.a1(host=("my-ip",80), mac=bytearray.fromhex("my-mac"))
device.auth()
print sensors
END
SENSORI=$(sensori)
echo Sensores: $SENSORI
# 0=Normal
# 1=Confortable
# 2=Sec
# 3=Humide
hum_stat=0
if [ $humidity<30 ]; then hum_stat=2; fi >>> LINE 46
if [ $humidity>=30 && $humidity<=45 ]; then hum_stat=0; fi >>> LINE 47
if [ $humidity>=45 && $humidity<=70 ]; then hum_stat=1; fi >>> LINE 48
curl -s -i -H "Accept: application/json" "http://myuser:mypw@$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$AIRQ_IDX&svalue="$air_quality""
curl -s -i -H "Accept: application/json" "http://myuser:mypw@$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$LIGHT_IDX&svalue="$light""
curl -s -i -H "Accept: application/json" "http://myuser:mypw@$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NOISE_IDX&svalue="$noise""
curl -s -i -H "Accept: application/json" "http://myuser:mypw@$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$TEMP_IDX&svalue="$temperature";"$humidity";"$hum_stat""
The texts
>>> LINE 4X i included for your reference only, they are not in the script.
And the output looks like this:
Sensores: {'air_quality': 'excellent', 'light': 'normal', 'noise': 'quiet', 'temperature': 24.8, 'humidity': 60.3}
/domoticz/scripts/python/broadlink/a1reads2.sh: line 46: 30: File or directory not found
/domoticz/scripts/python/broadlink/a1reads2.sh: line 47: [: missing `]'
/domoticz/scripts/python/broadlink/a1reads2.sh: line 48: [: missing `]'
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
Set-Cookie: SID=f0817775507e8cfc4b141f09caf78a20_ZGM5MzE0MjYtZTZmNC00YWNhLWIwOTktYjkzOTM1ODIxMGM1.1485435650; path=/; Expires=Thu, 26 Jan 2017 13:00:50 GMT
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
Set-Cookie: SID=9f0ebfb2d5662ce0e1289447c0c07a20_YWVlOGU1ZmYtNjU2Zi00YzkzLWE2NDctODI1NjU3ZTVhZTRm.1485435650; path=/; Expires=Thu, 26 Jan 2017 13:00:50 GMT
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
Set-Cookie: SID=5c3f7dfc659c328eb4dcb83b3042fc68_ZmIxMDU4Y2YtOWQ0NC00MWViLWE0MTMtMWE1YWI5NDg5NWJj.1485435650; path=/; Expires=Thu, 26 Jan 2017 13:00:50 GMT
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
Set-Cookie: SID=6c4c41789e0ef3f9eaf41ca4deb90ecf_MmRjMGZhZDAtZTQwMi00NDBlLTk0OTItZmZhMjFhMWM1OWY5.1485435650; path=/; Expires=Thu, 26 Jan 2017 13:00:50 GMT
"status" : "OK",
The temperature and humidity sensor is updated OK, but now with status 3 (wet, wrong because it should be 1 for humidity = 60.3) and in
/domoticz/scripts/python/broadlink three empty files are created:
"=30",
"=45" and
"70".
Posted: Monday 30 January 2017 1:42
by moacir
Hello again, people. I have a LOT of good news regarding the script for the A1 Sensor! With the help of a great brazilian shell script forum, i discovered what was happening with
hum_stat: the A1 generates the decimal humidity value (eg 58.6) and the
IF can not handle the decimal values. The solution is use
AWK to generate
hum_stat. This is the definitive script for use in A1, removing the
' and leaving upper case the first letter on the text variables (air_quality, light and noise):
#!/bin/bash
AIRQ_IDX="20" # IDX for Virtual switch air_quality
LIGHT_IDX="21" # IDX for Virtual switch light
NOISE_IDX="22" # IDX for Virtual switch noise
TEMP_IDX="23" # IDX for Virtual switch temperature
HUM_IDX="23" # IDX for Virtual switch humidity
function sensori {
python - <<END
import broadlink
import time
device = broadlink.a1(host=("A1-IP",80), mac=bytearray.fromhex("A1-MAC"))
device.auth()
print sensors
END
SENSORI=$(sensori)
air_quality=$(echo $SENSORI | cut -d' ' -f2 - | tr -d ",'")
light=$(echo $SENSORI | cut -d' ' -f4 - | tr -d ",'")
noise=$(echo $SENSORI | cut -d' ' -f6 - | tr -d ",'")
temperature=$(echo $SENSORI | cut -d' ' -f8 - | tr -d ",'")
humidity=$(echo $SENSORI | cut -d' ' -f10 - | tr -d "}'")
#Treatment of the variables
air_quality=${air_quality^}
light=${light^}
noise=${noise^}
# 0=Normal
# 1=Confortable
# 2=Sec
# 3=Humide
hum_stat=$(awk '{if($1<30) print "2";else if($1>=30 && $1<45) print "0";else if($1>=45 && $1<=70) print "1";else if($1>70) print "3"}' <<< $humidity)
echo $air_quality
echo $light
echo $noise
echo $temperature
echo $humidity
echo $hum_stat
curl -s -i -H "Accept: application/json" "http://USER:PWD@$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$AIRQ_IDX&svalue="$air_quality""
curl -s -i -H "Accept: application/json" "http://USER:PWD@$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$LIGHT_IDX&svalue="$light""
curl -s -i -H "Accept: application/json" "http://USER:PWD@$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NOISE_IDX&svalue="$noise""
curl -s -i -H "Accept: application/json" "http://USER:PWD@$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$TEMP_IDX&svalue="$temperature";"$humidity";"$hum_stat""
This is the output of the script:
Sensores: {'air_quality': 'excellent', 'light': 'dark', 'noise': 'quiet', 'temperature': 25.5, 'humidity': 61.1}
Excellent
Dark
Quiet
25.5
61.1
1
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
Set-Cookie: SID=eab2c6b52dc26bc6ae0a2155b2eb7c9e_YmY2YzM5YjktYzBlNC00M2JlLWJlNjUtMjdjYmFhYjg2NGI3.1485737119; path=/; Expires=Mon, 30 Jan 2017 00:45:19 GMT
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
Set-Cookie: SID=6af9a3dbf43daa1b5db9e43bc2dd67e1_MjJkMWM1N2UtZTc0Yi00Y2QwLTllYTQtZGZlYjQ3ZTc4MWY2.1485737119; path=/; Expires=Mon, 30 Jan 2017 00:45:19 GMT
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
Set-Cookie: SID=fd4308ffdaad925650aa44779d47fa64_MDVmZGJhYWItNjNiOC00ZDcyLTg1MmEtMTA0ZjRlOWQwY2Vj.1485737119; path=/; Expires=Mon, 30 Jan 2017 00:45:19 GMT
"status" : "OK",
HTTP/1.1 200 OK
Content-Length: 53
Pragma: no-cache
Set-Cookie: SID=e2ab149f8c3039b30b03eedd604705fa_NzM0YjVmYWUtN2MzZi00NjQ3LTg0MjEtOGE3ZjgxMDBmNjll.1485737119; path=/; Expires=Mon, 30 Jan 2017 00:45:19 GMT
"status" : "OK",
Now the A1 works perfectly with Domoticz! I would like to thank everyone who helped and also to suggest an improvement for future versions of Domoticz: enable notifications on text sensors. If the sensor receives a certain text string, it will generate the configured notification. It would also be interesting to enable the possibility of changing the icon in the text sensors.
Posted: Monday 30 January 2017 7:22
by deennoo
Cool news,
Which device did you use text sensor ?
Posted: Monday 30 January 2017 15:47
by moacir
In Broadlink A1, for air quality sensor (variable air_quality in script), luminance (variable light in script) and noise (variable noise in the script), text-mode sensors are required in Domoticz, since they send text (eg. Excellent, Dark, Quiet etc.) rather than numbers or percentage.
Posted: Monday 30 January 2017 16:49
by deennoo
moacir wrote:In Broadlink A1, for air quality sensor (variable air_quality in script), luminance (variable light in script) and noise (variable noise in the script), text-mode sensors are required in Domoticz, since they send text (eg. Excellent, Dark , Quiet etc.) rather than numbers or percentage.
ok thx
