Page 10 of 16
Re: Events system feedback thread
Posted: Monday 12 August 2013 23:46
by sebquid
I tried what you said and it is not working also. We can not save events with such url.
Posted: Saturday 17 August 2013 1:03
by Skippiemanz
Does anyone have the solution for this problem?
Posted: Saturday 17 August 2013 6:43
by CopyCatz
I put a fix in 996, could you test please?
Posted: Monday 19 August 2013 23:24
by Skippiemanz
Thanks, i will check a soon as an update is placed online
Posted: Thursday 22 August 2013 14:14
by Skippiemanz
Unfortunetly i still got the same error in rev 999.
Any ideas?
Posted: Friday 23 August 2013 3:29
by CopyCatz
You have to open your event and save it again for the new url storage to kick in. It works this way with most event fixes/upgrades.
Posted: Friday 23 August 2013 10:35
by Skippiemanz
I deleted the event and try to create the ne event but still unable to save
Open / close in Blockly not work
Posted: Sunday 25 August 2013 15:23
by matra-manni
Hello
"On" and "Off" function properly. (inverted blinds)
"Open" / "Close" doesn´t switch.
Events also work if they are not activated. (Text is red).
Only when all events disabled, they are turned off.
This is very difficult when testing.
Es grüßt ... Manni
Problem using temperature in events
Posted: Thursday 05 September 2013 22:49
by kallej
I have created an event using the block editor, it goes like this:
If "Höyrysauna" temperature < 26 do set "ventilation" on
both above devices are working nicely and I can get the temperature and control the ventilation, but once I activate the event
i start to get following log entries every time the "device" sends new temp and humidity information:
Error: Thu Sep 5 23:44:31 2013 Lua script error: [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to index global 'humiditydevice' (a nil value)
Error: Thu Sep 5 23:44:31 2013 Lua script error: [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to index global 'temperaturedevice' (a nil value)
Thu Sep 5 23:44:31 2013 (RFX-Dongle) Temperature + Humidity (Höyrysauna)
Just did an update, so domoticz version is the latest available.
Could you help me out on this one ?
Posted: Thursday 12 September 2013 8:48
by CopyCatz
Can you post a screenshot of your blockly event please?
Posted: Friday 13 September 2013 12:01
by spaanplaat
Some of us are trying to get xbmc and domoticz to interact with each other. The plugin in XBMC works great to interact with domoticz but it does not work the other way around.
When I try to pause XBMC with the following url it works but when I attach this URL to a blocky example and a dummy switch we receive the following error.
http://(user:password)@(ip address xbmc):(port)/jsonrpc?request={"jsonrpc": "2.0", "method": "Player.PlayPause", "params": { "playerid": 1 }, "id": 1}
Of course I replaced the user, password and ip with my own credentials.
Fetching url: xbmc:[email protected]:80/jsonrpc?request={"jsonrpc":"2.0
Error: Wed Sep 4 03:23:06 2013 Malformed action sequence!
I already tried to replace the comma's in the url with %2c but I still receive the same error. Is this type of URL not possible with blocky? Or is it to long? I'm running V1.1009.
Posted: Saturday 14 September 2013 14:04
by Keptenkurk
Piotr, how about calling the url with curl from a shell script and call this script from your lua script? Could be a work around for the time being...
Posted: Saturday 14 September 2013 20:56
by niki_lauda
i,
"CopyCatz"]Can you post a screenshot of your blockly event please?
Same problem here
error in the log
Error: Sat Sep 14 20:53:30 2013 Lua script error: [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare nil with number
Posted: Thursday 19 September 2013 9:30
by kallej
HI,
Some more information on this one.
seems that this happens only when I'm trying to evaluate humidity and it actually had something to do with my device
after swapping the thermometer, everything seems to work nicely.
Posted: Friday 20 September 2013 19:04
by alfred_j_kwak
Hi everyone. New member/user and first post.
I tried to control bathroom exhaust fan. I have switch to switch it on and off.
What I liked to do is use delay for fan. If I switch it on it runs 30 minutes and stop and also 'turn' switch off.
If I liked to stop it earlier I just turn switch off.
I tried to do Event, but it seems that when delay is set it is impossible to reset it again?
Here is simple block diagram where fan is set to run 1 min.
-Jussi-
EDIT: Now when I have stared my plan for a while it seems to be mission impossible...
Posted: Tuesday 24 September 2013 23:45
by CopyCatz
- v1.1023: Scenes and groups on/off/active/inactive via events, fixed bug where inactive event would still trigger
when multiple events apply. Comma now supported in event OpenURL. events now triggered by security state change
implemented script_security_name.lua for sec panel triggers in lua.
Posted: Wednesday 25 September 2013 11:21
by NiklasO
Posted: Wednesday 25 September 2013 11:30
by CopyCatz
weird, they are retrieved using the standard json.htm?type=scenes&order=Name. Can you post the output of that api call?
Posted: Wednesday 25 September 2013 11:35
by NiklasO
CopyCatz wrote:weird, they are retrieved using the standard json.htm?type=scenes&order=Name. Can you post the output of that api call?
"result" : [
"Favorite" : 1,
"HardwareID" : 1,
"LastUpdate" : "2013-09-23 22:15:49",
"Name" : "Vardagsrum, lampor",
"Status" : "Off",
"Timers" : "false",
"Type" : "Group",
"idx" : "3"
"Favorite" : 1,
"HardwareID" : 1,
"LastUpdate" : "2013-09-25 06:38:01",
"Name" : "Fönsterbelysning",
"Status" : "Off",
"Timers" : "true",
"Type" : "Group",
"idx" : "4"
"status" : "OK",
"title" : "Scenes"
Does this look right btw?
https://dl.dropboxusercontent.com/u/900 ... hot121.jpg
When done with groups it should turn the scene/group on when the power goes down below 1400mW and groupstatus = Off
The other way around when over 1500mW.
Posted: Wednesday 25 September 2013 13:31
by NiklasO
Also,
The event i posted in my last url does not work.
With the event active, manually turning on "Fönsterlampa, kök" this happens in the log:
Error: Wed Sep 25 13:26:34 2013 Lua script error: [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: ')' expected near 'comparevariable'
Wed Sep 25 13:26:33 2013 (RFXtrx) Lighting 2 (Fönster, kök)
Wed Sep 25 13:26:34 2013 (RFXtrx) Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 3
response = ACK, data correct transmitted
With the event disabled, turning on gives me this:
Wed Sep 25 13:27:03 2013 (RFXtrx) Lighting 2 (Fönster, kök)
Wed Sep 25 13:27:03 2013 (RFXtrx) Receiver/Transmitter Message
Sequence nbr = 4
Works as it should. But as I said. Not with the event activated.
The event does nothing if I leave the lamp on and waits for it to turn it off.
