Else i do not see the benefit ? prices of the nano are not expensive
if we could use the onboard wifi, now thats another story
Wow great. when my gateway if wifi (it would be easy because it's under my router) and if the sensor of my watermeter and 3 relais can be attached I can dump my: pi1 with piface.hek wrote:Hi guys,
A couple of benefits of using the WiFi gateway is:
1. You can place your gateway anywhere with WiFi coverage without the need for hard-wired ethernet connection.
2. Hooking up and configuring an ethernet gateway is more complicated (especially if you need to enable SOFT-SPI for radio).
Otherwise it should work just as your Serial/ethernet variant (but with more memory).
I'm currently doing a big refactoring of the library and the new version allows sensors to be attached to gateway as well. This would allow you to deploy ESP-gateways/sensors without any NRF24/RF69 radios attached. Could be a good option if you don't care about battery operation and already have good WiFi coverage in your house.
That would be great!hek wrote:I'm currently doing a big refactoring of the library and the new version allows sensors to be attached to gateway as well. This would allow you to deploy ESP-gateways/sensors without any NRF24/RF69 radios attached. Could be a good option if you don't care about battery operation and already have good WiFi coverage in your house.
Yes there is.Justintime wrote:No, you have to have a serial gateway which communicates with the nodes. The serial gateway talks with Domoticz.BluesBro wrote:Is there a way to skip ardunio via serial and connect the nrf24 directly to the Pi?
I have two gate ways up and running. One serial and one Ethernet.jopa wrote:Thanks.Yeah, I get the point. If two gateways with their sensors are in the same room they need to operate on different Radio Frequency Channels. I did take care of that to make sure they won't interfere one with another.
It seems to me to be something else. Something between Domoticz over the TCP/IP protocol and the Gateways. Activating one at the time in Domoticz everything is working fine.
It looks as if Domoticz isn't prepared to handle two MysSensors Gateways at the same time.
One gateway has the IP Address 192.168.0.91 and the other works with 192.168.0.93. Each Gateway activated separately gets correct registers in the Domoticz Log showing to be connected and sensors are being recognized automatically and shows up in the Log. But when I activate in the Hardware Menu both Gateways at the same time it stops working correctly and stops to register any new Logs. Even when I unplug or reset the MySensors Gateways Domoticz doesn't register any-longer the loss of connection.
Could I activate some recommended Debugging to capture more Data? And if someone please from the development team could confirm if Domoticz is prepared to handle various MySensors Gateways simultaneously. I can't find an answer in the documentation or at the Forum.
i can confirm it works.gizmocuz wrote:that might work
