Page 10 of 19
Re: Satel Integra (Security System) with ethernet module
Posted: Saturday 22 April 2017 13:28
by teamc
Hello everyone.
I'm a beginner from Domoticz and apologize for my question if the answer is somewhere in the forum.
I have a small problem with full communication with Satel Integra. I have reads from inputs and outputs but can not control outputs
2017-04-22 11: 09: 26.398 User: Admin initiated a switch command (19 / Output: Output 5 / On)
2017-04-22 11: 09: 26.929 Error: Satel Integra: receive error: requesting user code not found
2017-04-22 11: 09: 26.930 Error: Satel Integra: Switch output 5 failed
How can I add "user code" and how should it look ??
Cezary ( Poland )
Posted: Saturday 22 April 2017 17:35
by fantom
"requesting user code not found"
You didn't set user code in domoticz (setup->hardware->Integra->Password
Fantom
Posted: Monday 24 April 2017 11:23
by WojMaj
Hello everyone
I have a problem with communication with my Integra 128 with ETHM-1.
In Logs there is:
2017-04-24 11:20:22.168 Satel Integra: Create instance
2017-04-24 11:20:37.652 Satel Integra: connected to 192.168.1.22:7094
2017-04-24 11:20:37.658 Error: Satel Integra: busy
2017-04-24 11:20:37.658 Error: Satel Integra: Get info about Integra is failed
2017-04-24 11:21:30.367 Error: Satel Integra hardware (9) thread seems to have ended unexpectedly
What should I do, to start communiction?
Regards, Wojtek
Posted: Monday 24 April 2017 12:02
by fantom
ETHM1 uses only one connection on 7094 port. When You use another applaication etc You get "Satel Integra: busy"
Fantom
Posted: Monday 24 April 2017 12:11
by WojMaj
fantom wrote:ETHM1 uses only one connection on 7094 port. When You use another applaication etc You get "Satel Integra: busy"
Fantom
I think, I don't use other application. Maybe I will change integration port to 7099?
Posted: Monday 24 April 2017 12:55
by fantom
Other application are DLoadX, another domoticz instance, more Integra hardwares in domoticz etc,
Fantom
Posted: Monday 24 April 2017 14:07
by WojMaj
fantom wrote:Other application are DLoadX, another domoticz instance, more Integra hardwares in domoticz etc,
Fantom
I've got only one domoticz instance, and no other Intergra hardwares in domoticz. DLoadx is on port 7091 - but I will check it at home.
Posted: Monday 24 April 2017 14:46
by fantom
Do You have ETHM-1 or ETHM-1 Plus ?
Do You have the newest firmware (check date, not number)?
Fantom
Posted: Tuesday 23 May 2017 19:44
by zygi125
I have a problem with connecting Satel and Domotich. I have module ETHM-1 (1.07 firmware), Domoticz version: 3.7416 (on Synologic) and I try connect, but I have this message in log:
2017-05-23 19:29:18.672 Satel Integra: Destroy instance
2017-05-23 19:29:18.673 Satel Integra: Create instance
2017-05-23 19:29:18.692 Satel Integra: connected to 192.168.1.109:7094
2017-05-23 19:29:18.719 Error: Satel Integra: received bad frame (prefix or sufix)
2017-05-23 19:29:18.719 Error: Satel Integra: Get info about Integra is failed
2017-05-23 19:30:30.416 Error: Satel hardware (4) thread seems to have ended unexpectedly
2017-05-23 19:31:00.420 Error: Satel hardware (4) thread seems to have ended unexpectedly
2017-05-23 19:31:30.425 Error: Satel hardware (4) thread seems to have ended unexpectedly
2017-05-23 19:32:00.429 Error: Satel hardware (4) thread seems to have ended unexpectedly
2017-05-23 19:32:30.433 Error: Satel hardware (4) thread seems to have ended unexpectedly
What's is wrong?
Anyone help me?
Regards zygi
Posted: Tuesday 23 May 2017 20:10
by fantom
Pls check firmware date (ETHM1).
Do You use wifi or cable between domoticz and ethm1 ?
Fantom
Posted: Tuesday 23 May 2017 20:24
by zygi125
firmware in ETHM1 is 1.07. Today upgrade from 1.04 to 1.07, but it is not plus version - is it important?
I use calbe between domoticz and ETHM1 (and switch of course).
Zygi
Posted: Tuesday 23 May 2017 21:24
by fantom
ETHM1 (without plus) should work too.
Is Firmwware dated on 2015-03-02 ?
Fantom
Posted: Wednesday 24 May 2017 7:04
by zygi125
Firmware downloaded from here:
http://www.satel.pl/pl/product/348/ETHM ... ulu-ETHM-1 date version: 2015-03-02.
Below my config on Domoticz, but i have questions - password in config - which password from Satel must enter?
http://www.tinypic.pl/8y273uif0k8o
Zygi
Posted: Thursday 27 July 2017 17:33
by fantom
Password from Integra (for one user).
pin to which you arm the zone etc,
Fantom
Posted: Thursday 10 August 2017 7:12
by WojMaj
Hello
I use Domoticz 3.8153 with Satel integration module. Almost everything works fine, but sometimes it crashed. In logs there are error messages:
2017-08-09 23:06:32.701 Error: Satel Integra: bad data length received
2017-08-09 23:06:32.701 Error: Satel Integra: Send 'Read Outputs' failed
2017-08-09 23:06:33.702 Error: Satel Integra: bad data length received
2017-08-09 23:06:33.702 Error: Satel Integra: Get info about new data is failed
2017-08-09 23:06:34.707 Error: Satel Integra: bad data length received
2017-08-09 23:06:34.707 Error: Satel Integra: Send 'Read Outputs' failed
2017-08-09 23:06:35.707 Error: Satel Integra: bad data length received
2017-08-09 23:06:35.707 Error: Satel Integra: Get info about new data is failed
I had to restart Satel integration in Domoticz, and it works fine till next error. It happens once or twice per day.
What can I do to resolve this issue?
Thanks in advance
Wojmaj
Posted: Thursday 10 August 2017 9:18
by fantom
1) Please use the latest firmware for ETHM1
2) Set "data timeout" for Integra hardware (for example 5 minutes)
3) Don't use wi-fi between integra and domoticz
Fantom
ps. How "Refresh time" did you set ?
Posted: Monday 14 August 2017 8:49
by WojMaj
I'm using the latest firmware
Done
I've connected Domoticz to the main router, and ETHM to the switch witch is next connected to the repeater, and now I'm testing. There is a lot of trouble to connect ETHM stright to the main router, so I will try this resolution with the switch first.
1000
Wojmaj
Posted: Friday 18 August 2017 9:39
by borewicz
Hello
Is there any chance to integrate Domoticz with Satel Versa Plus ?
http://www.satel.pl/pl/product/722/VERS ... a-alarmowa
Posted: Sunday 20 August 2017 11:58
by fantom
Is versa plus working with Ethernet?
Fantom
Posted: Sunday 20 August 2017 11:59
by fantom
Do versa plus work with Ethernet?
Fantom
