Page 10 of 15
Re: Domoticz to Google Assistant integration
Posted: Wednesday 18 December 2019 9:14
by EddyG
DewGew wrote: Tuesday 17 December 2019 19:43 Note that this is still in beta..
New function is report state. With this dzga reports state to google to reduce quiering amount and time. So google reports back latest known state. This is might not optimal for some devices like temperatures. So I added function to disable report state on specific device.
Just add
report_state: false
to "Device_Config" in configuration or <voicecontrol>report_state = False</voicecontrol> in device description. That device should query direct from domoticz.
I haven’t tested fully yet.
Edit: If you want use dzga as before, just delete json file and add the homegraph_api_key.
OK, clear to me. I noticed that Google rounds the Temperature to 0,5 degrees.
So 21,3 degrees is pronounced as 21,5 degrees. Google does not know how to pronounce the other digits. ;)
Posted: Monday 23 December 2019 9:20
by EddyG
I wonder if it is possible to get a RTSP stream from my Foscam camera to Chromecast.
Posted: Monday 23 December 2019 9:34
by DewGew
If you can get a hls or mp4 stream from your camera or from a survailance program you can send stream to chrome cast or view stream in a google nest hub
Posted: Monday 23 December 2019 14:01
by EddyG
Foscam mostly have RTSP output (FFMPEG)
Has anyone an example how to convert this to a MP4 or HLS stream without a file as output?
Posted: Tuesday 24 December 2019 18:05
by DewGew
Posted: Tuesday 24 December 2019 22:05
by EddyG
I have seen that example, but it creates a file on /var/www/html/cam
That file grows, and I don not have the space.
I would like to stream without a file or pipe directly to Google.
Posted: Wednesday 25 December 2019 19:15
by lupo2a
Setted up everything following the wiki. When I go to google home and try to set up the new device, I can reach the login page.
When I enter the credentials nothing happen.
When I go to myhost:3030:settings and try sync devices I got: Homegraph api key not valid!
On the raspy consol I get an error code 404 Requested entity was not found
I checked on google and the HomeGRaph API is enabled. Any help?
Posted: Thursday 26 December 2019 18:22
by DewGew
lupo2a wrote: Wednesday 25 December 2019 19:15 Setted up everything following the wiki. When I go to google home and try to set up the new device, I can reach the login page.
What version are you running?
Posted: Sunday 29 December 2019 17:27
by lupo2a
dzga v 1.3.8 on a raspberry pi3.
Posted: Monday 30 December 2019 13:24
by lupo2a
DewGew wrote: Thursday 26 December 2019 18:22
dzga v 1.3.8 on a raspberry pi3. Any hint for debugging?
Posted: Monday 30 December 2019 16:41
by lupo2a
lupo2a wrote: Monday 30 December 2019 13:24
Restarted from scratch (git get, google action, API, etc..) now it works. Great!
Posted: Thursday 02 January 2020 14:10
by rezo552
I have an issue, I setup the application, I can see my domoticz device on the UI, I setup the google cloud API. But when I link the service in Google Home, I can login but no devices show up. I made a PCAP trace but I cannot see whats wrong
https://drive.google.com/file/d/1uSLALB ... sp=sharing
Any idea? Thanks
Z.
Posted: Thursday 02 January 2020 15:56
by lupo2a
rezo552 wrote: Thursday 02 January 2020 14:10 Hi,
Any idea? Thanks
Z.
it looks like what happened to me. I restarted from scratch and it works. Could be the HomeGRaph API key.
Posted: Monday 06 January 2020 22:57
by frankdep
Is it normal that I have to add the import of fanDomain in smarthome.py at every update?
I have a Fan definition in the image override section of config.yaml.
By The Way : great development and improvements in the settings page.
Posted: Tuesday 07 January 2020 10:09
by EddyG
For some strange reason when I ask for a room temperature sometimes Google comes back that the device is not reachable.
In the debug log I see a request and response in the same second. If I ask a few seconds later, the response from Google is normal with a rounded temperature of 0,5 degree. The response in the logfile is exactly the same.
Any idea how that can be prevented?
Posted: Tuesday 07 January 2020 10:59
by DewGew
frankdep wrote: Monday 06 January 2020 22:57 Hi,
Are you running dzga master or beta?
EddyG wrote: Tuesday 07 January 2020 10:09 For some strange reason when I ask for a room temperature sometimes Google comes back that the device is not reachable.
You are running beta I assume, I m trying to get dzga working with fahrenheit so beta might not be 100% correct.
Posted: Tuesday 07 January 2020 11:09
by EddyG
Yes, I am running beta. But it is not about the 0,5 degrees. It is about Google does not find the device, although the response in the debug logfile is exactly the same as when there is a normal answer.
I suppose that has nothing to do with you working on fahrenheit, is it?
Posted: Tuesday 07 January 2020 11:32
by DewGew
EddyG wrote: Tuesday 07 January 2020 11:09 Yes, I am running beta. But it is not about the 0,5 degrees. It is about Google does not find the device, although the response in the debug logfile is exactly the same as when there is a normal answer.
It has to do with this, I need to recalculate temp from fahrenheit to celsius and back !? So the temp request goes a roundabout in the code for now :)
Im working on a solution.
EDIT: I tested my setup. I cant reproduce your issue.
Posted: Tuesday 07 January 2020 17:52
by frankdep
DewGew wrote: Tuesday 07 January 2020 10:59
=> it is beta 1.4.8
Posted: Tuesday 07 January 2020 20:03
by DewGew
frankdep wrote: Tuesday 07 January 2020 17:52
Fixed in latest :)
