Page 10 of 20
Re: [120] opentherm gateway
Posted: Tuesday 24 June 2014 12:29
by Sjonnie
sincze wrote:Sjonnie wrote:Hello
Well actually i also have some zero values like you do, except for the return water temperature; that one shows an actual value. On top of that I have to deal with another lttle issue; cause when I got home from work I noticed all the OTGW devices in red state. The running log of Domoticz showed me an "end of file" error, don't know where that comes from, but after a restart of the TPlink and the start of the ser2net process things started to work again. Maybe some log which is enabled or so? So still stuff to do I guess
I flashed version 4.0.1 in my OTGW
Cheers
Hi Sjonnie.
Did you know that the TP Link suffers from an USB issue.
It will stop working if you don't connect OTGW via a HUB.
http://wiki.openwrt.org/toh/tp-link/tl-wr703n
"USB 2.0 port (High-Speed only, use an external High-Speed hub for Full/Low-Speed devices)"
This one will work
http://www.bol.com/nl/p/belkin-usb-2-0- ... 012517293/ however it seems the price exploded 4 times since I bought it.
It can be fixed by brewing your own build of open-wrt, or DISABLE the Wireless functionality that will also work.
I tested the last solution several months with my smartmeter (also USB) and a friend of mine who had to use the wireless functionality had to build his own open-wrt. That also solved the issue.
Good luck.
Ok, i will look into this. The OTGW package had an usb hub included but I thought i only needed to connect the otwg so no need for it. I will try this tonight and also have to make ser2net auto starting.
Thanks for your suggestions and solutions
John
Posted: Tuesday 24 June 2014 12:45
by sincze
John
A well if you didn't use the HUB..... & didn't disable WIFI within TP-Link I'lll bet that is causing your problem.
You'll be a happy man tomorrow.
Posted: Wednesday 25 June 2014 11:21
by Sjonnie
Hello
I wanted to let you know that everything is working fine now.
I included the USB hub and used the Lan interface instead of the WIFI option. Now Domoticz keeps polling the Opentherm Gateway. I do keep seeing the "end of file" error in the log but I think that is due to the fact that the polling cycle has ended. Other devices get polled then and after that the connection to OpenWRT is re-established and new polling cycle start. Like so:
- Log
- Knipsel2.JPG (157.74 KiB) Viewed 7882 times
Thanks again for your great help and support!!
Best Regards
John
Posted: Thursday 31 July 2014 17:44
by gizmocuz
I had this issue as well, could you point me to a website how to build this?
Posted: Tuesday 12 August 2014 18:56
by sincze
gizmocuz wrote:I had this issue as well, could you point me to a website how to build this?
You mean a TP-Link 703 using WIFI and a dropping USB connection without a low-speed USB-Hub ?
Posted: Tuesday 12 August 2014 18:59
by gizmocuz
I did not enable wifi... but dropping usb yes
i added a cronjob to reboot every 3 hours and xxx minutes, this seems to work excelent
Posted: Wednesday 13 August 2014 20:49
by sincze
gizmocuz wrote:I did not enable wifi... but dropping usb yes
A well a different solution. GOOD to know.
Are you using an USB-Hub as mentioned here:
http://wiki.openwrt.org/toh/tp-link/tl-wr703n (currently down).
Reboot shouldn't be necessary
Posted: Monday 18 August 2014 20:48
by tcviper
Can somebody tell me exactly what i would need to control my Bosch HRC heater with opentherm and then use it in domoticz?
I simply need this?
http://www.opentherm-gateway.com/openth ... t-lan.html
I can use a tablet/phone with domoticz to control temperature and set program?
Posted: Saturday 23 August 2014 16:11
by tcviper
Hello all,
When i install the opentherm gateway (with Lan) and add it to domoticz i get:
Sat Aug 23 16:09:31 2014 OTGW: Invalid test
Sat Aug 23 16:09:31 2014 OTGW: Opentherm gateway diagnostics - Version 1.0
Sat Aug 23 16:09:31 2014 OTGW: 1. LED test
Sat Aug 23 16:09:31 2014 OTGW: 2. Bit timing thermostat
Sat Aug 23 16:09:31 2014 OTGW: 3. Bit timing boiler
Sat Aug 23 16:09:31 2014 OTGW: 4. Delay symmetry
Sat Aug 23 16:09:31 2014 OTGW: 5. Voltage leves
Sat Aug 23 16:09:47 2014 Error: OTGW: Error: End of file
Any idea what this is and how to fix it?
Thx!
How did you guys flash it to 4.0? When i do that i keep getting: Click program to download the firmware and then please manually reset the opentherm gateway.... no idea but removing power doesnt do anything?! i get could not switch gateway to self-programming mode over and over...
plus i keep getting can not find channel named sock468 over and over in a popup..
Posted: Saturday 23 August 2014 21:34
by sincze
tcviper wrote:Hello all,
Thx!
Connect OTGW directly to USB port of windows machine and use the tool to flash the latest firmware.
http://otgw.tclcode.com/download.html
http://otgw.tclcode.com/download/otmonitor.exe
If it is unable to reboot itself remove 220v cable. Leave it for a few seconds and reconnect.
It will start flashing the latest firmware
Posted: Sunday 24 August 2014 11:57
by tcviper
I srsly dont get it, how do you connect it with USB by using opentherm monitor tool? under connect i see only COM1 and TCP Connection.
When i plug in the USB in the pc it says installing device, but when i choose COM1 in connection again nothing happens, and there is no COM3 to select like in the attachment below.
If i now try the firmware upgrade it says once again, please manually reset the opentherm gateway, i unplug the power cord, and put it back in (5 secs later), still nothing: Could not switch gateway to self programming mode.
Niks anders dan problemen met dit ding helaas
Zie in Windows bij hardware ook dit als ik usb inprik:
Posted: Sunday 24 August 2014 15:16
by sincze
tcviper wrote:I srsly dont get it, how do you connect it with USB by using opentherm monitor tool? under connect i see only COM1 and TCP Connection.
Mmm
- Remove all Com ports from windows device manager
- Restart computer
- Check available COM ports
- Plugin OTGW via USB
- See what Comport is added. If none you have to install the driver.
- Start OTMonitor
- Connect via the new Comport.
- Do you now actually receive data?
- If so flashing should be possible exactly as you described FLASH, remove power cord, attach power cord.
http://otgw.tclcode.com/otmonitor.html#upgrade
If no COM port is added we might have to download some additional drivers.
Posted: Sunday 24 August 2014 15:22
by tcviper
Tried what you suggested, removed all com ports in Windows, then restart... again the same Prolific USB-to-serial thing shows up under devices when i plug in the otgw.
There is no driver on the otmonitor page, out of ideas here. What is also strange if you ask me is that it shows up with and without pluggin in the 230v power.
Under hardware properties of this COM3 device i see:
This device cannot start. (Code 10)
A device which does not exist was specified.
Update, for those running windows 8.1 and have same problem, try this:
http://answers.microsoft.com/en-us/wind ... 34f8137645
I got the device working now i see over 22 devices in Domoticz all for opentherm gateway. How can i now best add all this and make domoticz a thermostat so it does things when for example temperature goes below xx?
Posted: Sunday 24 August 2014 21:51
by sincze
tcviper wrote:Tried what you suggested, removed all com ports in Windows, then restart... again the same Prolific USB-to-serial thing shows up under devices when i plug in the otgw.
Great you got it working.
Driver including Windows 8 warning
http://www.prolific.com.tw/US/ShowProdu ... 25&pcid=41
Windows 8/8.1 are NOT supported in PL-2303HXA and PL-2303X EOL chip versions
Now the fun part starts.
Not do disappoint you.
IMO Domoticz is not optimized to be a thermostat. It can read the values perfectly.
Draw nice graphs however the rest you have to build yourself in event or LUAs
Posted: Monday 25 August 2014 15:28
by tcviper
For now im gonna keep using my Toon Thermostat instead of this, atm its a bit to difficult/complicated for me to make this work as its own thermostat plus Toon can communicate with domoticz fine.
Posted: Monday 25 August 2014 23:15
by MarQuez
@ gizmocuz
Did you already started with the thermostat overview?
Also as already some people requested before is it possible to add a +/- button in order to change the temprature?
Last question i have is if it's possible to use blocky for scheduling as i tested this but nothing happened when trying to change the control setpoint.
Posted: Tuesday 07 October 2014 17:07
by Lampie
Honeywell has a new system for heating systems:
http://www.evohome.info/nl/
Each room can have it's own radiator controller:
https://products.ecc.emea.honeywell.com ... _hr92.html
Is it possible to connect Domoticz with these controllers? And let Domoticz control the temperature in the entire house?
Posted: Tuesday 21 October 2014 9:40
by gizmocuz
MarQuez wrote:@ gizmocuz
Also as already some people requested before is it possible to add a +/- button in order to change the temperature?
Not yet, but i think you can now control the setpoint from lua
commandArray['UpdateDevice'] = '2161|0|22.3'
where 2161 is your setpoint
(From version #2063+)
Posted: Thursday 23 October 2014 0:31
by MarQuez
For now i created a few scene buttons which send a HTTP command to set the desired temperature, these i then can use in blocky.
What does |0|22.3 mean behind the setpoint, also is 22.3 not the setpoint?
Posted: Thursday 23 October 2014 8:04
by gizmocuz
22.3 is the setpoint, see the wiki about events:
http://www.domoticz.com/wiki/Events
