Python plugin: Sony Bravia TV
simon_rb
Re: Python plugin: Sony Bravia TV
Post by simon_rb »
Is this plugin working for people with the new stable release? Its crashing my Domoticz so I've had to remove it for the time being.
Many Thanks
rkx1rkx1
Domoticz version: 3.8153
Post by rkx1rkx1 »
Simon_rb,
Since updating to the latest stable release, the Bravia plug in from gerard33 is no longer working for me either. Which is a nightmare! I had to roll back to the previous version of Domoticz as i rely on the plug in to control the TV from home assistant. (Kids are always loosing the remote control!)
There were previous conflicts with DzVentz/PIR plugin and a python segmentation issue. I had to disable DzVentz to get it working in the previous release otherwise a restart didn't bring the Domoticz service up. It could be a similar issue again. I am following this thread to see if anyone comes up with a solution. There are other basic scripts out there that can be pulled together to give some basic functionality but i did love this plug in.
Cheers Rich
simon_rb
Post by simon_rb »
Hi Rich,
Thats a shame, I was hoping it was my setup :(
I don't think the developer uses domoticz anymore so we might need a new, clever sole to take over. Hopefully I'm wrong.
Many Thanks
rkx1rkx1
Post by rkx1rkx1 »
His github also states 'This plugin is no longer maintained'.
I have freshly installed the latest stable Domoticz on a separate Pi and will continue to do some testing to see if it can be fixed otherwise I may start to make my own. Will share if anything good comes of it.
Cheers Rich
simon_rb
Post by simon_rb »
rkx1rkx1 wrote: Tuesday 03 July 2018 13:30 His github also states 'This plugin is no longer maintained'.
Cheers Rich
I noticed the same Rich, I modified the original slightly so that the volume dimmer switch when powered off would turn the TV off and powered on would turn it on. Then using HomeKit I could say turn on the living tv or set living room to to 30 etc.. Worked well :D
Good luck and if you need help testing.. let me know.
Many Thanks
lmet
Domoticz version: v4.9700
Post by lmet »
For me too the plugin does not work anymore. I took over the work of StefanPuntNL (thanks to him) here and after some additions/modifications I have a lua code to turn on and off the TV and a script to change channels including channels greater than 9. It's basic nothing about sound or channel like NetFlix or other features.
It works on my Sony Bravia KDL-50W755c and with Imperihome and Homekit.
If that interests I can publish this work here.
simon_rb
Post by simon_rb »
Hey,
Anything is better than nothing. For me the most important is controlling volume from within Domoticz
Cheers
rkx1rkx1
Post by rkx1rkx1 »
I don't suppose anyone got anywhere with this did they?
febalci
Post by febalci »
Ubuntu 18.04; Domoticz 4.9701 stable. The plugin still works on my android Sony.
Dnpwwo
Post by Dnpwwo »
If people with this failing on a recent beta (or last stable) enable debugging for the plugin and post some log output it might be possible to diagnose the problem.
lmet
Post by lmet »
Maybe a conflict related to version 3.5 of python and stretch see here at "Troubleshooting" section.
Tested successfully with another python plugin. Not with this one because I'm using lua code now.
Dnpwwo
Post by Dnpwwo »
That information is out of date and I have updated the wiki page.
Issues on Stretch were SSL library related and were resolved prior to the last stable release.
rkx1rkx1
Post by rkx1rkx1 »
After a day of fiddling (installing domoticz from source/different raspian versions) I managed to get the Sony-Bravia plugin working.
I used etcher to install the latest stretch lite onto a 64gb class 10. Expanded the filesystem and set all the settings correctly in Raspi-config.
Did the easy install of domoticz curl -L install.domoticz.com | sudo bash
Do all the other config bits you normally do to get you up and running (Upload database/configure your hardware/install apache and certbot ssl etc.)
Then the key for me was to sudo apt-get install python3-dev this stopped the complaining about (Failed dynamic library load, install the latest libpython3.x library)
Do not bother changing the libpython version or running a -dev this only makes things worse and any python plugin seems to crash the system.
Now I have the latest Stable with working plugins. There are quite a few lua scripts out there that can fulfil most of these just from EVENTS in domoticz. For those that dont get that involved the above is working a treat for me.
Sony plug in.png (74.28 KiB) Viewed 3918 times
lmet
Post by lmet »
Dnpwwo wrote: Sunday 29 July 2018 23:26 That information is out of date and I have updated the wiki page.
Maybe only one eye is not enough ;) Never talk about SSL library but python version issue.
simon_rb
Post by simon_rb »
rkx1rkx1 wrote: Wednesday 01 August 2018 16:29 After a day of fiddling (installing domoticz from source/different raspian versions) I managed to get the Sony-Bravia plugin working.
Now I have the latest Stable with working plugins. There are quite a few lua scripts out there that can fulfil most of these just from EVENTS in domoticz. For those that dont get that involved the above is working a treat for me.Sony plug in.png
Are we saying its a Python issue? Wonder if I can remove python from my Jessie setup and start fresh with that?!? I have a lot setup on my Raspberry Pi and to change it to Stretch would be a pain. I try not to update until its absolutely necessary lol
Cheers
simon_rb
Post by simon_rb »
Hey,
Got this semi-working but have you noticed there is no volume slider anymore?
To get this working I followed your instructions.
Cheers
Update:- Just seen volume slider False in the settings... Whoops my bad
daan256
Post by daan256 »
Wanted to add the plugin to my latest stable domoticz. However can't seem to find to add it in the hardware tab... it's not listed.
Any work around available?
Looking forward to some hints.
Much appreciated.
antipiot
Domoticz version: Stable
Post by antipiot »
Hello Everybody!
Just installed this plugin on latest stable: My TV is a Sony KD-60XF8305
Everything connects fine and every control i've tested so far work but......
when i shutdown TV using plugin: i can't power it ON back using domoticz; remote control immediately wake the TV back.
Here's what i got in log using debug:
2018-10-02 17:51:08.254 Status: User: admin initiated a switch command (305/TV - Status/Off)
2018-10-02 17:51:12.415 (TV) Pushing 'onCommandCallback' on to queue
2018-10-02 17:51:12.438 (TV) Processing 'onCommandCallback' message
2018-10-02 17:51:12.439 (TV) Calling message handler 'onCommand'.
2018-10-02 17:51:12.439 (TV) onCommand called for Unit 1: Parameter 'On', Level: 0
2018-10-02 17:51:12.414 Status: User: admin initiated a switch command (305/TV - Status/On)
2018-10-02 17:51:21.674 (TV) Pushing 'onCommandCallback' on to queue
2018-10-02 17:51:21.705 (TV) Processing 'onCommandCallback' message
2018-10-02 17:51:21.705 (TV) Calling message handler 'onCommand'.
2018-10-02 17:51:21.705 (TV) onCommand called for Unit 1: Parameter 'On', Level: 0
2018-10-02 17:51:21.673 Status: User: admin initiated a switch command (305/TV - Status/On)
2018-10-02 17:51:24.065 (TV) Pushing 'onHeartbeatCallback' on to queue
2018-10-02 17:51:24.109 (TV) Processing 'onHeartbeatCallback' message
2018-10-02 17:51:24.109 (TV) Calling message handler 'onHeartbeat'.
2018-10-02 17:51:24.122 (TV) Status TV: standby
2018-10-02 17:51:54.074 (TV) Pushing 'onHeartbeatCallback' on to queue
2018-10-02 17:51:54.076 (TV) Processing 'onHeartbeatCallback' message
2018-10-02 17:51:54.076 (TV) Calling message handler 'onHeartbeat'.
2018-10-02 17:51:54.090 (TV) Status TV: standby
Any hint?
Nervermind:
G3rard
Domoticz version: V3.8153
Contact: Contact G3rard
Post by G3rard » Thursday 10 August 2017 20:50
Enter 'Android' (without quotes) in the MAC address field on the Hardware page in Domoticz and press Update.
Then turning the TV on should work.
To make localtest.py work, enter 'chmod +x localtest.py' on the command line via SSH. Then ./localtest.py should work.
Works perfectly! You can add Sony Android TV KD-60XF8305 as working
kdschlosser
Post by kdschlosser »
Because this plugin is no longer being maintained. And I have seen some posts from people possibly remaking this plugin.
This should help you. It exposes every single feature of the Sony TV's. I do mean everything.
https://github.com/kdschlosser/SonyAPI. There is a branch that I started work on and I have not finished up yet. the branch contains code that expands the library to include all Sony products that have the capability of bring controlled over IP
alarm_guy1
Post by alarm_guy1 »
I know this is an old thread and Github declares this as "No longer maintained", however does anyone know in Blockly how to change the source.
I have as per the attached image and it wont change the input.
cheers
blockly 1.jpg (40.49 KiB) Viewed 2801 times
