Page 10 of 13
Re: TOON died within Domoticz
Posted: Monday 19 June 2017 17:50
by Maglor
OK... I was also having some issues with the connection... and for me, it came suddenly.
But then I remembered I changed my password to a stronger one.
Looks like the connection can't be set up if you are using special characters in the password. (or 16 characters is to much).
I changed the password to a 12 characters A-Z a-z 0-9 one, and it worked perfectly.
Just wanted to throw it in here, Maybe it helps some people or the developer to troubleshoot.
Posted: Monday 19 June 2017 17:57
by EdwinK
Thanks. Unfortunately no solution for me.
Posted: Monday 19 June 2017 18:49
by Mooseknuckle
Thanks for the tip but also no luck for me. The stupid thing is that when I stop en start Toon in the hardware tab it works but only once, after that I get "error login". I'm glad setting the setpoint still works from Domoticz.
Posted: Monday 19 June 2017 19:38
by SteGe
Nope, had the hope this was working for me, but unfortunately it didn't.... Really hope that some developer want to implement the API of Toon in Domoticz....
Posted: Monday 19 June 2017 20:49
by EdwinK
I hope so too, but seeing the agreement, you can only get around 1.000 users, after that you need to pay Quiby/Eneco. I've asked the developer of Domticz about this earlier.
Posted: Thursday 03 August 2017 22:33
by dressie
My logfile is filled with this:
2017-08-03 22:10:16.134 Error: ToonThermostat: retrieveToonState request not successful, restarting..!
2017-08-03 22:16:49.126 Error: ToonThermostat: retrieveToonState request not successful, restarting..!
2017-08-03 22:23:22.323 Error: ToonThermostat: retrieveToonState request not successful, restarting..!
Everything works though, controlling it and receiving power and gas usage updates. Does this still got to do with the max of 1000?
Posted: Thursday 03 August 2017 22:36
by EdwinK
Nope. The max. of 1000 users is for the new API that Eneco uses. Your error is something else, but... if things are working, I wouldn't touch it.
Posted: Thursday 03 August 2017 23:20
by Plantje
Hey... did you get rid of your Toon? As I see it is striked through
Posted: Friday 04 August 2017 14:55
by EdwinK
Nope, still have it, but since it doesn't work with Domoticz anymore. Until it's working again, I keep it striked through.
Posted: Friday 04 August 2017 18:24
by Plantje
Understandable. I hardly ever use my Toon. Perhaps that will increase again as soon as it becomes winter.
I hope domoticz will be able to pull in the weekly program as well
Posted: Friday 04 August 2017 18:35
by EdwinK
Plantje wrote:Understandable. I hardly ever use my Toon. Perhaps that will increase again as soon as it becomes winter.
Toon is off here as well. I hope before winter comes that Toon and Domoticz work again
Posted: Saturday 12 August 2017 7:33
by tlpeter
dressie wrote: Thursday 03 August 2017 22:33
Did you ever fix this as i have the same.
Toon works (installed yesterday) but i want to know why this is happening.
Posted: Saturday 12 August 2017 8:53
by dressie
tlpeter wrote: Saturday 12 August 2017 7:33
Nope, my logfiles are still filled with these lines. Everything works, I even re-installed the hardware, but I keep getting these errors.
Posted: Saturday 12 August 2017 9:08
by tlpeter
It is a strange error and it looks like it is a Domoticz issue. Maybe too many calls in a certain amount of time.
But if it works then it is fine for me.
Thanks.
Posted: Saturday 19 August 2017 21:22
by Martijn85
I have the same message: Error: ToonThermostat: retrieveToonState request not successful, restarting..!
Also here toon (in Domoticz) is working fine!
Posted: Sunday 20 August 2017 17:08
by EdwinK
You know what... all of a sudden Toon devices are showing up again!!!
Cause for celebration, or better wait and see
Posted: Monday 21 August 2017 10:06
by tlpeter
I have only one issue.
In the morning then Toon switches from sleep to whatever is set but in Domoticz it stays on sleep.
I can set it manually form Domoticz or on Toon and then it switches but somehow the first switch from sleep doesn't seem to work.
Posted: Thursday 24 August 2017 8:45
by tlpeter
And it is down again but i cannot even login to mijn eneco anymore.
Posted: Thursday 24 August 2017 8:56
by EdwinK
Down here too
Posted: Thursday 24 August 2017 9:12
by tlpeter
This must be a login problem as i cannot login to eneco website either.
