Page 90 of 184
Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Monday 01 May 2017 22:15
by htilburgs
HansieNL wrote:Derik wrote:robgeerts wrote:I've installed Dashticz outside Domoticz-folder. Every folder you can reach via your webbrowser is suitable to put Dashticz in... you dont need to run a webserver for it
So there is no problem?
Please a example
What map and place u use..
xx
x
Just updated Domoticz beta and my Dashticz folder is still in place.
Me also, no problems
Posted: Monday 01 May 2017 22:46
by Blueone
robgeerts wrote:NEW FUNCTION IN BETA!
Want your block to show up differently then Dashticz generates and do you have a little bit of coding skills?
Add to custom.js the following function:
function getBlock_233(device,idx){ //change 233 to the idx of your device!
$('.block_'+idx).attr('onclick','switchDevice(this)');
var html='';
html+='<div class="col-xs-4 col-icon">';
if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon');
else html+=iconORimage(idx,'fa-toggle-on','','on icon');
html+='</div>';
html+='<div class="col-xs-8 col-data">';
html+='<strong class="title">'+device['Name']+'</strong><br />';
if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
else html+='<span class="state">AANWEZIG</span>';
if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
html+='</div>';
return html;
Change '233' in the function-name to the idx of your device!
This is a sample-function, you can do whatever you want inside this function.
In the show your dashboard topic you can show what you've created. If it may usefull for other users to, I can include it in the core of Dashticz!
Thanks! Now I can create something for the burner state based on a other switch
Posted: Monday 01 May 2017 23:08
by robgeerts
Please show the result when finished
Posted: Tuesday 02 May 2017 7:55
by Teunissm
Hello, what a great dasboard is this.
I almost bot it set up. There is only one question.
Is it possible to set up rgb Lights like hue or mi-light and Control also the colors, now i only can turn the lights on or of and the dim slider works.
Really a Great job on this dasboard, Thanx.
Marcel
Posted: Tuesday 02 May 2017 8:04
by HansieNL
Not yet. It's on the todo list
https://github.com/robgeerts/dashticz_v2/issues/3
Posted: Tuesday 02 May 2017 8:30
by bsmeding
var html='';
html+='</div>';
html+='</div>';
return html;
That would be great, then it would also be possible to only show the status of a switch without name or time last changed?
Because i would like to use a 1-column row with the status of devices on- or offline in the network and also a 1-column for the status of door- and window state. Therefor the text and padding needs to be smaller.
Will try this in beta, thanks for this very nice dashboard!
Posted: Tuesday 02 May 2017 8:38
by woody4165
Hi all.
Fantastic dashboard, easy to customize.
Some questions:
I just updated my Domoticz beta via CLI and the Dashticz folder in www is still there. I have read in the github page that www folder should be overwritten losing that folder. Does it happen only when updating via Web interface?
I have some temperature block, but I would like to show only temp and no humidity. In this case I can't activate the temp graph. Is there a way to show it up?
I have an OWL to measure electricity consumption, it shows in dashticz current_now, current_today and total, but no graph. Is it possibile to how them up?
Posted: Tuesday 02 May 2017 8:46
by robgeerts
Just merged the beta with the master, so that one is up-to-date too.
Fixes can be found here:
https://github.com/robgeerts/dashticz_v ... s%3Aclosed
Now I'm going to work on the RGB-slider for Hue/Mi-light lamps in BETA.
Posted: Tuesday 02 May 2017 8:50
by bsmeding
Just tested this code in beta and it does exactly what i need! Thanks Rob!
- Schermafbeelding 2017-05-02 om 08.47.50.png (30.65 KiB) Viewed 3590 times
Posted: Tuesday 02 May 2017 9:04
by bsmeding
custom file change request
is it possible to separate the CONFIG.js file from the real configuration settings and a new file for the block, column and screen layout? (layout.js maybe? )
This because I use the master and beta branch both a lot now, and it would be easier when i only have to create the block layout once for both (create symbolic link between master and beta folder) and the custom.js setting can be changed when by an update with new functions
Posted: Tuesday 02 May 2017 9:12
by poudenes
robgeerts wrote:
Is now available in the beta-version!
The weather icons are COOL
Posted: Tuesday 02 May 2017 9:25
by EdwinK
woody4165 wrote:Hi all.
Some questions:
Perhaps something changed in the way how Domoticz updates. Maybe ignoring the www folder.
Posted: Tuesday 02 May 2017 9:31
by robgeerts
First preview of color changer:
Posted: Tuesday 02 May 2017 9:32
by poudenes
Posted: Tuesday 02 May 2017 9:33
by woody4165
Another question about calendar events
I see that I need to use crossorigin.me before the calendar ics url.
What about privacy policy of this service, since I'm providing a private calendar url ?
I haven't found anything on their website?
Posted: Tuesday 02 May 2017 9:40
by EdwinK
robgeerts wrote:First preview of color changer:
Looks neat, although I'm not very fond of this kind of color-things. I would prefer something like this
- Screen Shot 2017-05-02 at 09.38.41.png (18.18 KiB) Viewed 3559 times
(couldn't find a better example right now)
Posted: Tuesday 02 May 2017 9:46
by robgeerts
I think you must have the possibility to change to EVERY color you want.
Although, it will be possible to predefine colors you use the most in config.js.
Posted: Tuesday 02 May 2017 10:15
by Blueone
robgeerts wrote:Please show the result when finished
Oke, almost done (only have to create the icons)
I use the OTGW so I have a switch active when the Central heating is active and a switch when the Hot Water is active (The boiler gives a higher priority to the Hot Water), so when both are active the icon for the hot water have to be shown. This is my custom.js at the moment (copied the setpoint code from main.js and added some icon code, just a few lines needed.
//add custom javascript in here
function afterGetDevices(){
function getBlock_628(device,idx){ //Setpoint block
//CHstate = getDevicestatus(224)
//DHWstate = getDevicestatus(225)
//debug with dummy devices
CHstate = getDevicestatus(631)
DHWstate = getDevicestatus(632)
console.log('CHstate: ' + CHstate)
console.log('DHWstate: ' + DHWstate)
var html='';
html+=iconORimage(idx+'_1','','heating.png','on icon','style="max-height:35px;"');
if(typeof(blocks[idx])!=='undefined' && typeof(blocks[idx]['switch'])!=='undefined' && blocks[idx]['switch']==true){
html+='<span class="state">'+device['Data']+_TEMP_SYMBOL+'</span>';
else {
html+='<strong class="title">'+device['Data']+_TEMP_SYMBOL+'</strong><br />';
html+='<span class="state">'+device['Name']+'</span>';
if(_SHOW_LASTUPDATE && (typeof(blocks[idx])=='undefined' || typeof(blocks[idx]['hide_lastupdate'])=='undefined' || blocks[idx]['hide_lastupdate']===false)){
html+='</div>';
$('div.block_'+idx+'_1').html(html);
addHTML=false;
html='';
var random = getRandomInt(1,100000);
html+='<ul class="col-thermostat input-groupBtn">';
html+='<li class="up"><a href="javascript:void(0)" class="btn btn-number plus" data-type="plus" data-field="quant['+device['idx']+']" onclick="this.blur();">';
html+='<em class="fa fa-plus fa-small fa-thermostat"></em>';
html+='</a></li>';
html+='<li class="down"><a href="javascript:void(0)" class="btn btn-number min" data-type="minus" data-field="quant['+device['idx']+']" onclick="this.blur();">';
html+='<em class="fa fa-minus fa-small fa-thermostat"></em>';
html+='</a></li>';
html+='</ul>';
//Extra code for dynamic Icons
if(DHWstate == 'On') {
html+=iconORimage(idx+'_2','','Hot_Water.png','on icon iconheating','','2');
else if(CHstate == 'On') {
html+=iconORimage(idx+'_2','','CHActive.png','on icon iconheating','','2');
else {
html+=iconORimage(idx+'_2','','heating.png','on icon iconheating','','2');
html+='<strong class="title input-number title-input" min="12" max="25" data-light="'+device['idx']+'">'+device['Data']+_TEMP_SYMBOL+'</strong>';
html+='<div class="state stateheating">'+device['Name']+'</div>';
html+='</div>';
$('div.block_'+idx+'_2').addClass('thermostat'+random).html(html);
$('div.block_'+idx).addClass('thermostat'+random).html(html);
addHTML=false;
addThermostatFunctions('.thermostat'+random);
return html;
function getExtendedBlockTypes(blocktypes){
//blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
return blocktypes;
function getDevicestatus(idx){
for(r in data.result){
var device = data.result[r];
if(device['idx'] == idx){
return (device['Status'])
Maybe you can use something like this for the color picker:
- 2017-05-02 10_17_31-iconnecthue color - Google zoeken.png (117.13 KiB) Viewed 3510 times
Posted: Tuesday 02 May 2017 10:20
by SuperMouse
bsmeding,
Can you show me the custom.js ?
And maybe show the complete screen in :
Show your Dashticz v2.0 and how-to's!
https://www.domoticz.com/forum/viewtopi ... =8&t=17242
Posted: Tuesday 02 May 2017 10:35
by poudenes
mvveelen wrote:
Confirmed. We wait patiently for a fix. Rob is probably enjoying the weekend, as he should
As for the size of the text of the headers / calendar titles, would be nice if this could be resizable with a setting in CONFIG.js and maybe make it an option to have a title or not. As far as I'm concerned, I'd rather have the calendars merged, but maybe I'm over-asking
About the afvalwijzer - add-on: could this script be altered so that the switch isn't a 'selectable' switch anymore, but a text-switch? Now, you can select from the drop-down-menu, and it would be nicer if this wasn't selectable, but just a simple value: 'GFT', or 'Restafval', or 'Plastic', etc. Just my 2 cents.
I'm using now the iCal function and see something strange. I have multiple items on 1 day. Its only showing the 1st item on a day and then select the next one on other day etc. Does the script not supporting multiple agenda items on same day?
