islandman
Post by islandman »
corbin wrote: Saturday 19 August 2017 4:47 Thanks, I've submitted the changes to be included in the main beta, there is a problem compiling but I don't think it is related to my changes.
Also if it does get added to the beta, existing wall switches will need to be deleted and re-added in Domoticz due to the new unit codes being used.
Great Job, re-added my 12 Switches :roll: and also my single Wall Switches with neutral are working now!!!! :mrgreen:
pandemicz
Post by pandemicz »
Guys, I'm a little confused with all the switches :oops: Just to be sure, is there solution for Wireless Two-Button Switch LEFT click problem with 149 firmware in latest build or we all suppose to wait for an update from Xiaomi?
deennoo
Post by deennoo »
pandemicz wrote:Guys, I'm a little confused with all the switches :oops: Just to be sure, is there solution for Wireless Two-Button Switch LEFT click problem with 149 firmware in latest build or we all suppose to wait for an update from Xiaomi?
You have to wait about a Fw update, that not à domoticz problème.
http://domo-attitude.fr
Luigi87
Post by Luigi87 »
I have just ordered the Xiaomi Gateway. But it seems the gateway has an AU plug. Is there an EU plug?
Of do you have to put allways an adapter between the Power plug/ and the power socket?
pandemicz
Post by pandemicz »
Luigi87 wrote: Tuesday 22 August 2017 16:31 I have just ordered the Xiaomi Gateway. But it seems the gateway has an AU plug. Is there an EU plug?
Yes, we have to put an adapter, there's only Chinese version available.
Pyros
Post by Pyros »
Hello
Just bought that new model of XIAOMI (EDIT) ceiling : https://www.gearbest.com/flush-ceiling- ... 33589.html
Unfortunatly, it's no more seen in yeelight app but in smart home only.
Since it's not a device managed by the gateway nor a pure yeelight device, it's not visible in domoticz.
Any advice to manage it ?
thx
deennoo
Post by deennoo »
Pyros wrote:Hello
Just bought that new model of yeelight ceiling : https://www.gearbest.com/flush-ceiling- ... 33589.html
thx
Where have you read that à yeelight device ? That à Philips One...once again search about product before buy a price...now you have :
- to search some source (i already give some)
- dévelop à python plugin for this, (thanks you)
pandemicz
Post by pandemicz »
Pyros wrote: Wednesday 23 August 2017 0:51 Hello
thx
Been there, bought xioami philips table lamp once, thought it's compatible with yeelight, unfortunately no developer gateway for xiaomi-philips products :(
Pyros
Post by Pyros »
deennoo wrote: Wednesday 23 August 2017 7:45 Where have you read that à yeelight device ? That à Philips One...once again search about product before buy a price...now you have :
Some guys worked on it : https://github.com/aholstenson/miio/issues/57
I've just succeded with light on/light off the ceiling with miio.
So next step is to work on domoticz plugin with those informations
Mozart
Post by Mozart »
Pyros wrote: Wednesday 23 August 2017 15:11
A priori y a du monde qui bosse dessus : https://github.com/aholstenson/miio/issues/57 et qui a trouvé des infos.
Je vais regarder coté plugin mais je risque d'être léger en niveau
Please use english in this forum so everyone can understand what you say.
Raspberry 3
Aeon Labs Z-Wave Stick Series 2 - RFLink USB Gateway
Z-Wave switches
433 MHz Temperature + Humidity sensors
Philips Hue Lights
Mi-Light WiFi Bridge + RGBW Controllers
snuiter
Post by snuiter »
So I installed some Xiaomi stuff, like the gateway, a switch button and some other devices, all are working pretty good. My question is now how can i control the coloring of the gateway light in my script I have tried a couple of things. I want to change color on specific occassions.
Any suggestions as I want to change the colors of the gateway light via a script?
hekm77
Post by hekm77 »
snuiter wrote: Wednesday 23 August 2017 22:04 So I installed some Xiaomi stuff, like the gateway, a switch button and some other devices, all are working pretty good. My question is now how can i control the coloring of the gateway light in my script I have tried a couple of things. I want to change color on specific occassions.
Xiaomi Gateway Light Scenes
http://4pda.ru/forum/index.php?act=find ... 60482495-2
snuiter
Post by snuiter »
Had to analyze the script and play with it to understand how it worked. But it does. Thanks hekm77!
hekm77
Post by hekm77 »
snuiter wrote: Thursday 24 August 2017 9:57 Had to analyze the script and play with it to understand how it worked. But it does. Thanks hekm77!
Create a dummy selector switch with levels
xraken
Post by xraken »
Hello, I tried to follow the instructions from the Wiki https://www.domoticz.com/wiki/Xiaomi_Ga ... ateway_MP3 to make the gateway playback a recorded message using a dimmer control from Domoticz. I am not getting any sound from the gateway though when I move the slider. I do see the log messages corresponding to the script so I know the script is firing off the command to play back "10001", "10002" etc.. Has anyone got this to work and if yes please help.
I am able to change the ringtone etc. to the recorded message via the Xiaomi App so I know that the recording is on the gateway.
xbox2610
Post by xbox2610 »
Hi everyone i would like to ask if xiaomi smart plug (zigbee) works with Domoticz?
deennoo
Post by deennoo »
xbox2610 wrote:Hi everyone i would like to ask if xiaomi smart plug (zigbee) works with Domoticz?
Yes it is using last stable
xbox2610
Post by xbox2610 »
Thank
mikeoo
Post by mikeoo »
I am using the Xiaomi Smart Home Gateway 2 now for a while with door sensors and temp sensors. I notice then the updates on the dashboard are not always the latest.
When i open Domoticz you see the date and time when the sensor is last seen. Some temp sensors are correct and one is 30 min behind. The happens random with them. But when I open the chart I the time is correct.
Anyone have a explanation for it.
xbox2610
Post by xbox2610 »
Hi all, I have a few days restarted domoticz + homebridge + mqtt + broadlink and it all works well apart from the gateway functionality (sound effects + RGB light) and xiaomi smart plug somebody to the same problem?
Thank you
