phalseb
Re: Domoticz app 2.0
ok
How do you do?
In domocticz app I have:
Server connection settings
server adress : ???? xxx.ddns.net
protocol: HTTP
Port: ??
Username: domoticz
password domoticz
it's ok for internal ip or public IP but no for XX.ddns.net
can you help me please?
tank"s
How do you do?
protocol: HTTP
Port: ??
Username: domoticz
password domoticz
tank"s
- MarcelMAH
- Domoticz version: v3.8025
Your DNS should resolve to your Internet connection IP address.
The port should be open and forwarded in your router to your Domoticz setup (internal and external port need to be the same!).
When you are at home it might not work because your DNS name will (should) resolve your external IP and depending on your routers support for local NAT loopback, it will connect, or not.
Running Domoticz on Ubuntu 16.04 on VMware with RFXCOM - RFXtrx433 and Aeotec Z-Stick Gen5
phalseb
my No-ip xxx.ddns.net works qand I'm outside on internet explorer, chrome, ... it's ok for explorers but not for Domoticz app.
I tried to put my No-ip xxx.ddns.net in the app:
server address: ???? xxx.ddns.net
protocol: HTTP
Port: XXXX
Username: doXXXmoticz
password: doXXXmoticz
When I try with the external public ip (83.XXX.XX.XX) it works.
The problem is that this address changes. That's why I want to put the no-ip address.
can you help me
protocol: HTTP
Port: XXXX
can you help me
- MarcelMAH
It works for me...
salvacalatayud
Hello, I'm not sure if this is a bug, but when I enter in the rooms tab, scenes that exist into a room don't show in the app.
For example I have a bedroom where there are 5 devices and 1 scene, in the app shows that there are 6 devices but if I enter only 5 devices appear.
Enviado desde mi Redmi 4X mediante Tapatalk
- cpighin
- Domoticz version: 3.8153
For the benefit of other non-expert users like me, I report what I did, with the irreplaceable help of an expert, to access my Domoticz by remote.cpighin wrote: Tuesday 06 February 2018 9:44 Thanks to the help of woody4165 I successfully started the Domoticz app for Android![]()
For the benefit of other non-expert users like me, I report what I learned:
1) There is no relationship between Mydomoticz (activated by the Domoticz web application) and the Domoticz app for Android.
2) In the Install Wizard screen of the app, in the IP address field, you can type in the one used with the Domoticz web application, for a connection via the local network. Otherwise you can type in a different IP address (I still do not understand exactly how to do it) for a connection from outside the house. The other parameters to be entered are 8080 and http.
The username and password fields must be filled in only if they have been set in the Domoticz web application settings.
Claudio![]()
1) In Domoticz (Configuration> Settings> System> Site Protection) I filled in fields Username with "aaaaa", Password with "bbbbb" and set field Authentication with "Basic-Auth". Then I saved and applied changes.
2) on the web I searched for a dynamic DNS provider and created "test.ddns.net"
3) In the configuration of my router I searched for a section to be used for a Port Forwarding and there I added "Domoticz" as application, port "8080", protocol "Both", "Enable forwarding". Then I saved and applied changes.
4) In the configuration of my router I also searched for a DHCP Server section, to assign a static address to my Raspberry. There I added the MAC Address of my RPi3, in field Host Name I typed "RASPBERRY" than the IP Address used to access it locally with my browser "192.168.1.xxx". Then I saved and applied changes.
After the above actions I started the App Domoticz in my android phone and entered the following data on the "Server Setup" page:
server address: test.ddns.net
Port: 8080
Username: aaaaa
Password: bbbbb
than I pressed the right arrow at the bottom and ... in few seconds the app connected my phone to my Domoticz by remote
Claudio
phalseb
[/quote]
2) on the web I searched for a dynamic DNS provider and created "test.ddns.net" (no-ip installed on raspberry (http://www.noip.com/support/knowledgeba ... te-client/))
Port: 8080
Username: aaaaa
Password: bbbbb
Claudio
[/quote]
Hello thank's for your help.
But i still have a problem.
1) OK
2) OK AAAA.ddns.net created (no-ip installed on raspberry (http://www.noip.com/support/knowledgeba ... te-client/))
3) OK (I just changed the port to 8888 in router, an raspberry (with https://easydomoticz.com/forum/viewtopi ... =13&t=2615)
4) OK in DHCP section the raspberry IP is fixed.
On the web page AAA.ddns.net, it's work but no in the app.
server address: AAAA.ddns.net
Port: 8888
Username: aaaaa
Password: bbbbb
I also tried with the https port.
thank's for your help!
Port: 8080
Username: aaaaa
Password: bbbbb
Claudio
[/quote]
1) OK
Port: 8888
Username: aaaaa
Password: bbbbb
pudding
Apologies if this has been covered elsewhere, a quick search didnt reveal anything for me.
I've just bought the full app in order to use geofencing. I'd like to turn on the front door outside light when i get home and it's dark. Is there a way to turn the light on after a certain time/after sunset in addition to the geofence part of me getting with the radius set in the geofence setting? I dont really want the outside light turning on all the time in the daytime when i come home.
Many thanks.
Many thanks.
- cpighin
phalseb,
as wrote above, I am not expert, I just reported what I did with a big help of a frend!
Regarding your problem, have you tried to set the port to 8080 instead of 8888?
Claudio
Claudio
Marque1968
Just to let you know, I enjoyed how you avoided April Fools...
- remb0
We made an interview. pm if you have feedback, please.
https://gadget-freakz.com/2018/04/inter ... rk-heinis/
Thanks Mark!
- C4rtm4N
I'm not sure if it has been asked before but is there any way that certificate based authentication could be included in a future release? I love the app but can't use it when I am away from home as I don't feel comfortable opening up my Domoticz installation to the internet without my cert based reverse proxy to protect me.
Blueone
Re: Re: Re: Domoticz app 2.0
I am still having the issue above, is there a change this type will be added to the app so the arrow up and down is also avaialble for virtual blind devices?Blueone wrote: Friday 30 June 2017 13:53How did you get the up en and down arrow for the blinds? I only have on/off for my blinds. I made an export of the devicetype. Maybe this device type can also be added in the app as blinds with the up and down arrow?Zinken wrote:There isn't any issues with the installation or connection settings. The dashboard loads fine after a while, but it can take a minute.galadril wrote: Please check your connection settings or if there are issues with the domoticz installation.
Nothing changed on the app for this.
From browser (desktop or mobile) the dashboard loads like the wind.
When opening the app, first there is a blank page with ads showing, then a toast with error message and lastly the dashboard loads.
{ "ActTime" : 1498823406, "ServerTime" : "2017-06-30 13:50:06", "Sunrise" : "05:25", "Sunset" : "21:56", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "Open", "Description" : "", "Favorite" : 0, "HardwareID" : 2, "HardwareName" : "Virtual switches", "HardwareType" : "Dummy (Does nothing, use for virtual switches only)", "HardwareTypeVal" : 15, "HaveDimmer" : true, "HaveGroupCmd" : true, "HaveTimeout" : false, "ID" : "000142B3", "Image" : "Light", "IsSubDevice" : false, "LastUpdate" : "2017-06-30 07:00:00", "Level" : 0, "LevelInt" : 0, "MaxDimLevel" : 100, "Name" : "Zonwering", "Notifications" : "false", "PlanID" : "8", "PlanIDs" : [ 8 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "Status" : "Open", "StrParam1" : "aHR0cDovLzEyNy4wLjAuMTo4MDgwL2pzb24uaHRtP3R5cGU9Y29tbWFuZCZwYXJhbT1zd2l0Y2hsaWdodCZpZHg9NjEyJnN3aXRjaGNtZD1Pbg==", "StrParam2" : "aHR0cDovLzEyNy4wLjAuMTo4MDgwL2pzb24uaHRtP3R5cGU9Y29tbWFuZCZwYXJhbT1zd2l0Y2hsaWdodCZpZHg9NjEzJnN3aXRjaGNtZD1Pbg==", "SubType" : "Switch", "SwitchType" : "Blinds", "SwitchTypeVal" : 3, "Timers" : "false", "Type" : "Light/Switch", "TypeImg" : "blinds", "Unit" : 1, "Used" : 1, "UsedByCamera" : false, "XOffset" : "0", "YOffset" : "0", "idx" : "611" } ], "status" : "OK", "title" : "Devices" }
FunFair
I've bought the full version of the app today and got notifications working with 2 android devices. I use it to alert me when the doorbell is rang. So I set up a notification sound that sounds like the chime of a doorbell.
Only thing is that now all notifications have the chime. Is it possible to set different notification sounds for different events?
If not, I think that would be a great feature to add
phalseb
Dear Claudio,cpighin wrote: Saturday 17 March 2018 21:36 phalseb,
Claudio![]()
I tried by changing the ports (8080) on the raspberry, on the site no-ip, on the router.
It still does not work
please help meeeeee
- cpighin
I'm sorry, I'm not expert and hope that other people will help you
Claudio
Claudio
AllesVanZelf
- Domoticz version: 12467
Is it possible to have a dimmer switch widget? With a slider?
edit:
And will there be: MyDomoticz support?
edit:
- galadril
- Domoticz version: latest
Not at this moment, maybe in the future.AllesVanZelf wrote: Wednesday 13 June 2018 11:10 Is it possible to have a dimmer switch widget? With a slider?
(if there are Android devs willing to assist on Widgets, please make a pull request on the android project on github!!)
We should get MyDomoticz support yes.. but the dev op myDomoticz is really busy and has no time to assist me (or implement it)
- galadril
Can everybody that like to translate please help us on Crowndin to get all the languages complete?
https://crowdin.com/project/domoticz-for-android
Translations needed:
Bulgarian (22%)
Catalan (49%)
Danish (61%)
Hebrew (12%)
Norwegian (67%)
Turkish (60%)
New translations needed:
Greek(0%) -> added on request
Croatian(0%) -> added on request
Hebrew(0%) -> added on request
Persian (0%) -> added on request
Serbian (0%) -> added on request
Romanian (0%) -> added on request
Thanks in advance for all the effort put in to these translations!!
Bulgarian (22%)
Catalan (49%)
Danish (61%)
Hebrew (12%)
Norwegian (67%)
Turkish (60%)
Flappie
Is it possible to sort the groups and scenes in the Android app like it's on the webpage?
There is an setting to sort it like the Dashboard. That works for the dashboard, switches, plans and all other pages but doesn't work for scenes and groups. Is this a bug in the app?
