Page 88 of 120
Re: Domoticz app 2.0
Posted: Tuesday 06 February 2018 9:44
by cpighin
Thanks to the help of woody4165 I successfully started the Domoticz app for Android :D
For the benefit of other non-expert users like me, I report what I learned:
1) There is no relationship between Mydomoticz (activated by the Domoticz web application) and the Domoticz app for Android.
2) In the Install Wizard screen of the app, in the IP address field, you can type in the one used with the Domoticz web application, for a connection via the local network. Otherwise you can type in a different IP address (I still do not understand exactly how to do it) for a connection from outside the house. The other parameters to be entered are 8080 and http.
The username and password fields must be filled in only if they have been set in the Domoticz web application settings.
Claudio :)
Posted: Saturday 10 February 2018 14:22
by billouetaudrey
Hi, I need help please...
I run on Miui 9.1, and don't received gcm notification with domoticz lite
I add domoticz to except, launch at boot, but nothing change... And add my mobile to domoticz server
Any idea please?
Thanks very much
Envoyé de mon Redmi Note 4 en utilisant Tapatalk
Posted: Saturday 10 February 2018 18:02
by Bigted
Bigted wrote: Sunday 04 February 2018 13:04 Running version 0.1.430 (3714), when I try to add any scenes to the NFC tag, the scenes are listed, but when I select one, the app reports Connected switch N/A and doesn't switch the scene.
If I set it up to a single switch then it shows the switch correctly and switches correctly, am I missing something?
I'll answer my own question, it is a bug, if the scene I'd doesn't match a device I'd, then it doesn't work
Posted: Tuesday 13 February 2018 11:17
by galadril
Bigted wrote: Saturday 10 February 2018 18:02
That's weird.. because it was already flagged as a fixed bug :(
Ill check it
Posted: Tuesday 13 February 2018 11:18
by galadril
billouetaudrey wrote: Saturday 10 February 2018 14:22 I run on Miui 9.1, and don't received gcm notification with domoticz lite
Please check the following steps:
https://www.androidcentral.com/how-fix- ... ons-miui-8
Posted: Tuesday 13 February 2018 11:23
by galadril
Brutus wrote: Sunday 28 January 2018 15:27 Is there an option to Autofresh the dashboard? I have a Tablet at my wall and have the app running but after waking up the tablet for example after an hour its hasn't refreshed the devices. You need to refresh it manual (swipe down) to update all the devices.
There is no auto refresh options yet..
ill at this to the feature list:
https://github.com/domoticz/domoticz-android/issues/455
Posted: Tuesday 13 February 2018 11:48
by billouetaudrey
Hi I always do that, but now, I change rom and it's work fine...
Envoyé de mon Redmi Note 4X en utilisant Tapatalk
Posted: Monday 19 February 2018 13:45
by galadril
Just to let you know.. the next version on Android contains the new Auto Refresh feature
Posted: Monday 19 February 2018 13:47
by Minglarn
Me like! :)
Good work... Keep it up!
Posted: Monday 19 February 2018 15:54
by anthropo
I did searches but didn't find the answer.
I have an apache2 reverse proxy and a
ProxyPass /Domoticz/ http://192.168.0.10:8080/
ProxyPassReverse /Domoticz/ http://192.168.0.10:8080/
I have set server address with myservernameaddress/Domoticz/ and set the user and password, port 443
But it says 'could not get domoticz configuration : server error
I checked and double checked configuration, I have no more ideas.
Can you help me please ?
Posted: Tuesday 20 February 2018 23:20
by Logicsystem360
I am using your great app however there are a feature missing (or didn't find it).
How to schedule an event on a switch ?
We can only see, not modify the schedule.
I have a light as my alarm clock controlled by domoticz but when I want to change the scheduling, I can't with the app. I need to start my computer.
There any workaround to add this feature or not ?
Posted: Wednesday 21 February 2018 0:02
by Brutus
galadril wrote: Monday 19 February 2018 13:45 Just to let you know.. the next version on Android contains the new Auto Refresh feature
Google Play store notified me of a new version and I saw this implemented. Thnx! That's nice to use on both phone and tablet.
Posted: Wednesday 21 February 2018 12:03
by billouetaudrey
I find how resolve my issue :)
Need to Uninstall and reinstall... Restore with titanium backup don't work
Posted: Thursday 22 February 2018 22:15
by rfvdboom
galadril wrote: Tuesday 13 February 2018 11:17
Ill check it
+1. Can't use groups or scenes to a nfc tag.
Posted: Saturday 24 February 2018 11:33
by Xztraz
Can something be made to not break the widgets with every update? Have to remove and build up widgets on screen a bit too often.
Posted: Tuesday 27 February 2018 8:44
by BennY
this is my first issue I'm not able to find a solution for in this forum. I switched to Premium Version for using Geofencing. I have access from outside.
The Domoticz App trigger my switch on when I entered the Zone. Sometimes it trigger on when I leave the Zone, but never trigger off.
DomoFence App is working, but I need more than one location.
I set my Location at Home and set the radius to 1000m. My Phone is working with Android 7.0, GPS is on, Wifi configured to always on. Do I miss something to enable?
Posted: Tuesday 27 February 2018 12:25
by Gerwin
I use the Domoticz app with a lot of fun thanks for this developer !!
Though it is possible I would like to in the Android app 1 small adjustment
See if it is possible ,the smartwares radiator Valve can set the lowest temperature to 10 degrees ,Is it possible to change this to 5 degrees ?
Gerwin
Posted: Tuesday 27 February 2018 22:24
by pvklink
I have the premium app.
I added two domoticz servers in my app. One of myself and one of my dad who is to old to manage his environment.
How can i select my second server.
It looks you can only manage one environment...
Posted: Wednesday 28 February 2018 15:51
by phalseb
hello,
is it possible to conect the app with an url address given by no-ip?
I have a public IP address of the router that always changing.
Posted: Wednesday 28 February 2018 16:00
by MarcelMAH
phalseb wrote: Wednesday 28 February 2018 15:51 hello,
That should not be a problem... I'm using a DNS name with split-DNS (so the internal resolved IP is different from the external resolved IP).
