Locked
wizjos
Re: Dashticz v2.0, custom positioning and multiple screens
Post by wizjos »
Great new feature this ical calender add-on. However, I've noticed some strange behaviour as to the time of my appointments. They all are 2 hours off. Found it had to do with the dates being converted to utc. With an extra function to correct this, the dates and times of my appointments are correct now. 8-)
Strange however is that my appointments are not ordered from new to old, but randomly it seems... Anyone else noticed similar behaviour?
Regards,
Wizjos
madrian
Post by madrian »
mvveelen wrote:
madrian wrote:
mvveelen wrote:Any users with an Apple calendar? Trying to get the calendar plugin to work, but nothing shows up.
Me. :) config.js is correctly configured? Google Calendar works?
I added the URL (webcal://p29-calendars.icloud.com/published/2/nhsdjfgdsfgdsjfhfy3ef_DSgEIaCw_Tv6VZAn0xMLLCMhlEE-RIreVpahV4zKT-fE_XyvWaKHmFSf4cTYEptui-tRa1buriW7k)
the URL is just an example
But in the config.js I use buttons.calendar (the config_default.js isn't clear about what else to use) and nothing is showing up. I'm not using a Google calendar, but an Apple calendar.
Are you on beta branch? buttons.calendar is not for this module.
See my previous post from yesterday:
https://www.domoticz.com/forum/viewtopi ... 20#p131601
madrian
Post by madrian »
wizjos wrote:Great new feature this ical calender add-on. However, I've noticed some strange behaviour as to the time of my appointments. They all
Regards,
Wizjos
Timezone problem, I am working on this, but first I am trying to implement support for repeating events.
mvveelen
Post by mvveelen »
Yes, I am. But what IS ?
What do I use to display the calendar?
var _ICALENDAR_URL		= 'https://p9-calendars.icloud.com/published/2/nuh36ehsdfsdfsdf4TyqqnRy3ef_DSgEIaCw_Tv6VZAn0xMLLCMhlEE-sdfhkjdf-tRa1buriW7k'; //supports .ics type calendars (Google Calendar, Apple Calendar etc.)
var _ICALENDAR_DATEFORMAT	= 'friendly'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm'
var _ICALENDAR_LOCALE		= 'nl'; //en,hu, etc.
Is altered, but I'm missing the piece to display the calendar :)
madrian
Post by madrian »
Ahh, sorry:
columns[3] = {}
columns[3]['blocks'] = ['icalendar']
columns[3]['width'] = 2;
wizjos
Post by wizjos »
Regards,
Wizjos
Ive added this function to ical_parser.js
function ConvertUTCTimeToLocalTime(UTCDateString)
	var convertdLocalTime = new Date(UTCDateString);
	var hourOffset = convertdLocalTime.getTimezoneOffset() / 60;
	convertdLocalTime.setHours( convertdLocalTime.getHours() + hourOffset );
	return convertdLocalTime;
and in function makedate altered the line
var utcdatems = Date.UTC(dtutc.year, (dtutc.month-1), dtutc.day, dtutc.hour, dtutc.minute);
in
var utcdatems = ConvertUTCTimeToLocalTime(Date.UTC(dtutc.year, (dtutc.month-1), dtutc.day, dtutc.hour, dtutc.minute));
Hope it helps...
Regards,
Wizjos
pvdhelm
Post by pvdhelm »
where can i change the fontsize of the text 'er wordt momenteel niets afgespeeld" and "Grouped"
On my pc eveerything looks ok, but on my ipad pro the text is out of the box
greets patrick
madrian
Post by madrian »
Excellent, thank you very much. :)
I did not experienced any problem with the timezone, I am in Budapest timezone UTC+1, in DST +2.
Items not in order, I tested, it's ok here:
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Great job the calendar plugin.
Is it possible to add two google calendars on Dashticz, one for my wife and one for me?
madrian
Post by madrian »
SwordFish wrote:Great job the calendar plugin.
Not at this moment, but it's a great idea. Maybe if we ask @Rob nicely? :) He is better in these things.
I can imagine the following format:
var _ICALENDAR_URL	  	= [
  							    {"calendar":1,"title":"Lisa's calendar","url":"http://calendar.google.com/basic.ics"},
  							    {"calendar":2,"title":"SwordFish's calendar","url":"webdav://adaospdaspdokaspdo.ics"},
If no title were given, do not display title (as now).
8-)
SwordFish
Post by SwordFish »
8-)
Yeah something like that.
EdwinK
Post by EdwinK »
From a few posts back (Question of mine)
'Its a totally new module + you must install dashticz from beta branch, check new CONFIG_DEFAULT.js. buttons.calendar is not for this new module. :)
BTW this is how you clone beta branch into dashticz directory:
CODE: SELECT ALL
git clone https://github.com/robgeerts/dashticz_v2.git --branch beta dashticz
Or simple click here. https://github.com/robgeerts/dashticz_v ... e/beta.zip
Or go to the project page: https://github.com/robgeerts/dashticz_v2.git then click on 2 branches then select beta branch.
You need to run the beta version of this dashboard
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi Guys,
Suddenly i got errors for the Moon...:
Error: EventSystem: in MOON 17.04.27: [string "-- Variables to customize -------------------..."]:136: attempt to concatenate global 'moonsetMinute' (a nil value)
It worked, didn't do anything about scripting of testing... it started .....
mvveelen
Post by mvveelen »
madrian wrote:Ahh, sorry:
columns[3] = {}
This did the trick, thanks !
I see that you guys are working on the 2 hours time difference, but now at least I can see the calendar.
Now, we have more than 1 calendar (private, work, kids). Would it be possible to merge them?
tontze
Domoticz version: Beta Ch
Post by tontze »
Im trying to get this as map on dashboard, but for some reason, it doesnt work .. It works if i paste it to browser, but not shown in dashboard ?
https://gadgets.buienradar.nl/gadget/zoommap/?lat=61.49911&lng=23.78712&overname=2&zoom=8&naam=Tampere&size=2&voor=0"%20scrolling=no%20width=256%20height=256
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
SwordFish
Post by SwordFish »
poudenes wrote:Hi Guys,
I also still got an error and did nothing to the script since yesterday
Error: EventSystem: in Moon: [string "-- Variables to customize -------------------..."]:65: attempt to concatenate global 'moonsetMinute' (a nil value)
EdwinK
Post by EdwinK »
Add me too it. Also Rain script is throwing this to me.
2017-04-29 18:35:00.223 Error: EventSystem: in Regen Verwacht: [string "local RainTextIDX = 113 -- your domoticz te..."]:13: attempt to index global 'file' (a nil value)
2017-04-29 18:35:00.495 Error: EventSystem: in Moon: [string "-- Variables to customize..."]:54: attempt to index global 'file' (a nil value)
2017-04-29 18:35:37.130 Error: Logitech Media Server: No response from server 192.168.0.10:9000
2017-04-29 18:36:00.272 Error: EventSystem: in Regen Verwacht: [string "local RainTextIDX = 113 -- your domoticz te..."]:13: attempt to index global 'file' (a nil value)
2017-04-29 18:36:00.517 Error: EventSystem: in Moon: [string "-- Variables to customize..."]:54: attempt to index global 'file' (a nil value)
mvveelen
Post by mvveelen »
Same here....
Could it be that Wunderground isn't sending the "moon set" at the moment?
See:
  "response": {
  "version":"0.1",
  "termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
  "features": {
  "astronomy": 1
		,	"moon_phase": {
		"percentIlluminated":"15",
		"ageOfMoon":"4",
		"phaseofMoon":"Waxing Crescent",
		"hemisphere":"North",
		"current_time": {
		"hour":"18",
		"minute":"42"
		"sunrise": {
		"hour":"6",
		"minute":"11"
		"sunset": {
		"hour":"21",
		"minute":"03"
		"moonrise": {
		"hour":"8",
		"minute":"40"
		"moonset": {
		"hour":"",
		"minute":""
	"sun_phase": {
		"sunrise": {
		"hour":"6",
		"minute":"11"
		"sunset": {
		"hour":"21",
		"minute":"03"
And, when I use the newsfeed, I get all feeds in 1 block. Sometime just 1 news item, but most of the time all items on 1 page.
I'm using this code:
blocks['news_1'] = {} // NU.NL
blocks['news_1']['feed'] = 'https://crossorigin.me/http://www.telegraaf.nl/rss';
blocks['news_2'] = {} // TWEAKERS
blocks['news_2']['feed'] = 'https://crossorigin.me/http://feeds.feedburner.com/tweakers/nieuws';
columns[4] = {}
columns[4]['blocks'] = ['news_1','news_2']
columns[4]['width'] = 5;
madrian
Post by madrian »
1, work released, waiting for Rob to merge request.
2, this is a thing what Rob can do quickly, because only he has the super power.
koowee
Post by koowee »
How this "turn off last update date per device" works? There are these two settings in CONFIG.js, "_SHOW_LASTUPDATE" and"_LASTUPDATE_FORMAT", but what should I add per device to turn off this last update per device? Maybe add something like this: blocks[idx]['lastupdate'] = 'OFF'; or have I understood this totally wrong :)
Locked
