Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Saturday 29 April 2017 11:38
EdKo66 wrote:Yes please, Sopermouse
shit
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
Place this in your custom.css and play with the line background: rgba(0,0,0,0.2); (red, green, blue, transparancy) - especialy the 0.2 value (0.1 max transparancy - 1 = no transparancy)rick82 wrote:First of all: I'm really liking your dashboard, programming skills and keeping developing it! I've been using your dashboard and configuring it since yesterday and it's running like a charm. Bedankt
Second: if I want to change the transparency of a block how do I do that? I want it to be more dark because of the bright background.....?!
There's so much going on in the CSS-sheet
/* Background blocks */
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
padding-top:15px;
padding-bottom:15px;
border: 7px solid rgba(255,255,255,0);
background-clip: padding-box;
Looks goodhtilburgs wrote:Wiki modified with new look and page layout - http://www.domoticz.com/wiki/Dashticz-v2
I'll hope this becomes more clear to read, instead of 1 big page.
Now putting in the last changes![]()
In the speed this Dashboard is developing, it's a hard time to keep up...
Just Excellent !htilburgs wrote:Wiki modified with new look and page layout - http://www.domoticz.com/wiki/Dashticz-v2
response
version "0.1"
termsofService "http://www.wunderground.com/weather/api/d/terms.html"
features
astronomy 1
moon_phase
percentIlluminated "12"
ageOfMoon "3"
phaseofMoon "Waxing Crescent"
hemisphere "North"
current_time
hour "12"
minute "04"
sunrise
hour "6"
minute "12"
sunset
hour "20"
minute "57"
moonrise
hour "8"
minute "42"
moonset
hour ""
minute ""
sun_phase
sunrise
hour "6"
minute "12"
sunset
hour "20"
minute "57"If you did install it under .../domoticz/www/dashticz_v2/, then you need to use this kind of address domoticz_url:8084/dashticz_v2/ (assuming that your domoticz use 8084 port).tontze wrote:Hi, i just installed this via git, but i dont see it at all when browing to url:8084 ? I did as wiki asked to, which wasnt much![]()
-T
Koowee was quickerkoowee wrote:If you did install it under .../domoticz/www/dashticz_v2/, then you need to use this kind of address domoticz_url:8084/dashticz_v2/ (assuming that your domoticz use 8084 port).tontze wrote:Hi, i just installed this via git, but i dont see it at all when browing to url:8084 ? I did as wiki asked to, which wasnt much![]()
-T
Yes, please !SuperMouse wrote:Hi Guys.
Back again after 5 days on a holiday. Could not resist to open this forum![]()
I have this idea to make the moon edges transparent![]()
Anybody else interested before I change another 99 moons
aah ok ofcozkoowee wrote:If you did install it under .../domoticz/www/dashticz_v2/, then you need to use this kind of address domoticz_url:8084/dashticz_v2/ (assuming that your domoticz use 8084 port).tontze wrote:Hi, i just installed this via git, but i dont see it at all when browing to url:8084 ? I did as wiki asked to, which wasnt much![]()
-T
Yes please!!!SuperMouse wrote:Hi Guys.
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Dashticzstraat 2, 1234 AB Dashticzstad (0.4 km)",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 7,
"HardwareName" : "Dummy Virtual Switch",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveTimeout" : false,
"ID" : "00082154",
"LastUpdate" : "2017-04-29 12:00:07",
"Name" : "Locatie iPhone",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : false,
"SignalLevel" : "-",
"SubType" : "Text",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "text",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "154"
}htilburgs wrote:
I think it doesn't know ' "Data" : "Dashticzstraat 2, 1234 AB Dashticzstad (0.4 km)",'
Me.mvveelen wrote:Any users with an Apple calendar? Trying to get the calendar plugin to work, but nothing shows up.
I added the URL (webcal://p29-calendars.icloud.com/published/2/nhsdjfgdsfgdsjfhfy3ef_DSgEIaCw_Tv6VZAn0xMLLCMhlEE-RIreVpahV4zKT-fE_XyvWaKHmFSf4cTYEptui-tRa1buriW7k)madrian wrote:Me.mvveelen wrote:Any users with an Apple calendar? Trying to get the calendar plugin to work, but nothing shows up.config.js is correctly configured? Google Calendar works?
