Revers59
Post by Revers59 »
benbammens wrote:
doxikus wrote:HI,
I think someone already post a question. I have on new temperature sensor ordered from gearbest, cube shape, with additional pressure sensor. Can someone confirm that he had in domoticz sensor registered or we need to wait for update on code. Problem with android is resolved I can add sensor via Mi Home app.
No, it does not work yet
Verstuurd vanaf mijn SM-G930F met Tapatalk
hum I receive it this day ! One beer for the dev who code that :)
suborb
Post by suborb »
Revers59 wrote:
benbammens wrote:
doxikus wrote:HI,
The problem, as I understand it, is that the values for the new square button and thermometer aren't emitted over the LAN interface.
Looking at a tcpdump, it appears that the values are sent up to Xiaomi cloud, but the encryption keys/method for the cloud channel haven't been found - the protocol there is similar to that described here https://github.com/OpenMiHome/mihome-bi ... ROTOCOL.md
Thus a gateway firmware update is needed, or you need to bypass the gateway and use a zigbee sniffer such as here: http://faire-ca-soi-meme.fr/hack/2017/0 ... e-sniffer/
theo69
Domoticz version: la. beta
Post by theo69 »
I am using quit some Xiaomi Product by now, I bought them all @ GearBest. The shipping time was okay, german express 7-20 days (also available for other country and EU) and no TAX. They are really affordable with good build quality and design. Also integration via homebridge works like a charm.
These is a list of my working products:
Xiaomi Gateway Bridge (you need this)
Xiaomi Smart Door and Windows Sensor
Xiaomi Smart Wireless Switch
Xiaomi Motionsensor
Xiaomi Aqara Double Wall Switch
Xiaomi Aqara Single Wall Switch
Xiaomi Aqara Double Wall Switch Wireless
Xiaomi Aqara Single Wall Switch Wireless
Xiaomi Smart WiFi Socket
Not working right now are the Zero Line (neutral) Xiaomi Aqara Wall Switches.
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
levynger
Post by levynger »
theo69 wrote:I am using quit some Xiaomi Product by now, I bought them all @ GearBest. The shipping time was okay, german express 7-20 days (also available for other country and EU) and no TAX. They are really affordable with good build quality and design. Also integration via homebridge works like a charm.
Xiaomi Motionsensor
i Just installed the Aqara Single Wall Switch Line (LN) 2 days ago - after updating git from corbin's - it works.. i have seen corbin added the code to deal with the LN switch.. (didn't dig into it.. as it seems to work fine)
theo69
Post by theo69 »
levynger wrote: i Just installed the Aqara Single Wall Switch Line (LN) 2 days ago - after updating git from corbin's - it works.. i have seen corbin added the code to deal with the LN switch.. (didn't dig into it.. as it seems to work fine)
Did you update beta or did you compiled from corbin?
doxikus
Post by doxikus »
HI all,
This morning I have receive update for Xiaomi gateway, ver. 1.4.1_148.0143, and under domoticz log I got this message:
2017-07-17 09:40:32.236 XiaomiGateway: unhandled model: weather.v1
2017-07-17 09:40:32.245 XiaomiGateway: unhandled model: weather.v1
2017-07-17 09:40:32.282 XiaomiGateway: unhandled model: weather.v1
I have latest version of Aquara temp/hum/bar sensor, cube shape. Can someone take look on this, maybe with this update we can have finally support for new xiaomi sensors.
edit:
HA forum thread have more info:
https://community.home-assistant.io/t/b ... /8213/2236
benbammens
Post by benbammens »
doxikus wrote:HI all,
edit:
Damn, they are fast :)
Looking forward to seeing them in Domoticz.
corbin
Post by corbin »
should work if you compile from https://github.com/corbinmunce/domoticz
benbammens
Thank you!
Can the door/window sensor also be added? This is the message I see in the log:
2017-07-17 12:50:33.831 XiaomiGateway: unhandled model: sensor_magnet.aq2
levynger
Post by levynger »
Used Corbin's .cpp and .h on top of the beta before compiling.
but you can use corbin's git - it should work..
these changes are not yet in the official beta.
corbin
Post by corbin »
@benbammens Done - assuming it works the same as the Xiaomi sensor
@levynger I've just reset the changes for the wall switches in my repo to match the current Domoticz beta, so these new Aqara devices can be added in. I'm waiting on an order of wall switches to arrive so I can test it out fully, unless you could do it? You will see I've changed to using more unitcodes for the different devices.
salvacalatayud
Post by salvacalatayud »
I've just ordered this:
https://xiaomi-mi.com/sockets-and-senso ... ty-sensor/
Do you know if I can use it as a gateway?
theo69
Post by theo69 »
corbin wrote:should work if you compile from https://github.com/corbinmunce/domoticz
to stupid to compile, still new to all this. What do you think at what time it will word with beta?
theo69
Post by theo69 »
I also just got the new Square Button (Aqara Button) and I see these:
2017-07-17 13:39:33.186 XiaomiGateway: unhandled model: sensor_switch.aq2
Did anybody try the new motion sensor with LUX Sensor?motion sensor LUX
chatainsim
Domoticz version: v4.11307
Post by chatainsim »
corbin wrote:@benbammens Done - assuming it works the same as the Xiaomi sensor
For the aqara door sensor :
2017-07-17 19:42:20.142 XiaomiGateway: unhandled model: sensor_magnet.aq2
2017-07-17 19:42:20.142 {"cmd":"report","model":"sensor_magnet.aq2","sid":"158d0001a64ef5","short_id":15096,"data":"{\"status\":\"close\"}"}
2017-07-17 19:42:21.607 XiaomiGateway: unhandled model: sensor_magnet.aq2
2017-07-17 19:42:21.607 {"cmd":"report","model":"sensor_magnet.aq2","sid":"158d0001a64ef5","short_id":15096,"data":"{\"status\":\"open\"}"}
chatainsim
theo69 wrote:I also just got the new Square Button (Aqara Button) and I see these:
For the new square button, I'm not able to add it to the gateway. It's not in the list.
You did you add it ?
theo69
Post by theo69 »
chatainsim wrote: For the new square button, I'm not able to add it to the gateway. It's not in the list.
Just use the other button icon and after adding it shows aqara button ;-)
chatainsim
I tried but it failed.
I will try again later. Thanks
Revers59
Post by Revers59 »
the temp sensor with pression ( not supported now ) has a new name
2017-07-17 22:44:04.691 XiaomiGateway: unhandled model: weather.v1
theo69
Post by theo69 »
chatainsim wrote: I tried but it failed.
The learning button is on the side (not the small hole on top)
