Page 82 of 184
Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Friday 28 April 2017 22:28
by madrian
b00n wrote:@madrian
Nice work!!!
Is anyone having problems with the time in the calendar it shows my appointments 2 hours earlier ?
Sounds like a timezone problem, I'll check this asap.
Posted: Friday 28 April 2017 22:52
by robgeerts
sonar wrote:Am I the only one that thinks it is not a good development that we are relying on https://crossorigin.me/ more and more?
Would it not be better to have a proxy in the code of Dashticz?
I know, but you only have to use it in some situations.
Some sites dont like to be included in a frame or getting the content from within a localhost or something?
If someone has a better idea, please let me know!
madrian wrote:Apple Calendar support for iCalendar plugin is here.
How to get Apple Calendar url?
How to get Google Calendar url?
On settings page go to Calendars tab, click on your Calendar name then find Private Access row (or Calendar Address if you set your Calendar public):
One thing is missing: auto update calendar (at this time it is refreshing when you hit the refresh button).
Here is my idea: maybe if we ask Rob nicely, then he will check this part. :)
I will check this out :)
madrian wrote: B, Better wait for Rob, in a couple of hours he going to merge the request.
Merged in the beta version!
Posted: Friday 28 April 2017 23:01
by sonar
robgeerts wrote:I know, but you only have to use it in some situations.
Would this be a solution to this problem?
https://www.eriwen.com/javascript/how-to-cors/
Posted: Friday 28 April 2017 23:15
by TapNL
I am trying to display a more zoomed radar image from buienradar.
Using this link, option 1.4. https://www.buienradar.nl/overbuienrada ... s-weerdata
I tweaked the provided link a bit, so it looks now like:
frames.buivelp = {height:300,width:6,frameurl:"https://gadgets.buienradar.nl/gadget/zoommap/?lat=51.92324&lng=4.47863&overname=2&zoom=13&naam=3011 AD&size=2&voor=0"}
It gives me the right radar image as below.
Screen Shot.png (205.54 KiB) Viewed 2695 times
How can I make sure that the white part on the right is gone and that it fills the block just like the normal radar view?
Any help is appreciated.
Posted: Friday 28 April 2017 23:26
by EdwinK
madrian wrote:If you have time, please add more info to the Wiki about:
buttons.calendar = {icon: 'fa-calendar', title: 'Kalender', url: 'PASTE_URL_HERE'}
It is for Google Calendar? Other ical calendars are not supported?
When I paste my URL instead of showing the calendar, it downloads a file basic.ics.
Posted: Friday 28 April 2017 23:32
by madrian
It's a totally new module + you must install dashticz from beta branch, check new CONFIG_DEFAULT.js. buttons.calendar is not for this new module. :)
BTW this is how you clone beta branch into dashticz directory:
git clone https://github.com/robgeerts/dashticz_v2.git --branch beta dashticz
Or simple click here. https://github.com/robgeerts/dashticz_v ... e/beta.zip
Or go to the project page: https://github.com/robgeerts/dashticz_v2.git then click on 2 branches then select beta branch.
by EdwinK
I did.. Couldn't find it. Checking again.
Ah.. Now I see what was wrong. I just did git pull. Thinking it remembers that I was using the beta.
Posted: Friday 28 April 2017 23:55
by madrian
Maybe everybody should run they own crossorigin.me server? I got it working, since it is an open source project.
...maybe we should make 'https://crossorigin.me' into a configurable variable in CONFIG.js =>>>> _CROSS_PROXY_URL = '' so everybody can set they own cross proxy server (=or run it's own)? What about this idea?
Any interest in this idea?
Posted: Saturday 29 April 2017 0:03
by Nautilus
Thanks for the calendar plugin, got it working with google calendar at least. My primary calendar is in Outlook, do you know if it can be synced to google's or apple's calendar (or show directly with some url)? Also, any change of letting user to configure several icalendars (in case syncing between them is not an option)?
Posted: Saturday 29 April 2017 7:40
by gielie
EdKo66 wrote:
gielie wrote:Can someone help with the following problem.
Rob created some code to change the on/off status with af/aanwezig in the following code
Removed the code to shorten this post ;)
Where exactly should this code be placed? I rather be 'aanwezig' then 'on'.
The code is alleeady there, just change the idx and the name of the switch, if you then change the image location, that's it. All credits goes to Rob.
Posted: Saturday 29 April 2017 9:01
by EdwinK
[deleted[
Posted: Saturday 29 April 2017 9:05
by EdwinK
madrian wrote:Maybe everybody should run they own crossorigin.me server? I got it working, since it is an open source project.
Would be a good idea, I think. Atm not needed for me, but who knows.
Posted: Saturday 29 April 2017 10:10
by SwordFish
Got errors on the moon script and a notification from wunderground again. Had to many api calls in one minute.
Someone else have problems?
-----------..."]:65: attempt to concatenate global 'moonsetMinute' (a nil value)
2017-04-29 09:20:00.698 Error: EventSystem: in Moon: [string "-- Variables to customize -------------------..."]:65: attempt to concatenate global 'moonsetMinute' (a nil value)
2017-04-29 09:20:02.521 Error: EventSystem: in Moon: [string "-- Variables to customize -------------------..."]:65: attempt to concatenate global 'moonsetMinute' (a nil value)
Posted: Saturday 29 April 2017 10:50
by EdwinK
SwordFish wrote:Got errors on the moon script and a notification from wunderground again. Had to many api calls in one minute.
Nope, not here.
Posted: Saturday 29 April 2017 10:59
by Ierlandfan
What i think happens is when you reach the limit of WUnderground, they stop sending the right data.
As your error says, it can't find the right values anymore.
Posted: Saturday 29 April 2017 11:17
by htilburgs
The developer API can do 500 calls per day, with a max of 10 per minute. So you can place a max of 3 per minute for the 500. After that you'll receive an email.
Posted: Saturday 29 April 2017 11:26
by SwordFish
But i have it set to 7200 sec to check so only once in two hours?
Its started last night about 2 am and the error keeps returning.
Is it that i have to disable the script save it and then enable the script again?
Edit:
I just enabled the script again and the error comes right back :?
Posted: Saturday 29 April 2017 11:31
by rick82
First of all: I'm really liking your dashboard, programming skills and keeping developing it! I've been using your dashboard and configuring it since yesterday and it's running like a charm. Bedankt :-)
Second: if I want to change the transparency of a block how do I do that? I want it to be more dark because of the bright background.....?!
There's so much going on in the CSS-sheet ;)
Posted: Saturday 29 April 2017 11:34
by SuperMouse
Hi Guys.
Back again after 5 days on a holiday. Could not resist to open this forum :D
I have this idea to make the moon edges transparent :idea:
Anybody else interested before I change another 99 moons :o
Posted: Saturday 29 April 2017 11:35
by EdwinK
Yes please, Supermouse
