Locked
gielie
Domoticz version: latest β
Re: Dashticz v2.0, custom positioning and multiple screens
Post by gielie »
Can someone help with the following problem.
Rob created some code to change the on/off status with af/aanwezig in the following code
else if(parseFloat(device['idx'])==6 && device['Name']=='Thuis'){ //Special made for HansieNL! :)
							   $('.block_'+idx).attr('onclick','switchDevice(this)');
							   html+='<div class="col-xs-4 col-icon">';
								  if(device['Status']=='Off') html+='<img src="img/switch_off.png" class="off icon" />';
								  else html+='<img src="img/switch_on.png" class="on icon" />';
							   html+='</div>';
							   html+='<div class="col-xs-8 col-data">';
								  html+='<strong class="title">'+device['Name']+'</strong><br />';
								  if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
								  else html+='<span class="state">AANWEZIG</span>';
									if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
							   html+='</div>';
But when i use this in my own settings i get the following
before
after
So the icon isn't showing correct, how can this be fixed?
I also like to change the colour of the fan icon, but because this is a .png within the img folder i don't know how. I tried to change the fan_off.png but that doesn't work, if i change the fan.png both on and off are changing. Can someone point m i the right direction.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Ierlandfan
Post by Ierlandfan »
@mvveelen, it looks like you're recieving the wrong code.
In the code i can see a string search for the word "Moonphase" or somethin alike. You're output isnt showing that.
Let me look at the right output. I''ll put it here in a sec.
To check yourself:
sudo curl -s http://api.wunderground.com/api/api-key ... Hoorn.json
I don't think the output would differ that much from where I live (There are three sort of the same cities and it's not Enkhuizen)
"response": {
"version":"0.1",
"termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
"features": {
"astronomy": 1
, "moon_phase": {
"percentIlluminated":"6",
"ageOfMoon":"2",
"phaseofMoon":"Waxing Crescent",
"hemisphere":"North",
"current_time": {
"hour":"14",
"minute":"10"
"sunrise": {
"hour":"6",
"minute":"13"
"sunset": {
"hour":"21",
"minute":"01"
"moonrise": {
"hour":"7",
"minute":"54"
"moonset": {
"hour":"23",
"minute":"34"
"sun_phase": {
"sunrise": {
"hour":"6",
"minute":"13"
"sunset": {
"hour":"21",
"minute":"01"
poudenes
Domoticz version: 3.8993
Post by poudenes »
Can you add IDX devices that have a TEXT setup ? When i want add one it shown as a switch... :)
tried everything but can't get it good to see the text into the dashboard.
sonar
Domoticz version: 3.8153
Post by sonar »
gielie wrote:Can someone help with the following problem.
Are you sure the folder img contains the two files: switch_off.png and switch_on.png?
Ierlandfan
For the "text" switch:
In main.js around line 940 you '' ll find this piece of code
else if(device['Type']=='Group' || device['Type']=='Scene'){
                       if(device['Type']=='Group') $('.block_'+idx).attr('onclick','switchDevice(this)');
                       if(device['Type']=='Scene') $('.block_'+idx).attr('onclick','switchGroup(this)');
       if(buttonimg==''){
       if(device['Status']=='Off') html+=iconORimage(idx,'fa-lightbulb-o','','off icon');
       else html+=iconORimage(idx,'fa-lightbulb-o','','on icon');
        else {
       if(device['Status']=='Off') html+=iconORimage(idx,'',buttonimg+'.png','off icon');
       else html+=iconORimage(idx,'',buttonimg+'.png','on icon');
Put this piece of code BELOW
else if(device['SubType']=='Text'){
if(typeof(blocks[idx])!=='undefined' && typeof(blocks[idx]['switch'])!=='undefined' && blocks[idx]['switch']==true){
html+='<strong class="title">'+device['Data']+'</strong><br />';
html+='<span class="state">'+device['Name']+'</span>';
else {
html+='<span class="state">'+device['Data']+'</span>';
html+='</div>';
gielie
Post by gielie »
That was the problem, there is no which_off/on image, ok that solved that problem.
i figured it out and used this code.
								  if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon');
								  else html+=iconORimage(idx,'fa-toggle-on','','on icon');
							   html+='</div>';
							   html+='</div>';
I want to prevend a write over by the next update, how can i put this code in a custom file so it won't be overwritten?
- FIBARO FGS223
- Toon
- Kodi Media Server
mvveelen
Post by mvveelen »
Ierlandfan wrote:@mvveelen, it looks like you're recieving the wrong code.
To check yourself:
"response": {
"version":"0.1",
"features": {
"astronomy": 1
, "moon_phase": {
"ageOfMoon":"2",
"current_time": {
"hour":"14",
"minute":"10"
"sunrise": {
"hour":"6",
"minute":"13"
"sunset": {
"hour":"21",
"minute":"01"
"moonrise": {
"hour":"7",
"minute":"54"
"moonset": {
"hour":"23",
"minute":"34"
"sun_phase": {
"sunrise": {
"hour":"6",
"minute":"13"
"sunset": {
"hour":"21",
"minute":"01"
Almost neighbors :) ??
Wow......when I use "Enkhuizen" it works, I get a whole other output. Will look into it, probably "Kersenboogerd" will work, because that also worked for the weather forecast. Such a stupid error.....
But hey, thanks a lot, it now works and I see a very small piece of the moon on my dashboard :D !
gielie
Post by gielie »
Ierlandfan wrote:For the "text" switch:
       if(buttonimg==''){
        else {
else {
html+='</div>';
I tried this code but then i got nothing (dashboard is not loading), i can't figure out whats wrong. On my system its on line 1045
- FIBARO FGS223
- Toon
- Kodi Media Server
Ierlandfan
html+='</div>';
} <<<<<try removing this one
Dropshot
Post by Dropshot »
I can't get my dimmable lights to 100%. If I use the slider, it gets only to 99%. I saw the same in other dashboards. Of course this difference is not visible to the naked eye, but would it be possible to make a change so the dashboard says 100%?
poudenes
Post by poudenes »
Dropshot wrote:I can't get my dimmable lights to 100%. If I use the slider, it gets only to 99%. I saw the same in other dashboards. Of course this difference is not visible to the naked eye, but would it be possible to make a change so the dashboard says 100%?
In Domoticz it will not goto 100% as well... :) 99% is the new 100% !
madrian
Post by madrian »
Apple Calendar support for iCalendar plugin is here.
How to get Apple Calendar url?
How to get Google Calendar url?
On settings page go to Calendars tab, click on your Calendar name then find Private Access row (or Calendar Address if you set your Calendar public):
One thing is missing: auto update calendar (at this time it is refreshing when you hit the refresh button).
Here is my idea: maybe if we ask Rob nicely, then he will check this part. :)
sonar
Post by sonar »
Am I the only one that thinks it is not a good development that we are relying on https://crossorigin.me/ more and more?
Would it not be better to have a proxy in the code of Dashticz?
Some quotes from his site:
- PLEASE DO NOT USE THE PROXY ON A PRODUCTION SITE.
- I cannot guarantee the stability of the service, and you will probably experience service interruptions.
- And, as always, don't send sensitive information through the proxy. This is a good rule of thumb for any third party service.
- There is a 2MB size limit on files passed through the proxy
- etc.
mvveelen
Post by mvveelen »
madrian wrote:Apple Calendar support for iCalendar plugin is here.
Nice add-on !!
2 questions:
- If I make my iCloud calendar public, what 'risk' will I take? Can people see into my Calendar somehow?
- If I alter the code, like you explained earlier, and I update to the latest (beta), all code will be deleted, right?
madrian
Post by madrian »
Nice add-on !!
2 questions:
A. nothing, only when you share that URL with someone else. No else can view your Calendar.
B, Better wait for Rob, in a couple of hours he going to merge the request.
EdwinK
Post by EdwinK »
sonar wrote:Am I the only one that thinks it is not a good development that we are relying on https://crossorigin.me/ more and more?
- etc.
I agree with you. I believe this is running on some blokes computer. Not sure if it's something that could /should be done in the Dashboard.
b00n
Post by b00n »
@madrian
Nice work!!!
Is anyone having problems with the time in the calendar it shows my appointments 2 hours earlier ?
EdwinK
Post by EdwinK »
b00n wrote:@madrian
Nice work!!!
At least you will be on time :)
EdwinK
Post by EdwinK »
[quote="gielie"]Can someone help with the following problem.
Removed the code to shorten this post ;)
Where exactly should this code be placed? I rather be 'aanwezig' then 'on'.
b00n
Post by b00n »
EdKo66 wrote:
b00n wrote:@madrian
Nice work!!!
hahahah indeed :o :lol:
Locked
