chatainsim
Domoticz version: v4.11307
Post by chatainsim »
xxLeoxx93 wrote:What is the easiest way to tell domoticz that when i doubleclick my switch it should turn of my xiaomi wallplug? I can only see to run a script when interacting with my switch?
With lua it's fine :
-- Commande Selector Switch
    if (devicechanged['Xiaomi Switch Micro-onde'] == 'Click') then
        print("MicroOnde: Click ON for 10s")
        commandArray[1]={['Xiaomi Smart Plug']='On'}
        commandArray[2]={['Xiaomi Smart Plug']='Off AFTER 10'}
    if (devicechanged['Xiaomi Switch Micro-onde'] == 'Double Click') then
        print("MicroOnde: Double Click ON for 30s")
        commandArray[2]={['Xiaomi Smart Plug']='Off AFTER 30'}
    if (devicechanged['Xiaomi Switch Micro-onde'] == 'Long Click' ) then
        print("MicroOnde: Long Click ON for 2m")
        commandArray['Xiaomi Smart Plug']='On FOR 2'
I've added an entry "1.5 lua scripts example" in the Wiki with this script.
chatainsim
chatainsim wrote: I've added an entry "1.5 lua scripts example" in the Wiki with this script.
I've also added "1.6 Blocky example".
Tell me if it's relevant and useful. :lol:
marcotini
Post by marcotini »
Why sometimes the motion sensor isn't trigger on and nothing happen?
Edit:
corbin wrote:quote
(I quote just for tag) sometimes happen that the motion sensor not working so I need to update (click on button Update in Hardware section) Xiaomi service. So I think that there is some sort of problem in the timeout or something.
corbin
Post by corbin »
Some of my motion sensors don't always trigger immediately. Haven't had time to investigate further but I plan to compare Domoticz with the Mi Home app log.
apazga
Post by apazga »
benbammens wrote:OK, the new temperature sensors show up in the android app.
I still can't see them in Domoticz though...
So, are temperature new sensors [1] finally supported or not? I saw them on Mi Home app, but not in Domoticz yet.
[1] http://www.gearbest.com/access-control/pp_626702.html
benbammens
Post by benbammens »
Not in domoticz I'm afraid...
Verstuurd vanaf mijn SM-G930F met Tapatalk
apazga
Post by apazga »
benbammens wrote:Not in domoticz I'm afraid...
Ok, thanks anyway!
marcotini
Post by marcotini »
corbin wrote:Some of my motion sensors don't always trigger immediately. Haven't had time to investigate further but I plan to compare Domoticz with the Mi Home app log.
In Mi App everything work great... and only sometimes happen, I don't know how.
There is a way to see the log of the signal sent by the Gateway?
bing69
Post by bing69 »
is ther a change that the "Smart Socket/Plug - Zigbee version (The WiFi version is not supported)" to be supported in domoticz.
I ordered the wrong one...
Derik
Post by Derik »
mmm
Think i found a bug/problem...
Will try to use the remote button in blockley....
Only when i click 1 time...
The button is not going on, just change the tekst to click.
Only in blockley there is no click.
And on is not working.
other options?
corbin
Post by corbin »
marcotini wrote: In Mi App everything work great... and only sometimes happen, I don't know how.
So I setup an alert from the Mi Home app went motion is detected, and can confirm it was working properly too.
A reboot of Domoticz has helped with events not triggering immediately in Domoticz, indicating that is where the problem is. You can enable logging of messages received from the gateway (check the wiki), but I don't know if we can see a log of messages sent by the gateway.
Onkytonk
Post by Onkytonk »
Does anyone have this switch? And is it working?
theo69
Domoticz version: la. beta
Post by theo69 »
not working yet, only old round version. But they working on it!
Onkytonk wrote:Does anyone have this switch? And is it working?
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
Derik
Post by Derik »
mmm is this a third party?
Like my tempsensors...
Think they are not supported
pvm
Domoticz version: 4.10538
Post by pvm »
First: Great work, everything up and running in minutes thanks to the programmer(s) and the wiki!
I would like to play a sound with the gateway, somehow the following blocky does not work... can anybody help me?
jjnj
Post by jjnj »
You will have to use it as selector switch which is represented as a percentage. So 10% for the first one, 20% second one, etc
xxLeoxx93
Post by xxLeoxx93 »
Thank you very much!
Does anyone know if it's possible t change the wifi for the mi home gateway wihout resettig it?
mikeoo
Post by mikeoo »
As far is i know you need to do a reset. Try this also a month ago but there is no option to change it without reset.
pvm
Post by pvm »
jjnj wrote:You will have to use it as selector switch which is represented as a percentage. So 10% for the first one, 20% second one, etc
Thnx, added this info to the wiki page
jjnj
Post by jjnj »
Good idea thanks!
