Page 9 of 29
Re: How to install Domoticz on a Synology NAS
Posted: Saturday 14 January 2017 16:02
by jumbotroll
checkdiz wrote:i got this:
usbcore: registered new interface driver ch341
USB Serial support registered for TI USB 3410 1 port adapter
USB Serial support registered for TI USB 5052 2 port adapter
usbcore: registered new interface driver ti_usb_3410_5052
ti_usb_3410_5052: v0.10:TI USB 3410/5052 Serial Driver
i saw one error, but don't know if related:
EXT3-fs (md0): error: couldn't mount because of unsupported optional features (240)
You should have something like this to :
usb 6-2: ch341-uart converter now attached to ttyUSB0
If you look in Control Panel ->Info Center you should see:
USB device HL-340 USB-serial adapter .....
If you use USB HUB, try with out.
You can also check if you have this file in folder /usr/lib/modules
usbserial.ko
Posted: Saturday 14 January 2017 20:19
by checkdiz
jumbotroll wrote:checkdiz wrote:i got this:
usbserial.ko
As for your first suggestion, I found:
usb 2-1: ch341-uart converter now attached to ttyUSB0
Second, Info Center shows indeed HL-340 USB serial adapter
And I do not use a Hub.
And I found usbserial.ko under usr/lib/modules..
Posted: Saturday 14 January 2017 20:32
by jumbotroll
checkdiz wrote:jumbotroll wrote:checkdiz wrote:i got this:
usbserial.ko
Then all seems to be ok and i don´t know why not this is not working.
Maybe some conflicts with another application?
Have you maybe installed some another software?
Are you sure the RfLink is working ok?
Did you update the RfLink software and what version is it?
Posted: Saturday 14 January 2017 20:40
by checkdiz
I have a lot of other apps running on the synology, will see if i can stop them and see what happens.
Define another software?
RFLink I unpacked, put on the arduino board, and connected right to the ds214. I assume the seller has tested in on beforehand. Should I contact seller?
For the RFLink software: I installed the latest domoticz package from jadahl. Everything like drivers etc should be in there, right?
Domoticz 'about' says: Version: 3.6334
Build Hash: 2fd8bdc-modified
Compile Date: 2017-01-12 09:08:14
Sent from my iPad using Tapatalk
Posted: Saturday 14 January 2017 20:47
by jumbotroll
checkdiz wrote:I have a lot of other apps running on the synology, will see if i can stop them and see what happens.
Define another software? "some another software that are using USB ports"
I don´t know if the RFlink is preprogrammed, but if you have a windows machine you can download the software and update the RFlink.
Update to version R45
http://www.nemcon.nl/blog2/download
Posted: Saturday 14 January 2017 20:50
by checkdiz
Ok thanks for clearing that out! No there are no other usb port related software packages.
Thanks for that suggestion. Can I leave the rflink gateway connected to the synology when trying the update?
Posted: Saturday 14 January 2017 20:55
by jumbotroll
checkdiz wrote:Ok thanks for clearing that out! No there are no other usb port related software packages.
Disconnect the RFlink from the NAS and connect to the windows machine update starting RFLinkLoader.exe
Posted: Saturday 14 January 2017 21:24
by checkdiz
Jumbotroll
You are the man!
Thanks for all the quick support you gave.
Installing the software via windows did the trick.
Thanks again
Posted: Wednesday 18 January 2017 12:31
by synodomo
i have a DS209+II but i cant install domoticz, because iam on DSM 4.2. That is the max version from synology
Posted: Wednesday 18 January 2017 15:10
by jumbotroll
synodomo wrote:i have a DS209+II but i cant install domoticz, because iam on DSM 4.2. That is the max version from synology
Sorry I don't support DS209-ll arch-ppc853x for DSM 4.2
The Toolchain gcc343_glibc234_ppc853x-GPL used in DSM 4.2 is not compatible to build domoticz and openzwave.
Posted: Wednesday 18 January 2017 15:21
by synodomo
jumbotroll wrote:synodomo wrote:i have a DS209+II but i cant install domoticz, because iam on DSM 4.2. That is the max version from synology
I know. Is there a way to softmod to a ds210+? That have dsm 5.2
Posted: Wednesday 18 January 2017 15:25
by Egregius
Spare yourself the trouble and buy a RPi3. A RPi3 has 5 times the CPU power and double the memory.
See also
http://www.domoticz.com/forum/viewtopic ... 17&t=14853
Posted: Wednesday 18 January 2017 15:35
by synodomo
Egregius wrote:synodomo wrote:i have a DS209+II but i cant install domoticz, because iam on DSM 4.2. That is the max version from synology
See also
i know, i have 3 of them. I need domoticz on the DS209+II because then i can see my uptime from the nas in my main domoticz on a py.
I can not find any script for the synology to see my uptime.
Posted: Wednesday 18 January 2017 15:52
by Egregius
What's the point of that? My Syno has 100% uptime. Only down for a restart if I find the update important enough to install.
Posted: Wednesday 18 January 2017 15:54
by synodomo
Egregius wrote:What's the point of that? My Syno has 100% uptime. Only down for a restart if I find the update important enough to install.
It is important for me. When i see the server is down i receive a message from pushover. There are very important things on the synology. So i can see when the synology is down, and can easy investigate from there.
Posted: Wednesday 18 January 2017 16:26
by jumbotroll
synodomo wrote:Egregius wrote:What's the point of that? My Syno has 100% uptime. Only down for a restart if I find the update important enough to install.
I was able to build an older version, with allot of warnings you can test
Domoticz v3.0.3530-7 for DS209+ll
http://www.jadahl.com/domoticz_old/?arch=ppc853x
Posted: Wednesday 18 January 2017 16:42
by synodomo
jumbotroll wrote:synodomo wrote:Egregius wrote:What's the point of that? My Syno has 100% uptime. Only down for a restart if I find the update important enough to install.
Thanks! i have installed it, and it works! If someone have a script for the uptime for the synology (without installing domoticz on it) iam thankful too. But for now my problem is solved.
Posted: Thursday 26 January 2017 23:56
by Syssy
I have this error after update on 3.6496-7 on
2017-01-26 23:47:09.078 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 8443: use_certificate_chain_file: No such file or directory
Downgrade not solve it.
Any solution ?
Posted: Friday 27 January 2017 13:28
by jumbotroll
Syssy wrote:I have this error after update on 3.6496-7 on
Any solution ?
It is fixed in Domoticz V3.6500
Update with this fix will be uploaded later today
Re: RE: Re: How to install Domoticz on a Synology NAS
Posted: Friday 27 January 2017 14:13
by Syssy
jumbotroll wrote:Syssy wrote:I have this error after update on 3.6496-7 on
Any solution ?
You are the boss ! Great !
Envoyé de mon Nexus 5X en utilisant Tapatalk
