Page 9 of 16
Re: Events system feedback thread
Posted: Wednesday 07 August 2013 14:22
by gertjuhh
I think you misunderstood me, my proposition is actually not that complex.
Events already have a boolean/checkbox "Event active", all I'm suggesting is being able to toggle that boolean from within a (nother) event.
Another valid example of where this could be used:
Event A: Rain sensor (not sure if these work yet) current rainfall > 1mm AND bedroom windows sensor = open --> Send notification + disable "Event A"
Event B: Rain sensor current rainfall = 0mm OR bedroom window senor = closed --> enable "Event A"
This way you wouldn't get a notification each time the rain sensor checks in.
Blockly gives a LUA error
Posted: Wednesday 07 August 2013 14:44
by willie-p
ls,
I've made a blockly event which should work in my opinion but I look at my log I see:
Error: Wed Aug 07 14:43:22 2013 Lua script error: [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: ')' expected near 'comparevariable'
What am I doing wrong?
Posted: Wednesday 07 August 2013 15:05
by Dynamic
+1 for gertjuhh's idea!
Posted: Friday 09 August 2013 16:39
by willie-p
ls,
Could still use some help on the post above.
Any idea anyone?
Cheers,
Will
Posted: Friday 09 August 2013 16:59
by macaidwin
You can use a 'fake' lightswitch for this. This switch tells the event if it should check the rainfall or not.
Event A: If rain > 1mm AND window = open AND lightswitch=ON then send mail AND switch lightswitch=OFF
Event B: If rain < 1mm OR window = closed then lightswitch=OFF
Something like that
Only thing is, that something has to reset the situation. You have to play with it until it is right.
Posted: Friday 09 August 2013 17:00
by maxtrash
I've made some basic blocky script to interface with Eventghost. Eventghost can receive events and payloads using the webserver plugin. I can send them this way, but I would like the payload to be a dim-value (e.g. create a virtual dimmer device).
would this be possible in blockly?
if not, what is the corresponding LUA-statement for Open URL? If I understand correctly internally domoticz changes blockly into lua, right?
Posted: Friday 09 August 2013 17:04
by gertjuhh
macaidwin wrote:You can use a 'fake' lightswitch for this. This switch tells the event if it should check the rainfall or not.
Something like that
The whole point of my suggestion is not having to create a fake switch for such events.
That way you don't clutter up your whole system with fake switches, and as an extra bonus the events system will be (theoretically) faster.
Posted: Friday 09 August 2013 17:08
by macaidwin
gertjuhh wrote:macaidwin wrote:You can use a 'fake' lightswitch for this. This switch tells the event if it should check the rainfall or not.
Something like that
Okay and you can't manage to make 1 complex event with every check in it, you want?
I made these events:
http://www.domoticz.com/forum/viewtopic ... t=20#p1118
With checks that prevent the events from repeating itself because of values that keep steady for hours.
Posted: Friday 09 August 2013 17:18
by gertjuhh
macaidwin wrote:gertjuhh wrote:macaidwin wrote:You can use a 'fake' lightswitch for this. This switch tells the event if it should check the rainfall or not.
Something like that
Sure you can solve a problem multiple ways, my addition would give you one more, one i myself happen to prefer.
But you seem to be missing the point here...
I'm merely making a suggestion which could improve the events system.
I shared my thoughts, given my argumentation, let's just leave it at that.
Posted: Friday 09 August 2013 19:17
by macaidwin
It's okay, I get your point to switch events on and of using another event.
I am not a programmer, but I think it is not easy to programm this. So that's why I tried to help with other ideas.
Posted: Sunday 11 August 2013 1:49
by asjmcguire
willie-p wrote:ls,
Any idea anyone?
Cheers,
Will
Will - unless I have missed an announcement somewhere (which is quite possible with so much activity happening across the forum) I don't think the Blockly editor supports working with scenes yet?
Posted: Sunday 11 August 2013 9:00
by bistoury
I can confirm blocky works with scene
to run a scene named "SCENE1" you have to add a block such as : set SCENE1 = ON
et voila !
cheers,
bistoury.
Posted: Sunday 11 August 2013 16:05
by Skippiemanz
I'am experimenting with the event system.
Looking very promising. But when i try to get my foscam fi9821 PTZ cam to a default preset when a door sensor is triggerded using the follwoing url:
192.168.xxx.xx:xxxxxx/cgi-bin/CGIProxy.fcgi?cmd=ptzGotoPresetPoint&name=Kamer&usr=xxxxx&pwd=xxxxxx
I get an error when trying to save the event. if i shorten the url in halve i can save the event without problems.
the url after the saving atempt looks like this: 192.168.xxx.xx:xxxxxx/cgi-bin/CGIProxy.fcgi?
Is this a setting in the database or something else?
Posted: Sunday 11 August 2013 16:33
by hemmelot
Hi Guys, first of all my compliments for this great piece of software.
I ran into a problem with the following:
I have a virtual switch (controlled via XBMC, this works) and a dimmer (also works).
IF virtualswitch=ON AND dimmer=ON
DO set dimmer level to 30%
ELSE IF virtualswitch=OFF AND dimmer=ON
DO set dimmer level to 80%
This won't work.
Losing the "AND dimmer=ON" makes it work, but i only want XBMC to control the light if the dimmer/lamp is on because during daytime i don't want it on (dimmer is on a after sunset timer).
Any ideas?
Posted: Sunday 11 August 2013 17:13
by pepijn
I'am trying to create a nice presence simulation in Blockly, some questions
1) Is it possible to start a sequence (turn of the lights, turn on dimmer hallway, turnoff dimmer hallway, turn on bathroom etc) on a random time? I know you can do this for one switch but is would be nice if this can be done for a bunch actions.
2) Can you add a wait/delay block? So Switch 1 --> Wait 1 min --> Switch 2 etc?
Posted: Monday 12 August 2013 12:24
by sebquid
I have got the same issue (see my post
http://www.domoticz.com/forum/viewtopic.php?f=15&t=246) and I think It is because blocky doesnt' accept "&" symbol in the URL... Let me know if you managed to save your event without the "&"
Posted: Monday 12 August 2013 14:47
by robpow
what happens if you change
to
192.168.xxx.xx:xxxxxx/cgi-bin/CGIProxy.fcgi?cmd=ptzGotoPresetPoint%26name=Kamer&26usr=xxxxx%26pwd=xxxxxx
Matt
Posted: Monday 12 August 2013 16:40
by Skippiemanz
The link works ok when i try it in my chrome browser.
But unfortunetly i still cant save the event.
Still get the same error and the link is shortened at the same place
Posted: Monday 12 August 2013 17:28
by robpow
What if you urlencode all the special characters like this?
192.168.xxx.xx:xxxxxx/cgi-bin/CGIProxy.fcgi%3Fcmd%3DptzGotoPresetPoint%26name%3DKamer%26usr%3Dxxxxx%26pwd%3Dxxxxxx
Posted: Monday 12 August 2013 17:52
by Skippiemanz
Hmm still not saving.
Also the url doesnt work an gives me a 404 error.
Any more ideas?
