Page 9 of 25
Re: Android app
Posted: Wednesday 22 January 2014 13:13
by JohanEikelenboom
Looks like I found a bug in the android app:
I have a KaKu dimmer. When I use a remote to switch off the dimmer (using an event in Domoticz) the dimmer is displayed off in Domoticz, but still showing on at 100% in Dromotica. Clicking the off-button in Dromotica is will display off for a couple of seconds, and than flips back to on (the lamp itself stays off)....
Re: Android app
Posted: Saturday 25 January 2014 0:50
by Ron
A have exactly the same problem over here.
Lights are off, allso in Domoticz but are on in Dromotica.
After switching off in Dromotica, the (Dromotica) dimmer goes on after a few seconds.
(but not in real life or Domotic the light stays off)
Because of this, the app became useless for me. In the beginning this was not the case.
It looks like this only occurs with a dimmer.
Re: Android app
Posted: Saturday 01 February 2014 9:50
by Ron
@Sebastian, are you stil working on Dromotica?
Re: Android app
Posted: Sunday 02 February 2014 10:20
by sebas
Ron wrote:@Sebastian, are you stil working on Dromotica?
Yes, I'm still working on it.
Re: Android app
Posted: Sunday 02 February 2014 20:37
by supergroover
Dimmers are working perfectly with the new update..
Thanks for the great app
Re: Android app
Posted: Sunday 02 February 2014 20:44
by JohanEikelenboom
Confirmed: Dimmers are working. Now when I leave home everyting is turned off, also in Dromotica :)
Re: Android app
Posted: Monday 03 February 2014 6:21
by Ron
Thank you for your work!
Tbe last update solved the problem, Dromotica is nice and easy to work with.
Re: Android app
Posted: Monday 03 February 2014 7:59
by sebas
Great! Finally got those dimmers working :D
Re: Sv: Android app
Posted: Sunday 09 February 2014 10:22
by SEALen
Just installed your app and like it a lot. But the widget lacks a very basic thing. Can you please display witch switch or witch scene it is for? At least a couple of letters from the name. Hard to keep track with only the color.
Re: Android app
Posted: Sunday 16 February 2014 12:38
by mikejclark
Hi, what's the latest with https support?
I'm running domoticz 1.1492 and can access using https in a browser. I have just configured a startssl certificate and get no certificate errors (also fine using an ssl checker).
I get:
Error reading switches
The server did not return a valid response
I have double checked my credentials, url and port etc
Re: Android app
Posted: Sunday 16 February 2014 17:04
by SEALen
Hmm I upgraded to Domoticz 1.1396 (latest stable) today and now adding new widgets won't work at all. When you click the choose switch or choose scene it craches with a Java.lang.null pointer exception. Everything else seems fine though.
Re: Android app
Posted: Monday 17 February 2014 10:51
by sstolk
Is it possible now that you have great working app to implement the security panel with a native android keyboard/numeric?
I've been clicking around in Android Development Toolkit with Eclipse but the pieces are not falling into place...yet! I'm not a programmer but it has my curiosity.
Re: Android app
Posted: Monday 17 February 2014 21:02
by sebas
mikejclark wrote:Hi, what's the latest with https support?
I get:
I'm still running 1.429, maybe it's in the new version of Domoticz without any problems. I'll have to check after I upgrade.
You're connect to the correct port and the certificate you got is for the domain name you're using to connect to Domoticz? I'm using SSL when I'm not on my home network and the unsecure connection when I'm on my local network. This because my certificate is not for my local ip-address, only for the domain name I use remotely.
sstolk wrote:Is it possible now that you have great working app to implement the security panel with a native android keyboard/numeric?
I've got requests to add the security panel and it's on the todo list. For now I'm focussing on weather, camera's and a tablet version. I'm very busy with other projects, setting up my own business, and work so I have very little time and the moment. It's coming :-)
For the widgets. They need a redesign both technically and how they look and work. Only icons doesn't work out very well.
Re: Android app
Posted: Tuesday 18 February 2014 8:21
by sstolk
Great to hear! Good luck with your business and keep up the good work!
Re: Android app
Posted: Tuesday 18 February 2014 9:18
by mikejclark
Yes, the certificate is for my domain. I can connect to domoticz using ssl when I'm off my home network from any browser and the certificate is accepted with no errors. I'm using port 443 which is forwarded in my router
Re: Android app
Posted: Wednesday 12 March 2014 22:11
by Blueone
Is is maybe also possible to add the possibility to manage multiple domoticz systems?
Re: Android app
Posted: Friday 14 March 2014 16:00
by fwehrle
It works nice for me, but with a StartSSL certificate.
Maybe it is the Self Signed cert., or maybe the proxy settings... (I use nGinx on https and port 443, with proxy authentification (none on Domoticz))
Re: Android app
Posted: Friday 14 March 2014 19:27
by Ritmeester
Blueone wrote:Is is maybe also possible to add the possibility to manage multiple domoticz systems?
Yes, this would be a nice option to add.
For example: I have two Yamaha receivers in my home and they can be controlled by a Android App. When you start the App, you can choose which receiver you want to control.
Re: Android app
Posted: Sunday 16 March 2014 12:30
by Derik
Dear Sebastien,
Would it be possible to have multiple login?
I have several users in Domoticz.
And it would be nice if a users also only can use his switches with the app, which they may operate.
Now I log in with another user, who can use all the switches, while I have known to them. Domoticz in only a few switches
And would it be possible to have a room plan to add.
Re: Android app
Posted: Thursday 20 March 2014 13:24
by andriej
For me (StartSSL certificate on "high" port) the "Secure" option doesn't work (triple-checked all login/pass info).
"Insecure" on local network works ok.
