Page 9 of 12
Re: Python Plugin: Volvo EV
Posted: Tuesday 07 January 2025 0:05
by Tukker
@akamming
I just tried the Volvo.lua script found within the plugin directory
- missing availabilityStatusDevice='Volvo-availabilityStatus' in the plugin
- log showing error: 2025-01-07 00:04:28.116 Error: EventSystem: Lua script Volvo warning did not return a commandArray
is this still experimental?
Posted: Wednesday 08 January 2025 9:00
by akamming
impossible to troubleshoot if you don't post the logging. First Guess is that you renamed the volvo availability status device and did not change the script accordingly
I did notice that after a recent change i also neede to change the LUA, but forgot to checkin in github. So i just did.
It is now a working script (but just a sample. Adjust to your own needs). Make sure the device numbers or names match in the top of the script match your configuration, otherwise it will not work ofcourse..
Better to ask help then in the dzvents section of this forum
Posted: Wednesday 05 February 2025 21:36
by Tukker
With the ideas and setup of myself and the help of Claude I present you my EV Consumption script.
What is needed
- a text sensor named EV Consumption Facts (Facts added to avoid naming problems within Domoticz)
- a switch sensor type doorbell with the name Reset EV Data
- you will have to create a file EV_Consumption.csv to start with in your /home/pi directory
- the contens of the file are these
timeStamp;odometer;batteryLevel;deltaDistance;kWhTotal;deltakWh;kWh100km;euro;a>
01-01-2025 01:00;15513;;;2562.958;;;;
and the script
-- Data is written to file and to textSensor
-- file: EV_Consumption.csv, textSensor EV Consumption
-- monthly data are saved to file at the end of each Month
-- it enables you to depict the relationship between EV Consumption and temperature
-- Constants
local CONSTANTS = {
    BATTERY_CAPACITY = 79, -- kWh
    TARGET_BATTERY_PERCENTAGE = 82, -- Target percentage for normalization
    PRICE_PER_KWH = 0.25, -- euro/kWh
    CSV_FILE_PATH = "/home/pi/EV_Consumption.csv", -- Path to the CSV file
    MAX_TEMP_ARRAY_SIZE = 1440 -- Max number of temperature measurements (1 day with 1 measurement per minute)
-- Helper functions
local function spaces(count)
    return string.rep(" ", count)
local function round2Decimals(number)
    if number == nil then
        return 0
    return math.floor(number * 100 + 0.5) / 100
-- Check if today is the last day of the month
local function isLastDayOfMonth()
    local today = os.date("*t")
    local tomorrow = os.date("*t", os.time() + 24 * 60 * 60)
    return today.month ~= tomorrow.month
-- Format display text for the text device
local function formatDisplayText(domoticz, data, currentMonth)
    -- Ensure domoticz.log is available
    if domoticz and domoticz.log then
        -- Log all data for debugging
        domoticz.log('Last Update: ' .. (data.lastUpdate or "N/A"), domoticz.LOG_DEBUG)
        domoticz.log('Current Odometer: ' .. (tonumber(data.currentOdometer) or 0) .. ' km', domoticz.LOG_DEBUG)
        domoticz.log('Battery Level: ' .. (tonumber(data.batteryLevel) or 0) .. ' %', domoticz.LOG_DEBUG)
        domoticz.log('Distance ' .. currentMonth .. ': ' .. (tonumber(data.distance) or 0) .. ' km', domoticz.LOG_DEBUG)
        domoticz.log('kWh ' .. currentMonth .. ': ' .. (tonumber(data.kWhPartial) or 0) .. ' kWh', domoticz.LOG_DEBUG)
        domoticz.log('Costs ' .. currentMonth .. ': ' .. (tonumber(data.euro) or 0) .. ' €', domoticz.LOG_DEBUG)
        domoticz.log('Average Temp: ' .. (tonumber(data.avgTemp) or 0) .. '°C', domoticz.LOG_DEBUG)
        domoticz.log('EV Consumption: ' .. (tonumber(data.evConsumption) or 0) .. ' kWh/100km', domoticz.LOG_DEBUG)
        domoticz.log('Battery level normalized to ' .. CONSTANTS.TARGET_BATTERY_PERCENTAGE .. '%', domoticz.LOG_DEBUG)
        domoticz.log('Original kWh loaded: ' .. (tonumber(data.kWhPartial) or 0) .. ' kWh', domoticz.LOG_DEBUG)
        domoticz.log('Normalized kWh: ' .. (tonumber(data.normalizedKWh) or 0) .. ' kWh', domoticz.LOG_DEBUG)
        -- Provide a clearer error message
        local errorMsg = 'Er is een fout opgetreden in local function formatDisplayText: '
        if not domoticz then
            errorMsg = errorMsg .. 'domoticz is nil. '
        if domoticz and not domoticz.log then
            errorMsg = errorMsg .. 'domoticz.log is nil.'
        domoticz.log(errorMsg, domoticz.LOG_ERROR)
    return string.format(
        "Last Update : %s\n" ..
        "Current Odometer : %d km\n" ..
        "Battery Level : %d %% \n" ..
        "Distance %s : %d km\n" ..
        "kWh %s : %.2f kWh\n" ..
        spaces(15) .. "Costs %s : %.2f €\n" ..
        spaces(15) .. "Average Temp : %.1f°C\n" ..
        spaces(15) .. "EV Consumption : %.2f kWh/100km\n" ..
        spaces(15) .. "Battery level normalized to %d%%\n" ..
        spaces(15) .. "Original kWh loaded: %.2f kWh\n" ..
        spaces(15) .. "Normalized kWh   : %.2f kWh\n",
        data.lastUpdate or "N/A",
        tonumber(data.currentOdometer) or 0,
        tonumber(data.batteryLevel) or 0,
        currentMonth, tonumber(data.distance) or 0,
        currentMonth, tonumber(data.kWhPartial) or 0,
        currentMonth, tonumber(data.euro) or 0,
        tonumber(data.avgTemp) or 0,
        tonumber(data.evConsumption) or 0,
        CONSTANTS.TARGET_BATTERY_PERCENTAGE,
-- Update the text device with the latest data
local function updateDisplay(domoticz, displayText)
    local displayDevice = domoticz.devices('EV Consumption Facts')
    if displayDevice then
        displayDevice.updateText(displayText)
        domoticz.log('Text sensor updated with new data', domoticz.LOG_DEBUG)
        domoticz.log('Text sensor "EV Consumption Facts" not found', domoticz.LOG_ERROR)
-- Normalize battery consumption to target percentage
local function normalizeToTargetLevel(domoticz, currentLevel, kWhUsed)
    local kWhPerPercent = CONSTANTS.BATTERY_CAPACITY / 100
    local difference = CONSTANTS.TARGET_BATTERY_PERCENTAGE - currentLevel
    local kWhAdjustment = difference * kWhPerPercent
    local normalizedKWh = kWhUsed + kWhAdjustment
    domoticz.log('Battery normalization calculation:', domoticz.LOG_DEBUG)
    domoticz.log(string.format('Current level: %.1f%%', currentLevel), domoticz.LOG_DEBUG)
    domoticz.log(string.format('Difference to target: %.1f%%', difference), domoticz.LOG_DEBUG)
    domoticz.log(string.format('kWh adjustment: %.2f kWh', kWhAdjustment), domoticz.LOG_DEBUG)
    domoticz.log(string.format('Original kWh: %.2f, Normalized kWh: %.2f', kWhUsed, normalizedKWh), domoticz.LOG_DEBUG)
    return normalizedKWh
-- Save data to CSV file
local function saveToCSV(data)
    local file = io.open(CONSTANTS.CSV_FILE_PATH, "a")
    if not file then return false end
    local fields = {
        os.date('%d-%m-%Y %H:%M'),
        math.floor(data.currentOdometer or 0),
        math.floor(data.batteryLevel or 0),
        math.floor(data.distance or 0),
        round2Decimals(data.kWhTotal),
        round2Decimals(data.kWhPartial),
        round2Decimals(data.evConsumption),
        round2Decimals(data.euro),
        round2Decimals(data.avgTemp)
    local csvLine = table.concat(fields, ";") .. "\n"
    file:write(csvLine)
    file:close()
    return true
-- Load data from CSV file
local function loadDataFromCSV()
    local file = io.open(CONSTANTS.CSV_FILE_PATH, "r")
    if not file then return nil end
    -- Skip the header line
    file:read("*l")
    local lastLine
    for line in file:lines() do
        lastLine = line
    file:close()
    if not lastLine then return nil end
    local fields = {}
    for field in string.gmatch(lastLine, "([^;]+)") do
        table.insert(fields, field)
        lastUpdate = fields[1],
        beginningOfTheMonthOdometer = tonumber(fields[2]),
        beginningOfTheMonthBatteryLevel = tonumber(fields[3]),
        beginningOfTheMonthkWhTotal = tonumber(fields[5]),
        avgTemp = tonumber(fields[9])
-- Process EV data and update display
local function processEVData(domoticz, sensorData, csvData)
    local kWhPartial = sensorData.currentkWhTotal - csvData.beginningOfTheMonthkWhTotal
    local euro = kWhPartial * CONSTANTS.PRICE_PER_KWH
    local distance = sensorData.currentOdometer - csvData.beginningOfTheMonthOdometer
    local normalizedKWh = normalizeToTargetLevel(domoticz, sensorData.batteryLevel, kWhPartial)
    local evConsumption = (distance > 0) and ((normalizedKWh / distance) * 100) or 0
    -- Log for debugging
    domoticz.log('kWhPartial: ' .. kWhPartial, domoticz.LOG_DEBUG)
    domoticz.log('euro: ' .. euro, domoticz.LOG_DEBUG)
    domoticz.log('distance: ' .. distance, domoticz.LOG_DEBUG)
    domoticz.log('normalizedKWh: ' .. normalizedKWh, domoticz.LOG_DEBUG)
    domoticz.log('evConsumption: ' .. evConsumption, domoticz.LOG_DEBUG)
    -- Prepare display data
    local displayData = {
        currentOdometer = sensorData.currentOdometer,
        batteryLevel = sensorData.batteryLevel,
        distance = distance,
        kWhPartial = kWhPartial,
        kWhTotal = sensorData.currentkWhTotal,
        euro = euro,
        avgTemp = sensorData.temperature,
        evConsumption = evConsumption,
        normalizedKWh = normalizedKWh,
        lastUpdate = os.date('%Y-%m-%d %H:%M:%S')
    -- Update display
    local currentMonth = os.date('%B')
    local displayText = formatDisplayText(displayData, currentMonth)
-- Main script
        devices = {'Charging Level', 'Reset EV Data'},
        timer = {'at 23:56'}
    logging = {
        level = domoticz.LOG_DEBUG,
        marker = "----- EV Consumption -----"
    data = {
        previousSelectorLevel = { initial = 0 }
        local csvData = loadDataFromCSV()
        if not csvData then
            domoticz.log('Failed to load data from CSV', domoticz.LOG_ERROR)
            return
        -- Read current sensor values
        local sensorData = {
            selectorLevel = domoticz.devices('Charging Level').levelVal,
            batteryLevel = domoticz.devices('XC40-ChargeLevel').nValue,
            currentOdometer = domoticz.devices('Volvo-Odometer').nValue,
            currentkWhTotal = domoticz.devices('Laadpaal').WhTotal / 1000,
            temperature = tonumber(domoticz.devices('Buitentemperatuur').sValue)
        -- Check if Charging Level changed from > 0 to 0
        if sensorData.selectorLevel == 0 and domoticz.data.previousSelectorLevel > 0 then
            -- Process data and update display
        -- Update previousSelectorLevel
        domoticz.data.previousSelectorLevel = sensorData.selectorLevel
        -- Save data to CSV only on the last day of the month at 23:56
        if isLastDayOfMonth() and device.isTimer then
                distance = sensorData.currentOdometer - csvData.beginningOfTheMonthOdometer,
                kWhPartial = sensorData.currentkWhTotal - csvData.beginningOfTheMonthkWhTotal,
                euro = (sensorData.currentkWhTotal - csvData.beginningOfTheMonthkWhTotal) * CONSTANTS.PRICE_PER_KWH,
                evConsumption = (sensorData.currentOdometer - csvData.beginningOfTheMonthOdometer > 0) and (((sensorData.currentkWhTotal - csvData.beginningOfTheMonthkWhTotal) / (sensorData.currentOdometer - csvData.beginningOfTheMonthOdometer)) * 100) or 0,
                normalizedKWh = normalizeToTargetLevel(domoticz, sensorData.batteryLevel, sensorData.currentkWhTotal - csvData.beginningOfTheMonthkWhTotal),
            saveToCSV(displayData)
EDIT 08-02-2025
I have done some cleaning up in the file and added Normalised kWh.
When charging state ~= TARGET_BATTERY_PERCENTAGE, partialkWh will be calculated to TARGET_BATTERY_PERCENTAGE.
In this way cuurent EV Consumtion is quite accurate.
The length of the script has shrunk from 404 to 256 lines
Here are the data that are displayed:
Current Odometer: 17349 km
Battery Level: 56 %
Distance February: 99 km
kWh February: 5.85 kWh
Costs February: 1.46 €
Average Temp: 2.8°C
EV Consumption: 26.66 kWh/100km
Battery level normalized to 82%
Original kWh loaded: 5.85 kWh
Normalized kWh: 26.39 kWh
Posted: Thursday 13 February 2025 13:11
by Tukker
Any idea what this is supposed to mean?
2025-02-13 13:10:10.201 Error: Volvo hardware (16) thread seems to have ended unexpectedly
2025-02-13 13:10:24.204 Error: Volvo hardware (16) thread seems to have ended unexpectedly
2025-02-13 13:10:38.207 Error: Volvo hardware (16) thread seems to have ended unexpectedly
2025-02-13 13:10:52.210 Error: Volvo hardware (16) thread seems to have ended unexpectedly
I deactivated and reactivated the plugin, no difference.
Posted: Thursday 13 February 2025 13:30
by akamming
HvdW wrote: Thursday 13 February 2025 13:11 Any idea what this is supposed to mean?
This error can occur if the Volvo API takes too lojng to respond. Will probably resolve itself
Posted: Monday 24 March 2025 12:12
by Tukker
This is what can be done with the Volvo plugin.
Posted: Friday 23 May 2025 13:07
by Tukker
I have a problem fetching Volvo-batteryChargeLevel
2025-05-23 12:03:00.874 Error: dzVents: ----- Car Charging Facts -----: There is no device with that name or id: Volvo-batteryChargeLevel
2025-05-23 12:03:00.874 Error: dzVents: ----- Car Charging Facts -----: An error occurred when calling event handler Car Charging Facts - 3
2025-05-23 12:03:00.874 Error: dzVents: ----- Car Charging Facts -----: ...pts/dzVents/generated_scripts/Car Charging Facts - 3.lua:133: attempt to index a nil value
2025-05-23 12:03:01.085 Error: dzVents: EV Fail-Safe: There is no device with that name or id: Volvo-batteryChargeLevel
2025-05-23 12:03:01.086 Error: dzVents: EV Fail-Safe: An error occurred when calling event handler Car charging on PV power - 11
2025-05-23 12:03:01.086 Error: dzVents: EV Fail-Safe: ...ents/generated_scripts/Car charging on PV power - 11.lua:60: attempt to index a nil value
Here are some devices.
		815	Volvo	YV1XZEHR4R2282899	68	Volvo-chargedTotal	General	kWh	167.688 kWh	-	-	   	2025-05-23 13:02:13
		816	Volvo	YV1XZEHR4R2282899	69	Volvo-usedKWH	General	kWh	148.794 kWh	-	-	   	2025-05-23 13:02:13
		817	Volvo	YV1XZEHR4R2282899	64	Volvo-chargedAtHome	General	kWh	0.000 kWh	-	-	   	2025-05-23 13:02:13
		818	Volvo	YV1XZEHR4R2282899	67	Volvo-chargedPublic	General	kWh	167.688 kWh	-	-	   	2025-05-23 13:02:13
		819	Volvo	YV1XZEHR4R2282899	65	Volvo-chargedPublicAC	General	kWh	167.688 kWh	-	-	   	2025-05-23 13:02:13
		820	Volvo	YV1XZEHR4R2282899	66	Volvo-chargedPublicDC	General	kWh	0.000 kWh	-	-	   	2025-05-23 13:02:13
		795	Volvo	YV1XZEHR4R2282899	84	Volvo-Car is moving or moved	Light/Switch	Switch	Off	-	-	   	2025-05-23 13:02:12
		829	Volvo	YV1XZEHR4R2282899	31	Volvo-MonthsToService	General	Custom Sensor	5 months	-	-	   	2025-05-23 12:55:02
		796	Volvo	YV1XZEHR4R2282899	15	Volvo-FrontLeftWindow	Light/Switch	Switch	Closed	-	-	   	2025-05-23 12:54:59
		832	Volvo	YV1XZEHR4R2282899	39	Volvo-engineCoolantLevel	General	Text	NO_WARNING	-	-	   	2025-05-23 02:10:27
		833	Volvo	YV1XZEHR4R2282899	38	Volvo-oilLevel	General	Text	NO_WARNING	-	-	   	2025-05-23 02:10:27
		834	Volvo	YV1XZEHR4R2282899	41	Volvo-BrakeLightCenterWarning	General	Text	NO_WARNING	-	-	   	2025-05-23 02:10:27
		835	Volvo	YV1XZEHR4R2282899	42	Volvo-BrakeLightLeftWarning	General	Text	NO_WARNING	-	-	   	2025-05-23 02:10:27
Watch the last updated times.
and the Volvo-batteryChargeLevel
		821	Volvo	YV1XZEHR4R2282899	3	Volvo-batteryChargeLevel	General	Percentage	76%	-	-	   	2025-05-22 20:44:43
		857	Volvo	YV1XZEHR4R2282899	79	Volvo-Last Known Location	General	Text	52.28826168607167;6.767776562791289;Unknown Adress;21614;148793.71421989275;76	-	-	   	2025-05-22 20:44:43
Of course I replaced the name with IDX to doublecheck and enabled and disabled the plugin several times.
Any idea what's going on or what I am missing here?
Posted: Friday 23 May 2025 13:09
by Tukker
		815	Volvo	YV1XZEHR4R	68	Volvo-chargedTotal	General	kWh	167.688 kWh	-	-	   	2025-05-23 13:02:13
		816	Volvo	YV1XZEHR4R	69	Volvo-usedKWH	General	kWh	148.794 kWh	-	-	   	2025-05-23 13:02:13
		817	Volvo	YV1XZEHR4R	64	Volvo-chargedAtHome	General	kWh	0.000 kWh	-	-	   	2025-05-23 13:02:13
		818	Volvo	YV1XZEHR4R	67	Volvo-chargedPublic	General	kWh	167.688 kWh	-	-	   	2025-05-23 13:02:13
		819	Volvo	YV1XZEHR4R	65	Volvo-chargedPublicAC	General	kWh	167.688 kWh	-	-	   	2025-05-23 13:02:13
		820	Volvo	YV1XZEHR4R	66	Volvo-chargedPublicDC	General	kWh	0.000 kWh	-	-	   	2025-05-23 13:02:13
		795	Volvo	YV1XZEHR4R	84	Volvo-Car is moving or moved	Light/Switch	Switch	Off	-	-	   	2025-05-23 13:02:12
		829	Volvo	YV1XZEHR4R	31	Volvo-MonthsToService	General	Custom Sensor	5 months	-	-	   	2025-05-23 12:55:02
		796	Volvo	YV1XZEHR4R	15	Volvo-FrontLeftWindow	Light/Switch	Switch	Closed	-	-	   	2025-05-23 12:54:59
		832	Volvo	YV1XZEHR4R	39	Volvo-engineCoolantLevel	General	Text	NO_WARNING	-	-	   	2025-05-23 02:10:27
		833	Volvo	YV1XZEHR4R	38	Volvo-oilLevel	General	Text	NO_WARNING	-	-	   	2025-05-23 02:10:27
		834	Volvo	YV1XZEHR4R	41	Volvo-BrakeLightCenterWarning	General	Text	NO_WARNING	-	-	   	2025-05-23 02:10:27
		835	Volvo	YV1XZEHR4R	42	Volvo-BrakeLightLeftWarning	General	Text	NO_WARNING	-	-	   	2025-05-23 02:10:27
		821	Volvo	YV1XZEHR4R	3	Volvo-batteryChargeLevel	General	Percentage	76%	-	-	   	2025-05-22 20:44:43
		857	Volvo	YV1XZEHR4R	79	Volvo-Last Known Location	General	Text	52.28826168607167;6.767776562791289;Unknown Adress;21614;148793.71421989275;76	-	-	   	2025-05-22 20:44:43
Posted: Friday 23 May 2025 13:34
by akamming
this is not ev AV plugin issue, it's a dzvents issue. i think you have better luck solving it if you post in that forum
Posted: Friday 23 May 2025 14:49
by Tukker
I can agree, however the fact that it is not updated may be a plugin issue.
Does it update in your Domoticz?
Posted: Friday 23 May 2025 16:01
by akamming
HvdW wrote: Friday 23 May 2025 14:49 I can agree, however the fact that it is not updated may be a plugin issue.
Yes. If it does not, there should be errors. The errors you show are dzvents errors, not python errors. Hence: Solve these first and see what happens
Posted: Friday 23 May 2025 18:11
by Tukker
Problem solved.
Changed device name from Volvo-batteryChargeLevel to Volvo-batteryLevel.
Naming convention in dzVents?
Posted: Friday 27 June 2025 14:31
by mvveelen
Feeling stupid here. I can't get this command to work:
curl -X GET 'https://api.volvocars.com/connected-vehicle/v2/vehicles'
  -H 'accept: application/json'
  -H 'authorization: Bearer <your-access-token>'
  -H 'vcc-api-key: <your-vcc-api-key>'
I have the <your-access-token> and also the <your-vcc-api-key>, but whatever I try I get the error:
                        "status": 401,
                        "error": {
                            "message": "Access denied due to missing header VCC-API-KEY. Make sure to provide a valid key for an active application."
                    }-bash: -H: command not found
Edit:
I renewed the keys, but when I check which cars are connected, I get below result. That means I took a wrong turn somewhere. How can I fix this?
  "data": [
    { "vin": "YV4952NA4F120DEMO" },
    { "vin": "LPSEFAVS2NPOLDEMO" }
Edit 2:
How?
Requests today:
2 out of 10 000
Edit 3:
It works. Probably had to wait a while before I saw the EX30 and then had to run authorize.py
Great :D
Posted: Friday 04 July 2025 14:24
by mvveelen
HvdW wrote: Sunday 17 November 2024 12:36 I just wrote some new text for my Volvo text sensor.
        if domoticz.devices('Volvo-aangesloten').state ~= 'Disconnected' then
            carConnected = 'Connected'
            carConnected = 'not Connected'
           if laadvermogen > 1000 then
            laadvermogen = domoticz.devices('Laadpaal').actualWatt/1000
            laadvermogen = 3600/1000  -- Watt to kWh
        -- calculate range
        local batteryCapacity = 79 -- kW
        local certainRange = 25    -- kWh/100km
        local currentRange = math.floor((domoticz.devices('XC40-ChargeLevel').state * batteryCapacity)/certainRange)
        local expectedRange = math.floor((domoticz.devices('XC40 battery charge set').levelVal * batteryCapacity)/certainRange)
        -- laadtijd berekenen tot dynamisch
        local resttijd = (batteryCapacity/100)*((domoticz.devices('XC40 battery charge set').levelVal - domoticz.devices('XC40-ChargeLevel').state))/laadvermogen
        domoticz.log('Battery set - Battery state '..domoticz.devices('XC40 battery charge set').levelVal..' - '.. domoticz.devices('XC40-ChargeLevel').state.. 'Laadvermogen : '..laadvermogen,domoticz.LOG_DEBUG)
        -- resttijd = round(resttijd,2)
        uren, honderdsten = math.modf(resttijd)
        minuten = honderdsten*60
        minuten = math.floor(minuten+0.5)
        -- certain range based on 25 kWh/100km
        domoticz.devices('Volvo').setIcon(107)
        domoticz.devices('Volvo').updateText('Charge level set &nbsp;&ensp;&emsp;&emsp;' .. tostring(domoticz.devices('XC40 battery charge set').levelVal) ..'%'..
            '\n Charge level actual &nbsp;&emsp;' .. tostring(domoticz.devices('XC40-ChargeLevel').nValue) ..'% '..
            '\n Plug connected &emsp;&emsp;&emsp;' .. carConnected ..
            -- '\n Plug connected &emsp;&emsp;&emsp;' .. chargingState ..
            '\n \n \n &emsp;&emsp;&emsp;&emsp; Expected range &ensp;&emsp;&emsp;' .. expectedRange ..' km '..
            '\n &emsp;&emsp;&emsp;&emsp; Current range &nbsp;&emsp;&emsp;&emsp;' .. currentRange ..' km'..
            '\n \n &emsp; Charging to '..tostring(domoticz.devices('XC40 battery charge set').levelVal)..'% : '.. tostring(uren) .. ' hours, ' .. tostring(minuten) .. ' minutes'..
            '\n &nbsp;')
Up till now it displayed Charging state and Set charging state.
It now displays Expected Range and Actual Range as well.
Range is calculated using an electricity consumption of 25 kWh/100 km which is based on the Spritmonitor consumption.
In summer our Volvo uses 23 kWh/100 km, in winter 25 kWh/100 km
Nice, but I can't figure out how to implement it myself. Yet. Any pushes in the right direction?
Posted: Friday 04 July 2025 16:42
by Tukker
What would you like to achieve?
Information from what sensors to be displayed.
Posted: Friday 04 July 2025 16:46
by mvveelen
Hi, actually what's in the custom text device so that I have an overview in just 1 place.
Not sure how I can accomplish this.
Posted: Friday 04 July 2025 17:34
by akamming
mvveelen wrote: Friday 04 July 2025 16:46 Hi, actually what's in the custom text device so that I have an overview in just 1 place.
several ways to go:
You could create a dzVents script to populate a text device or use something like dashticz to create your overview.
To be honest domoticz is a outdated for the UI (in my humble opinion, will not be a popular opinion in this forum), so you need more advanced ways to create simple overviews.
Tha'ts why i am now using a combi of domoticz (which is still far better than HA in flexibility in scripting, so I use it for the more complex scripting cases) and home assistant (for simple automations and dashboarding).
Alternatively: If you're an iphone user, you could also use https://github.com/PatchworkBoy/homebridge-edomoticz, to make apple home your dashboard. That was my setup before i moved to HA for that part.
Posted: Friday 04 July 2025 17:58
by mvveelen
I'm using Domoticz and I'm still OK with it. Tried Dashticz, but don't need other fancy stuff really. Such a Text device you showed, would be fine if I just know what DzVents or LUA script I could use to start with. I thought you had such a script already made for us to change to our set-up. If not, that's OK too and I will then try to figure out how myself.
Posted: Friday 04 July 2025 20:21
by Tukker
Like I mentioned before. What do you want to be displayed..
Give me the names of the devices and I'll show you.
Posted: Friday 04 July 2025 20:25
by mvveelen
Below are the devices mentioned, in the Text device you posted. I think this is a nice way of showing these devices in one place.
I think that if I know where to start, I can manage myself to add/adjust or remove devices/lines.
"Charge level actual" is called "VolvoEX30 Batterij level" in my set up
I think "Volvo-evccConnectedStatus" (value B) is the "Plug connected"?
"Expected range" is probably "Volvo-fullRange"
"Current range" is "VolvoEX30 range"
"Charging to 90%" is in my setup "VolvoEX30 laadtijd tot vol" and I think I'd better translate. Dutch is "ugly" for these kinds of devices :D
I can't find the "Charge level set" yet.
