Page 9 of 15
Re: Tesla hardware module
Posted: Wednesday 18 November 2020 21:38
by dyter
Is it possible to have alarm alert or sentry alert ?
Posted: Wednesday 02 December 2020 14:44
by chrispazz
Is it possibile to have Domoticz web interface loading in Tesla web browser?
I always get offline status....
Posted: Wednesday 02 December 2020 15:14
by rgroothuis
I would like to get a notification from the Tesla API into Domoticz when for example the Tesla is set into the gear to start riding.
When this is possible, I can make a rule in Domoticz that when the Tesla is home and out into the gear (start driving) to open the garage door automatically. Any idea, suggestions on how to do this?
Posted: Monday 07 December 2020 21:10
by chrispazz
chrispazz wrote:Is it possibile to have Domoticz web interface loading in Tesla web browser?
No help?
Posted: Tuesday 08 December 2020 0:07
by MrHobbes74
chrispazz wrote: Monday 07 December 2020 21:10
No help?
I do not know. But how is this related to the Tesla module in domoticz?
Perhaps it’s related to your router?
Posted: Tuesday 08 December 2020 0:12
by MrHobbes74
rgroothuis wrote: Wednesday 02 December 2020 15:14
Unfortunately this is not possible. The Tesla API is a polling based API. You don’t want to poll every second to overload the system, (besides that, a poll already cost 10 seconds) and 10 second delay for something like this is already too much. Also I don’t think the gear is a setting available in the Tesla api. Unfortunately the Tesla can not send out a command all by itself.
Posted: Tuesday 08 December 2020 0:18
by MrHobbes74
dyter wrote: Wednesday 18 November 2020 21:38
The car is polled every 20 minutes, or every minute when home and charging. The detection of an alert (if possible, I’m not sure) will be extremely late I’m afraid.....
Posted: Tuesday 08 December 2020 8:22
by rgroothuis
MrHobbes74 wrote: Tuesday 08 December 2020 0:18
I was more or less afraid of this, thanks for the confirmation. Based on polling this is not really going to work. THanks.
Posted: Tuesday 08 December 2020 8:25
by rgroothuis
MrHobbes74 wrote: Tuesday 08 December 2020 0:07
No help?
I guess this is about accessing the Domoticz from the display within the Tesla, correct? First question to answer, can you access your Domoticz from the outside world? Have you tested to make a connection from a mobile phone or computer when NOT on the local network. If this doesn't work, then from the Tesla it will for sure also not work. And you also need to look into SSL type certificates and connections, I guess Tesla is checking on a valid certificate when making a connection to a server like Domoticz.
I will try it from my Tesla in the next couple of days or so. Will let you know the outcome.
Posted: Tuesday 08 December 2020 15:53
by chrispazz
Yes, I am trying to access it from display within Tesla.
I am already using my domoticz instance from internet with a domain and a correct SSL (let's encrypt) certificate....
Posted: Thursday 10 December 2020 19:08
by rgroothuis
chrispazz wrote: Tuesday 08 December 2020 15:53
I tried it today, Tesla connected to my local network. Typed in the local IP address of my Domoticz server and nothing was displayed on screen. I guess Tesla is blocking a lot of things like Javascript etc. Only alternative way is work with fixed URL’s and/or build you own web-page.
Posted: Saturday 12 December 2020 22:16
by freijn
Top my knowledge Tesla builds a VPN to the Tesla network and then goto the internet. So you can only access the domoticz from a public ipaddress.
Posted: Sunday 13 December 2020 10:11
by Xylophone
Hi there
I’m new to the Tesla function and I can’t get the home location working. I cannot see the location reported by the Tesla in the logs, so unable to align the values with Domoticz settings.
Is there a deeper level of logging I can access please?
I’m on a recent NAS synology build
Tim
Posted: Sunday 13 December 2020 14:06
by MrHobbes74
To see the location, you need to enable debug logging mode in the settings.
Posted: Sunday 13 December 2020 14:47
by Xylophone
Hi. Thanks for reply
I got the following from debug:
{"gps_as_of":1607864476,"heading":261,"latitude":5x.xxx,"longitude":-0.xxx,"native_latitude":51.xxx,"native_location_supported":1,"native_longitude":-0.xxxx,"native_type":"wgs","power":0,"shift_state":null,"speed":null,"timestamp":1607866064846},"gui_settings":
And then changed my Domoticz location to xxxx Does it need closer accuracy than this, because it’s still reporting “not at home” in Domoticz.
Thanks in advance
Tim
Posted: Sunday 13 December 2020 15:11
by MrHobbes74
Yea you need to use all digits! What you put in still has a range of 400-500 meters.
Posted: Sunday 13 December 2020 15:44
by Xylophone
Ah. Good point thanks for the “doh”
Now working!
Tim
Posted: Sunday 13 December 2020 17:10
by MrHobbes74
Xylophone wrote: Sunday 13 December 2020 15:44
Now working!
Tim
Great!
Posted: Tuesday 19 January 2021 14:27
by dyter
I make a script for a short car home detection, because when the car is home I want to save energy.
And when the car isn't home, I log it because his always wake up (sentry, drive ...)
if (devicechanged['Tesla Ping'] == 'Off') then
commandArray['OpenURL'] ='http://127.0.0.1:8084/json.htm?type=command¶m=updatehardware&htype=120&username=[username]&password=[password]'&name=Tesla&enabled=true&idx=18&datatimeout=0&extra=[VIN]&Mode1=5&Mode2=5&Mode3=1 AFTER 1'
elseif devicechanged['Tesla Ping'] == 'On' then
commandArray['OpenURL'] ='http://127.0.0.1:8084/json.htm?type=command¶m=updatehardware&htype=120&username=[username]&password=[password]'&name=Tesla&enabled=true&idx=18&datatimeout=0&extra=[VIN]&Mode1=60&Mode2=5&Mode3=0 AFTER 1'
Perhaps you can and a default interval for each car status (home, not home, charging ...) ?
Posted: Friday 29 January 2021 18:20
by PVuser
Can you help me how to update an oder version of this module? I can't find the original installation instruction and no instruction to update an existing one?
Also I have an feature request: Perhaps you can implement an counter for the car status (awake or not) to see, how long and at which time the car sleeps.
