Tesla hardware module
dyter
Domoticz version: 8841
Re: Tesla hardware module
Post by dyter »
Is it possible to have alarm alert or sentry alert ?
Domoticz v2024.1 on Synology Docker host, RFLink, ESPEasy wemos D1, Ecodevices, relays x8, dahua doorbell, reolink cameras ....
chrispazz
Post by chrispazz »
Is it possibile to have Domoticz web interface loading in Tesla web browser?
I always get offline status....
rgroothuis
Post by rgroothuis »
I would like to get a notification from the Tesla API into Domoticz when for example the Tesla is set into the gear to start riding.
When this is possible, I can make a rule in Domoticz that when the Tesla is home and out into the gear (start driving) to open the garage door automatically. Any idea, suggestions on how to do this?
chrispazz
Post by chrispazz »
chrispazz wrote:Is it possibile to have Domoticz web interface loading in Tesla web browser?
No help?
MrHobbes74
Domoticz version: latest B
Post by MrHobbes74 »
chrispazz wrote: Monday 07 December 2020 21:10
No help?
I do not know. But how is this related to the Tesla module in domoticz? 😉 Perhaps it’s related to your router?
MrHobbes74
rgroothuis wrote: Wednesday 02 December 2020 15:14 I would like to get a notification from the Tesla API into Domoticz when for example the Tesla is set into the gear to start riding.
Unfortunately this is not possible. The Tesla API is a polling based API. You don’t want to poll every second to overload the system, (besides that, a poll already cost 10 seconds) and 10 second delay for something like this is already too much. Also I don’t think the gear is a setting available in the Tesla api. Unfortunately the Tesla can not send out a command all by itself.
MrHobbes74
dyter wrote: Wednesday 18 November 2020 21:38 Is it possible to have alarm alert or sentry alert ?
The car is polled every 20 minutes, or every minute when home and charging. The detection of an alert (if possible, I’m not sure) will be extremely late I’m afraid.....
rgroothuis
MrHobbes74 wrote: Tuesday 08 December 2020 0:18
I was more or less afraid of this, thanks for the confirmation. Based on polling this is not really going to work. THanks.
rgroothuis
MrHobbes74 wrote: Tuesday 08 December 2020 0:07
No help?
I guess this is about accessing the Domoticz from the display within the Tesla, correct? First question to answer, can you access your Domoticz from the outside world? Have you tested to make a connection from a mobile phone or computer when NOT on the local network. If this doesn't work, then from the Tesla it will for sure also not work. And you also need to look into SSL type certificates and connections, I guess Tesla is checking on a valid certificate when making a connection to a server like Domoticz.
I will try it from my Tesla in the next couple of days or so. Will let you know the outcome.
chrispazz
Post by chrispazz »
Yes, I am trying to access it from display within Tesla.
I am already using my domoticz instance from internet with a domain and a correct SSL (let's encrypt) certificate....
rgroothuis
chrispazz wrote: Tuesday 08 December 2020 15:53 Yes, I am trying to access it from display within Tesla.
I tried it today, Tesla connected to my local network. Typed in the local IP address of my Domoticz server and nothing was displayed on screen. I guess Tesla is blocking a lot of things like Javascript etc. Only alternative way is work with fixed URL’s and/or build you own web-page.
freijn
Domoticz version: Stable
Post by freijn »
Top my knowledge Tesla builds a VPN to the Tesla network and then goto the internet. So you can only access the domoticz from a public ipaddress.
Xylophone
Post by Xylophone »
Hi there
I’m new to the Tesla function and I can’t get the home location working. I cannot see the location reported by the Tesla in the logs, so unable to align the values with Domoticz settings.
Is there a deeper level of logging I can access please?
I’m on a recent NAS synology build
Tim
MrHobbes74
To see the location, you need to enable debug logging mode in the settings.
Xylophone
Post by Xylophone »
Hi. Thanks for reply
I got the following from debug:
{"gps_as_of":1607864476,"heading":261,"latitude":5x.xxx,"longitude":-0.xxx,"native_latitude":51.xxx,"native_location_supported":1,"native_longitude":-0.xxxx,"native_type":"wgs","power":0,"shift_state":null,"speed":null,"timestamp":1607866064846},"gui_settings":
And then changed my Domoticz location to xxxx Does it need closer accuracy than this, because it’s still reporting “not at home” in Domoticz.
Thanks in advance
Tim
Last edited by Xylophone on Sunday 13 December 2020 15:48, edited 1 time in total.
MrHobbes74
Yea you need to use all digits! What you put in still has a range of 400-500 meters.
Xylophone
Post by Xylophone »
Ah. Good point thanks for the “doh” 😀
Now working!
Tim
MrHobbes74
Xylophone wrote: Sunday 13 December 2020 15:44 Ah. Good point thanks for the “doh” 😀
Now working!
Tim
Great!
dyter
Post by dyter »
MrHobbes74 wrote: Tuesday 08 December 2020 0:18 The car is polled every 20 minutes, or every minute when home and charging. The detection of an alert (if possible, I’m not sure) will be extremely late I’m afraid.....
I make a script for a short car home detection, because when the car is home I want to save energy.
And when the car isn't home, I log it because his always wake up (sentry, drive ...)
if (devicechanged['Tesla Ping'] == 'Off') then
	commandArray['OpenURL'] ='http://127.0.0.1:8084/json.htm?type=command&param=updatehardware&htype=120&username=[username]&password=[password]'&name=Tesla&enabled=true&idx=18&datatimeout=0&extra=[VIN]&Mode1=5&Mode2=5&Mode3=1 AFTER 1'
elseif devicechanged['Tesla Ping'] == 'On' then
	commandArray['OpenURL'] ='http://127.0.0.1:8084/json.htm?type=command&param=updatehardware&htype=120&username=[username]&password=[password]'&name=Tesla&enabled=true&idx=18&datatimeout=0&extra=[VIN]&Mode1=60&Mode2=5&Mode3=0 AFTER 1'
Perhaps you can and a default interval for each car status (home, not home, charging ...) ?
PVuser
Domoticz version: 2021.1
Post by PVuser »
Can you help me how to update an oder version of this module? I can't find the original installation instruction and no instruction to update an existing one?
Also I have an feature request: Perhaps you can implement an counter for the car status (awake or not) to see, how long and at which time the car sleeps.
