Python Plugin : Broadlink RM2 V4
parrotface
Re: Python Plugin : Broadlink RM2 V4
Post by parrotface »
Am I correct in thinking that the broadlink plugin will NOT work with version 3.8153 the last stable version and that I need to use a Beta version above 3.90xx
zak45
Domoticz version: V2024.4
Post by zak45 »
parrotface wrote: Friday 20 April 2018 10:55 Am I correct in thinking that the broadlink plugin will NOT work with version 3.8153 the last stable version and that I need to use a Beta version above 3.90xx
Right for the V 4.x, you can still use V 3 if you want. all in dropbox.
madrian
Post by madrian »
zak45: any idea for my previous post?
zak45
Post by zak45 »
madrian wrote: Friday 20 April 2018 19:05 zak45: any idea for my previous post?
Not enough information. Put plugin in debug mode and provide full log. Need also domoticz version and OS
madrian
Post by madrian »
Hmm, it's already turned on.
Screen Shot 2018-04-21 at 21.44.12.png (389.79 KiB) Viewed 3684 times
Log after restarting domoticz:
2018-04-21 21:49:02.122 Domoticz V3.9269 (c)2012-2018 GizMoCuz
2018-04-21 21:49:02.123 Build Hash: e8b89e5f, Date: 2018-04-18 18:17:31
2018-04-21 21:49:02.123 Startup Path: /home/madrian/domoticz/
2018-04-21 21:49:02.151 Sunrise: 05:45:00 SunSet: 19:43:00
2018-04-21 21:49:02.151 Day length: 13:58:00 Sun at south: 12:05:00
2018-04-21 21:49:02.151 Civil twilight start: 05:12:00 Civil twilight end: 20:16:00
2018-04-21 21:49:02.151 Nautical twilight start: 04:31:00 Nautical twilight end: 20:57:00
2018-04-21 21:49:02.151 Astronomical twilight start: 03:45:00 Astronomical twilight end: 21:43:00
2018-04-21 21:49:02.151 EventSystem: reset all events...
2018-04-21 21:49:02.488 PluginSystem: Started, Python version '3.5.3'.
2018-04-21 21:49:02.492 Active notification Subsystems: email, pushover (2/14)
2018-04-21 21:49:02.501 WebServer(HTTP) started on address: 0.0.0.0 with port 8080
2018-04-21 21:49:02.503 Proxymanager started.
2018-04-21 21:49:02.504 Starting shared server on: 0.0.0.0:6144
2018-04-21 21:49:02.504 TCPServer: shared server started...
2018-04-21 21:49:02.504 RxQueue: queue worker started...
2018-04-21 21:49:04.505 XiaomiGateway: will listen on 9898 for hardware id 8
2018-04-21 21:49:04.505 XiaomiGateway: Delaying worker startup...
2018-04-21 21:49:04.828 Incoming connection from: 192.168.1.54
2018-04-21 21:49:09.505 XiaomiGateway: Worker started...
2018-04-21 21:49:09.506 (Xiaomi Mi Flower Mate) Started.
2018-04-21 21:49:09.506 (Broadlink RM3 mini) Started.
2018-04-21 21:49:09.601 Python EventSystem: Initalizing event module.
2018-04-21 21:49:09.601 EventSystem: Started
2018-04-21 21:49:09.601 EventSystem: Queue thread started...
2018-04-21 21:49:09.672 PluginSystem: Entering work loop.
2018-04-21 21:49:09.770 (Xiaomi Mi Flower Mate) Entering work loop.
2018-04-21 21:49:09.770 (Xiaomi Mi Flower Mate) Initialized version 1.0.0, author 'blauwebuis'
2018-04-21 21:49:10.015 (Broadlink RM3 mini) Entering work loop.
2018-04-21 21:49:10.015 (Broadlink RM3 mini) Initialized version 4.1.0, author 'zak45'
And no "Learn" device was created. :|
zak45
Post by zak45 »
madrian wrote: Saturday 21 April 2018 21:54 Hmm, it's already turned on.
What you can do: try to create another HW but first be sure that in Domoticz the accept new hardware/devices settings has been checked.
madrian
Post by madrian »
Done, but all I see is:
2018-04-22 21:11:36.706 (RMMini3) Started.
2018-04-22 21:13:00.455 Error: RMMini3 hardware (13) thread seems to have ended unexpectedly
and there is no new device (accept new devices is enabled). :(
I am on Ubuntu 16.04, is there any dependency needed?
HarleyZard
Post by HarleyZard »
Hi Madrian, Zak45,
Thanks Zak45 for your plugin, but I can't use it : I've exactly the same problem than Madrian.
Raspberry 3
Domoticz V3.9139
2018-04-24 22:40:32.808 Domoticz V3.9139 (c)2012-2018 GizMoCuz
2018-04-24 22:40:32.808 Build Hash: 75213953, Date: 2018-03-31 08:19:09
2018-04-24 22:40:32.808 Startup Path: /home/pi/domoticz/
2018-04-24 22:40:32.834 Sunrise: 06:35:00 SunSet: 20:57:00
2018-04-24 22:40:32.834 Day length: 14:22:00 Sun at south: 13:05:00
2018-04-24 22:40:32.834 Civil twilight start: 05:59:00 Civil twilight end: 21:33:00
2018-04-24 22:40:32.834 Nautical twilight start: 05:14:00 Nautical twilight end: 22:18:00
2018-04-24 22:40:32.834 Astronomical twilight start: 04:21:00 Astronomical twilight end: 23:11:00
2018-04-24 22:40:32.834 EventSystem: reset all events...
2018-04-24 22:40:32.975 PluginSystem: Started, Python version '3.5.3'.
2018-04-24 22:40:32.984 Active notification Subsystems: (0/14)
2018-04-24 22:40:32.985 WebServer(HTTP) started on address: :: with port 8080
2018-04-24 22:40:32.996 WebServer(SSL) started on address: :: with port 443
2018-04-24 22:40:32.998 Proxymanager started.
2018-04-24 22:40:32.999 Starting shared server on: :::6144
2018-04-24 22:40:32.999 TCPServer: shared server started...
2018-04-24 22:40:32.999 RxQueue: queue worker started...
2018-04-24 22:40:35.000 Wunderground: Worker started...
2018-04-24 22:40:35.003 Hardware Monitor: Started
2018-04-24 22:40:35.020 (MyBroadlink) Started.
2018-04-24 22:40:35.021 EventSystem: reset all events...
2018-04-24 22:40:35.022 EventSystem: reset all device statuses...
2018-04-24 22:40:35.196 Python EventSystem: Initalizing event module.
2018-04-24 22:40:35.197 EventSystem: Started
2018-04-24 22:40:35.197 EventSystem: Queue thread started...
2018-04-24 22:40:35.335 PluginSystem: Entering work loop.
2018-04-24 22:40:36.046 (MyBroadlink) Entering work loop.
2018-04-24 22:40:36.047 (MyBroadlink) Initialized version 4.1.0, author 'zak45'
2018-04-24 22:40:45.431 (Méteo Lille) Temp + Humidity + Baro (Météo Lille)
2018-04-24 22:40:45.433 (Méteo Lille) Wind (Unknown)
2018-04-24 22:40:45.435 (Méteo Lille) Rain (Unknown)
and when I close domoticz :
^C2018-04-24 22:58:47.749  Closing application!...
2018-04-24 22:58:47.749  Stopping worker...
2018-04-24 22:58:47.749  RxQueue: queue worker stopped...
2018-04-24 22:58:47.750  WebServer(HTTP) stopped
2018-04-24 22:58:48.251  WebServer(SSL) stopped
2018-04-24 22:58:48.752  TCPServer: shared server stopped
2018-04-24 22:58:48.753  Stopping all hardware...
2018-04-24 22:58:48.833  Wunderground: Worker stopped...
2018-04-24 22:58:49.126  Hardware Monitor: Stopped...
2018-04-24 22:58:49.127  (MyBroadlink) Stop directive received.
2018-04-24 22:58:49.244  (MyBroadlink) Exiting work loop.
2018-04-24 22:58:54.131  Error: (MyBroadlink) Plugin did not stop after 5 seconds, flushing event queue...
2018-04-24 22:58:54.131  Error: (MyBroadlink) Callback event 'onHeartbeatCallback' (Python call 'onHeartbeat') discarded.
2018-04-24 22:58:54.132  Error: (MyBroadlink) Callback event 'onHeartbeatCallback' (Python call 'onHeartbeat') discarded.
And no device was created, and I've autorize new dispositif....
I'm on this problem for 2 weeks, but impossible for me to find a solution :roll:
Do yoy have an idea Zak45 ? :roll:
Thanks...
Lars65
Post by Lars65 »
seems like I have some trouble with pyaes, running raspbian stretch:
2018-04-25 12:38:44.089 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/broadlink/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-04-25 12:38:44.089 Error: (Discover) Module Import failed, exception: 'ImportError'
2018-04-25 12:38:44.089 Error: (Discover) Module Import failed: ' Name: pyaes'
2018-04-25 12:38:44.089 Error: (Discover) Error Line details not available
HarleyZard
madrian wrote: Sunday 22 April 2018 21:14 Done, but all I see is:
Madrian,
Do you test this solution : viewtopic.php?f=6&t=21900&p=168648&hili ... d.#p168648
(upgrade python to 3.6)
(I'll try this evening)
Xfiles
Post by Xfiles »
‌I'm not sure if my problem is like other from thist topic. I have installed python, copied files to BroadlinkRM2 folder (like mentioned in wiki). I added new hardware and then Domoticz crashed. Domoticz service was running but page was not responsive. I managed to restore domoticz by doing upgrade to stable version (I use normally beta). After this domoticz started working normally. I removed Broadlink from hardware list and upgraded domoticz to beta version and everything is ok now. What I should do to use Broadlink in beta version of domoticz.
wawjan
Post by wawjan »
Hello
It also has the same problems.
Is it possible for someone to share an image of an SD card with a clean domoticzem and a working Broadlink plugin.
Sorry for my English.
satanasinc
Domoticz version: 4.9700
Post by satanasinc »
Hi!!
First of all please excuse my bad english.
Yesterday i installed my brand new RM Mini3 in domoticz without problems. Now learn, test and save perfectly.
The plugin adds a complete remote control in the switches panel and it works great, but someone knows how to add another one to control the TV and the sat box for example?.
I need add more complete remotes.
Thanx in advance for your help and thanks for the great job to the developer. Youre great!
Greetings from spain!
wawjan
Post by wawjan »
What can be the reason that after loading the plugin, it blocks the operation of other plugins.
Wszystkie
Status
Błędy
Filtr:
X
2018-04-26 22:29:16.648 Domoticz V3.9326 (c)2012-2018 GizMoCuz
2018-04-26 22:29:16.648 Build Hash: a24ebc05, Date: 2018-04-26 16:06:01
2018-04-26 22:29:16.648 Startup Path: /home/pi/domoticz/
2018-04-26 22:29:17.024 Sunrise: 05:25:00 SunSet: 20:07:00
2018-04-26 22:29:17.024 Day length: 14:43:00 Sun at south: 12:05:00
2018-04-26 22:29:17.024 Civil twilight start: 04:46:00 Civil twilight end: 20:46:00
2018-04-26 22:29:17.024 Nautical twilight start: 03:55:00 Nautical twilight end: 21:37:00
2018-04-26 22:29:17.024 Astronomical twilight start: 02:52:00 Astronomical twilight end: 22:40:00
2018-04-26 22:29:17.024 EventSystem: reset all events...
2018-04-26 22:29:17.751 PluginSystem: Started, Python version '3.4.2'.
2018-04-26 22:29:17.793 Active notification Subsystems: (0/14)
2018-04-26 22:29:17.862 WebServer(HTTP) started on address: :: with port 8080
2018-04-26 22:29:17.929 WebServer(SSL) started on address: :: with port 443
2018-04-26 22:29:17.931 Proxymanager started.
2018-04-26 22:29:17.933 Starting shared server on: :::6144
2018-04-26 22:29:17.933 TCPServer: shared server started...
2018-04-26 22:29:17.933 RxQueue: queue worker started...
2018-04-26 22:29:19.934 Hardware Monitor: Started
2018-04-26 22:29:19.996 OpenWeatherMap: Started
2018-04-26 22:29:19.996 (Speedtest) Started.
2018-04-26 22:29:19.997 XiaomiGateway: will listen on 9898 for hardware id 7
2018-04-26 22:29:20.004 XiaomiGateway: Delaying worker startup...
2018-04-26 22:29:25.004 (Pi Monitor) Started.
2018-04-26 22:29:25.004 (Yamaha) Started.
2018-04-26 22:29:25.004 (Broadlink) Started.
2018-04-26 22:29:25.005 EventSystem: reset all events...
2018-04-26 22:29:25.005 EventSystem: reset all device statuses...
2018-04-26 22:29:25.006 XiaomiGateway: Worker started...
2018-04-26 22:29:25.082 XiaomiGateway: Using 192.168.1.150 for local IP address.
2018-04-26 22:29:25.123 PluginSystem: Entering work loop.
2018-04-26 22:29:25.169 XiaomiGateway: RGB Gateway Detected
2018-04-26 22:29:25.191 (Bramka Xiaomi) Temp (Xiaomi Temperature)
2018-04-26 22:29:25.192 (Bramka Xiaomi) Humidity (Xiaomi Humidity)
2018-04-26 22:29:25.193 (Bramka Xiaomi) General/Pressure (Xiaomi Pressure)
2018-04-26 22:29:25.203 (Bramka Xiaomi) Lux (Aqara Motion Sensor)
2018-04-26 22:29:25.205 (Bramka Xiaomi) Temp (Xiaomi Temperature)
2018-04-26 22:29:25.206 (Bramka Xiaomi) Humidity (Xiaomi Humidity)
2018-04-26 22:29:25.214 Python EventSystem: Initalizing event module.
2018-04-26 22:29:25.215 (Bramka Xiaomi) Temp (Xiaomi Temperature)
2018-04-26 22:29:25.217 EventSystem: Started
2018-04-26 22:29:25.218 EventSystem: Queue thread started...
2018-04-26 22:29:25.219 (Bramka Xiaomi) Humidity (Xiaomi Humidity)
2018-04-26 22:29:25.220 (Bramka Xiaomi) General/Pressure (Xiaomi Pressure)
2018-04-26 22:29:25.363 (Pogoda) Temp + Humidity + Baro (THB)
2018-04-26 22:29:25.369 (Pogoda) Wind (Wind)
2018-04-26 22:29:25.375 (Pogoda) General/Visibility (Visibility)
2018-04-26 22:29:25.381 (Pogoda) General/Percentage (Clouds %)
2018-04-26 22:29:25.579 (Speedtest) Entering work loop.
2018-04-26 22:29:25.579 (Speedtest) Initialized version 1.3.0, author 'Xorfor'
2018-04-26 22:29:25.692 (Pi Monitor) Entering work loop.
2018-04-26 22:29:25.692 (Pi Monitor) Initialized version 1.1.0, author 'Xorfor'
2018-04-26 22:29:25.895 (Yamaha) Entering work loop.
2018-04-26 22:29:25.895 (Yamaha) Initialized version 2.0.0, author 'thomasvillagers'
2018-04-26 22:29:27.241 (Broadlink) Entering work loop.
2018-04-26 22:29:27.241 (Broadlink) Initialized version 4.0.0, author 'zak45'
zak45
Post by zak45 »
wawjan wrote: Thursday 26 April 2018 22:35 What can be the reason that after loading the plugin, it blocks the operation of other plugins.
Wszystkie
Status
Błędy
Filtr:
X
try the 4.1.0 to see if it's better.
zak45
Post by zak45 »
Lars65 wrote: Wednesday 25 April 2018 12:40 seems like I have some trouble with pyaes, running raspbian stretch:
show this output:
sudo pip3 show broadlink
sudo pip3 show pyaes
zak45
Post by zak45 »
satanasinc wrote: Thursday 26 April 2018 20:30 Hi!!
Create another HW by using same parameters (RM Mini3). this will give you another HW Id and create another remote control that you can customize.
zak45
Post by zak45 »
HarleyZard wrote: Tuesday 24 April 2018 22:53 Hi Madrian, Zak45,
Raspberry 3
Domoticz V3.9139
Thanks...
put the debug mode on and post the log output.
satanasinc
zak45 wrote: Friday 27 April 2018 23:30 [quote=satanasinc post_id=178888 time=<a href="tel:1524767431">1524767431</a> user_id=7387]
Hi!!
[/quote]
Thanks zak45 I will try.
Regards.
Xfiles
Post by Xfiles »
Can anyone help me with problem described few posts above? (domoticz doesn't work after I add broadlink hardware). Do you have any idea what can be a reason of that?
