Page 9 of 49
Re: Dashticz - Module - Garbage collector
Posted: Monday 19 June 2017 14:18
by robgeerts
I've fixed Swifty's problem with latest beta!
Do you have latest beta? Otherwise, could you send me your ical-link by PM ?
Posted: Monday 19 June 2017 17:03
by raymond
raymond wrote:robgeerts wrote:htilburgs wrote:Currently my Trashcan plugin won't load, it's only saying "Loading......"
Has anybody else this problem right now?
Please send me the piece of code of the trashcan in config.js..
Have the very same problem all of a sudden. It says Loading...
Did this get resolved in the end? And how can I try to fix?
Ray
My problem is fixed also in the latest beta of today !
Thanks,
Ray
Posted: Sunday 25 June 2017 21:54
by lukev
Mmm... I too, have the 'loading' problem with my garbage from Afvalwijzer.
Here is my code:
var trashcan = {}
trashcan.afvalwijzer = { trashapp: 'mijnafvalwijzer', maxitems: 6, width:12, zipcode:'xxxxxx', housenumber:'xx' }
Just updated to the latest beta...
Posted: Monday 26 June 2017 10:14
by robgeerts
Could you PM me your zipcode and housenumber?
Posted: Monday 26 June 2017 17:50
by lukev
robgeerts wrote:Could you PM me your zipcode and housenumber?
Done!
Posted: Monday 26 June 2017 21:56
by robgeerts
Check with latest beta
Posted: Monday 26 June 2017 22:47
by lukev
robgeerts wrote:Check with latest beta
whoop whoop! Everything seems OK again!
Posted: Friday 30 June 2017 21:17
by JohD50
Ik hope somebody can help me. I try to use the afvalwijzer, but nothing on the dashboard.
I added this lines to CONFIG.js
var trashcan = {}
trashcan.afvalwijzer = { trashapp: 'mijnafvalwijzer', maxitems: 10, width:12, zipcode:'6871XX', housenumber:'YY' }
I tried also with and without:
columns[1] = {}
columns[1]['width'] = 2;
columns[1]['blocks'] = [trashcan.mijnafvalwijzer]
also tried:
var _USE_FAVORITES = false or true, do difference
When i use in the browser
http://www.mijnafvalwijzer.nl/nl/6871XX/YY, I get the right answer
I use latest betas of DomoticZ and Dahticz
What did i wrong
Posted: Friday 30 June 2017 22:12
by HansieNL
JohD50 wrote:Ik hope somebody can help me. I try to use the afvalwijzer, but nothing on the dashboard.
var trashcan = {}
columns[1] = {}
also tried:
What did i wrong
Have you tried...
var _USE_AUTO_POSITIONING =false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = false; //only used when using auto positioning
Don't forget to add a screen and add
var columns = {}
Posted: Friday 30 June 2017 22:17
by htilburgs
I think in your case it's trashcan.afvalwijzer and not trashcan.mijnafvalwijzer in the blocks section.
[columns[1]['blocks'] = [trashcan.afvalwijzer]
Posted: Saturday 01 July 2017 8:58
by JohD50
Thx HansieNL and htilburgs, tips helped to bring the info on the dashboard.
Posted: Thursday 13 July 2017 10:30
by Blueone
Is it possible to refresh the trash calendar a bit more often? For example, I have the complete dashtics refresh every 24hour. but I often have trash"tomorrow" while it should already be today because it isn't refreshed. It would be nice if that part could have a separate refresh, the same as the weather.
Posted: Thursday 13 July 2017 10:39
by robgeerts
@Blueone, in latest beta it refreshes every 15 minutes now.
Posted: Monday 17 July 2017 8:59
by axelbaas
Hi Rob,
Is it possible to add
https://www.vianen.nl/afval/afvalkalender/ ?
When i fill in my zipcode, there is an option to download a ICS file. According to
http://ical-to-json.herokuapp.com/ it is a JSON file.
For testing purposes you can use this zipcode ; 4125RG / number 12.
I'll hope you can add this! Tnx in advance!
Posted: Monday 17 July 2017 10:32
by stlaha2007
Nice work... Finally got the TrashCollector running...
Running behind a 'very' restricted firewall/router with Advertisement-/Misbehaving Hosts Blocker.
Within the script theres a host that transforms the json reply from several sites to eliminate crosssite ssl failures. Not a big deal however the host used is located under herokuapp.com where some are listed as misbehaving software hosters.
To resolve this i figured the following solution:
Simple but affective for those running a centrally located AdBlocker like me, or on there smartphone/tablets. Just exclude the host cors-anywhere.herokuapp.com.
In my specific case with dnsmasq it did NOT listen to the exclusion, so a had to add a specific nameserver redirect for cors-anywhere.herokuapp.com to an external nameserver. It is mentioned on several forums like: server=/cors-anywhere.herokuapp.com/8.8.8.8
Sent from my K00C using Tapatalk
Posted: Monday 17 July 2017 10:53
by robgeerts
Just added to latest BETA!
Add in config.js:
var trashcan = {}
trashcan.vianen = { trashapp: 'vianen', maxitems: 6, width:12, zipcode:'4125RG', housenumber:'12' }
Posted: Monday 17 July 2017 10:56
by webrazor
Wow thats a great module can you add the waste calender for Hellendoorn to?
http://hellendoornafvalkalender.2go-mobile.com/
Posted: Saturday 29 July 2017 13:05
by benbammens
Where I live in Belgium we have an other way of defining the days the garbage is collected. It works with a google calendar. Would this be possible to implement in Dashticz?
Here is an example of the calendar: webcal://
www.limburg.net/ics/afvalkalender/71011/9744/119/0
Posted: Sunday 30 July 2017 12:19
by robgeerts
Try something like:
(Add your own ical url)
Var trashcan = {}
trashcan.ical = { width:6, maxitems: 10, trashapp:'ical', icalurl: 'https://calendar.google.com/calendar/basic.ics' }
Posted: Sunday 30 July 2017 14:03
by benbammens
robgeerts wrote:Try something like:
Var trashcan = {}
Does not work I'm afraid. I can generate an ical url from my google calendar but since it is not a shared calendar dashticz can not see it. And I can not share it so it seems since it is an external calendar...
