Dashticz - Bug report
Locked
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Bug report
Post by robgeerts »
gielie wrote: Thursday 10 August 2017 15:34 HI Rob,
The following code doesn't work anymore in the latest beta.
function getBlock_6(device,idx){
   $('.block_'+idx);
   var html='';
   html+='<div class="col-xs-4 col-icon">';
      if(device['Status']=='Off') html+='<img src="img/cust_away.png" class="off icon" />';
      else html+='<img src="img/cust_home.png" class="on icon" />';
   html+='</div>';
   html+='<div class="col-xs-8 col-data">';
   html+='<strong class="title">'+device['Name']+'</strong><br />';
   if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
   else html+='<span class="state">AANWEZIG</span>';
   if((_SHOW_LASTUPDATE && (typeof(blocks[idx])=='undefined' || typeof(blocks[idx]['hide_lastupdate'])=='undefined' || blocks[idx]['hide_lastupdate']===false)) || (!_SHOW_LASTUPDATE && (typeof(blocks[idx])!=='undefined' && typeof(blocks[idx]['show_lastupdate'])!=='undefined' && blocks[idx]['show_lastupdate']==true))  ){
          html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
   html+='</div>';
   return html;
Its the presence switch with is no a on/off again instead of a aan/afwezig.
Can you fix this?
Replace code with:
function getBlock_117(device,idx,result){
   var html='';
   html+='</div>';
	if((settings['last_update']==1 && (typeof(blocks[idx])=='undefined' || typeof(blocks[idx]['hide_lastupdate'])=='undefined' || blocks[idx]['hide_lastupdate']===false)) ||
	(settings['last_update']==0 && (typeof(blocks[idx])!=='undefined' && typeof(blocks[idx]['show_lastupdate'])!=='undefined' && blocks[idx]['show_lastupdate']==true))
		html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(settings['timeformat'])+'</span>';
   html+='</div>';
   return html;
Blueone
Post by Blueone »
robgeerts wrote: Tuesday 08 August 2017 22:43 Yes, thats the plugin I use to show a colorpicker..
Is it maybe possible to have an option to disable the RGB functionallity for the being? :)
robgeerts
Post by robgeerts »
Well not everyone has this problem, depending on the device Dashticz is running on...
I will check if theres another colorpicker-plugin I can use.
gielie
Domoticz version: latest β
Post by gielie »
robgeerts wrote: Thursday 10 August 2017 15:39
   $('.block_'+idx);
   var html='';
   html+='</div>';
   html+='</div>';
   return html;
Can you fix this?
Replace code with:
   var html='';
   html+='</div>';
   html+='</div>';
   return html;
Thanks for the help but the code doesn't work, when i switch back to the master the old code works great, thus only in the beta it doesn't work.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
Wich master, the current one or an old one you have?
freakshock
Post by freakshock »
robgeerts wrote: Friday 11 August 2017 9:25 Well not everyone has this problem, depending on the device Dashticz is running on...
I had the same problem with the dashboard becoming unresponsive.
I could see the seconds of the clock freezing a few seconds and then unfreezing again.
This problem only occured on my android tablet (fully kiosk browser).
On Windows/Chrome I did not have this problem.
I removed the RGB lamps as a test and voila, dashboard fully responsive on the android tablet.
I'll try blocking out the RGB color picker element in custom css for now when I have time to find the code. Unless someone can already tell me the custom css? ;)
EDIT: Rob temporarily removed the RGB colorpicker in the latest beta, so that's a solution for the performance issues until a better solution is found!
gielie
Post by gielie »
I still have a problem with the aan/afwezig code, can't figure out why its not working.
//Thuis
function getBlock_536(device,idx){
   $('.block_'+idx);
   var html='';
      if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon');
      else html+=iconORimage(idx,'fa-toggle-on','','on icon');
   html+='</div>';
   if(device['Status']=='Off') html+='<span class="state">Niet op AMC</span>';
   else html+='<span class="state">Op AMC</span>';
   html+='</div>';
   return html;
i changed my code with some tips of Rob but still it doesn't work, above my original code which worked fine some time ago.
- FIBARO FGS223
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
Did you triple check the idx (536) ??
gielie
Post by gielie »
robgeerts wrote: Monday 14 August 2017 21:07 Did you triple check the idx (536) ??
Yes i did, if I use the code you suggested it kinda works, 1 thing that doesn't work is the custom icon I use, when I change the icon, like I did with the previous code, it suddenly doesn't work anymore. So I've been combining your new code with my own changes with no luck. I'm not much of coder, so it's just trial and error for me.
- FIBARO FGS223
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
Ok, show me what you've changed.
Although, you should not change to much to my example, because for example: '_SHOW_LASTUPDATE' doesnt work anymore and has been changed...
What did you try to change for the custom icon?
Thanks for your donation!
Appreciate it!
gielie
Post by gielie »
Ok after a lot of trial and error i started from scratch, and its working again. I changed the icon part so now i can simply change the on/off icon.
this is my final code
//thuis
function getBlock_63(device,idx,result){
   var html='';
   html+='</div>';
   html+='</div>';
   return html;
thank for the help.
- FIBARO FGS223
- Toon
- Kodi Media Server
dutchdevil83
Post by dutchdevil83 »
Have done the latest beta update and now my energy blocks give some "undefined" with total usage blocks for gas/energy.
Is there someway to fix this?
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
robgeerts
Post by robgeerts »
Could you send me (via PM) your config.js and the output of:
http://DOMOTICZ_IP:PORT/json.htm?type=devices&filter=all&used=true&order=Name
dutchdevil83
robgeerts wrote: Wednesday 16 August 2017 9:40 Could you send me (via PM) your config.js and the output of:
Send you a PM, can you help me out please?
It`s undefined with the total usages as stated in the config.JS (comments). So the _3 option gives undefined...
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
robgeerts
Post by robgeerts »
Should be fixed in latest beta!!
gijsje
Domoticz version: Stable
Post by gijsje »
i am very new to the world of Domoticz but i am getting the hang of it and i love it with Dashticz :D .
I run in to an issue with the show_lastupdate
it does not seen to work for me
blocks[23] = {} //TEMP HUISKAMER
blocks[23]['width'] = 3;
blocks[23]['switch'] = true;
blocks[23]['show_lastupdate'] = false;
the switch function is ok but not the lastupdate
Were else can i look for this?
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
robgeerts
Post by robgeerts »
Do you mean it still shows the last update
gijsje
Post by gijsje »
yes if i put in the blocks as shown above it still shows the update status
If this is done at the var config it is gone but gone for all,but with some things i want to have it and others i do not
config['last_update'] = 0;
robgeerts
Post by robgeerts »
Try :
blocks[23]['hide_lastupdate'] = true;
If config['last_update'] = 1, you have to use hide_lastupdate to hide it in a single block.
If config['last_update'] = 0, you have to use show_lastupdate to show it in a single block.
gijsje
Post by gijsje »
Thanks a lot it works
i am liking it more and more :)
Locked
