Page 9 of 51
Posted: Sunday 09 July 2017 12:46
by Onrust
I've been playing with Dasticz last last couple of days (as posted in the General Discussions topic) and had some issues with graphs not being displayed properly. Somehow I managed to fix that, but ran into a different issue with blocks being displayed within the graph after selecting the 'laatste uren' or 'afgelopen maand' view. See screenshots below.
This is the dash I have when opening the page:
This is what I get when selecting 'laatste uren' or 'afgelopen maand'
What have I been doing wrong here?
Other question: How can I make the white surrounding of the secpanel transparent?
My CONFIG.js:
var _LANGUAGE = 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ = 'http://username:[email protected]:xxxx';
var _DOMOTICZ_REFRESH = 10; //in seconds
var _DASHTICZ_REFRESH = 30; //in minutes
var _BACKGROUND_IMAGE = 'brushed.jpg'
var _THEME = 'default'; // default = dashticz default theme
//var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.x.x/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = 'xxxxxx';
var _WEATHER_CITY = 'EHGR';
var _WEATHER_CITYNAME = 'Weer Tilburg'; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY = 'NL';
var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = false; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _USE_BEAUFORT = true; //Bft instead of m/s
var _TRANSLATE_SPEED = false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE = false;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
var _HIDE_SECONDS_IN_STATIONCLOCK = false;
var _CLOCK_BOSS = 'RedBoss';
var _APIKEY_MAPS = 'xxxx';
var _MAPS_LATITUDE = '51.4946086';
var _MAPS_LONGITUDE = '5.2041633';
var _MAPS_ZOOMLEVEL = '10'
var _AUTO_SWIPEBACK_TO = 1; //when no activity, swipe back to main screen after x seconds
var _AUTO_SWIPEBACK_TIME = 900; //seconds
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['type'] = 'blocktitle'
blocks['blocktitle_1']['title'] = 'Verlichting'
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['type'] = 'blocktitle'
blocks['blocktitle_2']['title'] = 'Aanwezig'
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle'
blocks['blocktitle_3']['title'] = 'Deuren/ramen'
blocks[1] = {}
blocks[1]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[1]['title'] = 'Electra verbruik'; //if you want change the name of switch different then domoticz
blocks[1]['icon'] = 'fa-line-chart'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
//blocks[1]['image'] = 'bulb_off.png'; //if you want to show an image instead if icon, place image in img/ folder
blocks[1]['switch'] = true; //if you want to switch the title and data
blocks[1]['hide_data'] = false; //if you want to hide the data of this block
blocks[1]['show_lastupdate'] = false; //if you want to show the last update specific for this block
//blocks[1]['playsound'] = 'sounds/ping.mp3'; //play a sound when a device changes
//blocks[1]['protected'] = true; //protect switching manually in Dashticz
blocks[3] = {}
blocks[3]['width'] = 4;
blocks[3]['title'] = 'Temp buiten';
blocks[3]['switch'] = true;
blocks[3]['hide_data'] = false;
blocks[3]['show_lastupdate'] = false;
blocks[6] = {}
blocks[6]['width'] = 4;
blocks[6]['title'] = 'Temp woonkamer';
blocks[6]['switch'] = true;
blocks[6]['hide_data'] = false;
blocks[6]['show_lastupdate'] = false;
blocks[4] = {}
blocks[4]['width'] = 4;
blocks[4]['title'] = 'Temp verdieping 1';
blocks[4]['switch'] = true;
blocks[4]['hide_data'] = false;
blocks[4]['show_lastupdate'] = false;
blocks[68] = {}
blocks[68]['width'] = 6;
blocks[68]['title'] = 'Woonkamer';
blocks[68]['image'] = 'bulbyellow_on.png';
blocks[68]['switch'] = false;
blocks[68]['hide_data'] = false;
blocks[68]['show_lastupdate'] = false;
blocks[69] = {}
blocks[69]['width'] = 6;
blocks[69]['title'] = 'Voordeur';
blocks[69]['switch'] = false;
blocks[69]['hide_data'] = false;
blocks[69]['show_lastupdate'] = false;
blocks[70] = {}
blocks[70]['width'] = 6;
blocks[70]['title'] = 'Eetkamer';
blocks[70]['switch'] = false;
blocks[70]['hide_data'] = false;
blocks[70]['show_lastupdate'] = false;
blocks[108] = {}
blocks[108]['width'] = 4;
blocks[108]['title'] = 'Vriezer';
blocks[108]['icon'] = 'fa-line-chart';
blocks[108]['switch'] = true;
blocks[108]['hide_data'] = true;
blocks[108]['show_lastupdate'] = false;
blocks[111] = {}
blocks[111]['width'] = 4;
blocks[111]['title'] = 'Marc';
blocks[111]['icon'] = 'fa-male';
blocks[111]['switch'] = false;
blocks[111]['hide_data'] = false;
blocks[111]['show_lastupdate'] = false;
blocks[172] = {}
blocks[172]['width'] = 4;
blocks[172]['title'] = 'Astrid';
blocks[172]['icon'] = 'fa-female';
blocks[172]['switch'] = false;
blocks[172]['hide_data'] = false;
blocks[172]['show_lastupdate'] = false;
blocks[173] = {}
blocks[173]['width'] = 4;
blocks[173]['title'] = 'Thomas';
blocks[173]['icon'] = 'fa-male';
blocks[173]['switch'] = false;
blocks[173]['hide_data'] = false;
blocks[173]['show_lastupdate'] = false;
blocks[114] = {}
blocks[114]['width'] = 6;
blocks[114]['title'] = 'Slapen';
blocks[114]['switch'] = false;
blocks[114]['hide_data'] = false;
blocks[114]['show_lastupdate'] = false;
blocks[144] = {}
blocks[144]['width'] = 6;
blocks[144]['title'] = 'Raam voor';
blocks[144]['switch'] = false;
blocks[144]['hide_data'] = false;
blocks[144]['show_lastupdate'] = false;
blocks[148] = {}
blocks[148]['width'] = 6;
blocks[148]['title'] = 'Slaapkamer voor';
blocks[148]['switch'] = false;
blocks[148]['hide_data'] = false;
blocks[148]['show_lastupdate'] = false;
blocks[151] = {}
blocks[151]['width'] = 6;
blocks[151]['title'] = 'Voordeur';
blocks[151]['switch'] = false;
blocks[151]['hide_data'] = false;
blocks[151]['show_lastupdate'] = false;
blocks[155] = {}
blocks[155]['width'] = 6;
blocks[155]['title'] = 'Tuindeur';
blocks[155]['switch'] = false;
blocks[155]['hide_data'] = false;
blocks[155]['show_lastupdate'] = false;
blocks[174] = {}
blocks[174]['width'] = 12;
blocks[174]['title'] = 'Ventilatie';
blocks[174]['switch'] = true;
blocks[174]['hide_data'] = false;
blocks[174]['show_lastupdate'] = false;
var trashcan = {}
trashcan.afvalwijzer = { maxitems: 1, trashapp: 'mijnafvalwijzer', width:6, zipcode:'xxxx', housenumber:'xx' }
var frames = {}
frames.secpanel = {height:390,frameurl:"http://192.168.x.x:xxxx/secpanel/index.html",width:12}
var buttons = {}
buttons.buienradar = {width:5, isimage:true, refreshimage:3600000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256', url: 'http://www.weeronline.nl/Europa/Nederla ... rg/4058675'}
//buttons.floorplans = {width:6, isimage:false, refresh:10000, image:'', url:'http://192.168.x.x:xxxx/#/Floorplans'}
//buttons.nunl = {width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', url: 'http://www.nu.nl'}
buttons.webcam = {width:12, isimage:true, refresh:1000, image: 'https://xx/record/current.jpg', url: 'https://xx/record/current.jpg'}
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',68,70,69,114,'blocktitle_3',151,155,144,148,'blocktitle_2',111,172,173]
columns[1]['width'] = 3;
columns[2] = {}
columns[2]['blocks'] = ['graph_1','1_1','1_2','108_2','3_1','6_1','4_1',174]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [frames.secpanel,buttons.webcam]
columns[3]['width'] = 4;
columns[4] = {}
columns[4]['blocks'] = []
columns[4]['width'] = 6;
columns[5] = {}
columns[5]['blocks'] = ['trafficmap',buttons.buienradar,trashcan.afvalwijzer]
columns[5]['width'] = 6;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'brushed.jpg';
//screens[1]['background_morning'] = 'bg_morning.jpg';
//screens[1]['background_noon'] = 'bg_noon.jpg';
//screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[1]['background_night'] = 'bg_night.jpg';
screens[2] = {}
screens[2]['background'] = 'brushed.jpg';
screens[2]['columns'] = [4,5]
And custom.css:
CUSTOM CSS FILE
Hoeken afronden
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
padding-top:15px;
padding-bottom:15px;
border: 7px solid rgba(255,255,255,0)
background: rgba(0,0,0,0.2);
background-clip: padding-box;
border-radius: 15px;
Verkleinen iframes
iframe {
-moz-transform: scale(0.65, 0.65);
-webkit-transform: scale(0.65, 0.65);
-o-transform: scale(0.65, 0.65);
-ms-transform: scale(0.65, 0.65);
-moz-transform-origin: top left;
-webkit-transform-origin: top left;
-o-transform-origin: top left;
-ms-transform-origin: top left;
height:700px !important;
width:50vw !important;
overflow:hidden !important;
Hoogte grafieken
#graphoutput1 { height:282px;}
.trafficmap {
height: 100%;
.col-xs-1.block_trafficmap,
.col-xs-2.block_trafficmap
, .col-xs-3.block_trafficmap, .col-xs-4.block_trafficmap, .col-xs-5.block_trafficmap, .col-xs-6.block_trafficmap, .col-xs-7.block_trafficmap, .col-xs-8.block_trafficmap, .col-xs-9.block_trafficmap, .col-xs-10.block_trafficmap, .col-xs-11.block_trafficmap, .col-xs-12.block_trafficmap {
padding-left: 13px !important;
padding-right: 13px !important;
height:400px !important;
Posted: Sunday 09 July 2017 13:28
by EdwinK
I like your setup. I don't know how, but I don't have the 'uren' problem anymore. Do you hve the latest beta? Maybe that changed things
Posted: Sunday 09 July 2017 13:35
by Onrust
EdKo66 wrote:I like your setup.
Thnx! :)
EdKo66 wrote:I don't know how, but I don't have the 'uren' problem anymore. Do you hve the latest beta? Maybe that changed things
It's the latest beta I think, I installed it on July 6.
Posted: Sunday 09 July 2017 15:28
by pollefinario
Found this super forum post yesterday, already working on my own dash.
Does anybody got it working with Sonos yet? That would be great! Thanks
Posted: Sunday 09 July 2017 20:59
by dycati
If made my own version of dashticz in Angular because of the Drawbacks of Jquery
Its a work in progress, so NOT everything is supported at this moment.. 8-)
https://github.com/danielalmering/DomoDash
Posted: Sunday 09 July 2017 21:02
by EdwinK
Great :)
Posted: Sunday 09 July 2017 21:08
by Derik
@ Dycati.
Nice job...
Please can you ex plane the ANWB part??
Like this in my config...
Posted: Sunday 09 July 2017 21:16
by dycati
Sure just put the following url 'https://www.anwb.nl/feeds/gethf'' on the Settings/Traffic section and it should display the current traffic jams..
You can copy alot of settings from this screenshot https://raw.githubusercontent.com/danie ... ttings.png
Posted: Monday 10 July 2017 11:38
by jmvdijk
dycati wrote:If made my own version of dashticz in Angular because of the Drawbacks of Jquery
https://github.com/danielalmering/dashticz_v3
Can you explain how you add the Spotify module in your Dashboard?
tnx!
Posted: Monday 10 July 2017 11:56
by dycati
Sure first add the 'Spotify' to your blocks then just go to https://developer.spotify.com/my-applic ... plications
And add a application(domoticz) then you will get A Client ID just copy that in your settings.
Then add the correct redirect url like so ''http://192.168.192.22:8887//#" and fill in your username to get the playlist you got at spotify..
If you got any question just pm me!!
PS Just added Google Calendar to beta version...
Posted: Monday 10 July 2017 12:03
by robgeerts
Always great to see when other developers like your work and want to create a new and better version!
Although, I dont like you are using the name 'Dashticz v3'... People might get confused, basically my Dashticz and yours are 2 different dashboards... I'm still working on v2 wich will have some new features coming up.
Posted: Monday 10 July 2017 12:42
by dycati
Sure it will give it its own name, no problem
Posted: Monday 10 July 2017 19:18
by remb0
WOW spotify and a settings page.
Great work. I hope rob will add also the settingspage.
this it the advantage of opensource I think! :)
Posted: Monday 10 July 2017 19:21
by Derik
remb0 wrote:WOW spotify and a settings page.
The settingspage is very nice feature,,, hope rob will...
Or perhaps work together guys..
One great bash better then 2 wit different features..
No hard feelings just a great dash :-)
Posted: Monday 10 July 2017 19:38
by robgeerts
Well, indeed, I was already working on a spotify-widget, settings page and draggable blocks (instead of arranging via config.js).
Posted: Monday 10 July 2017 19:39
by Trigun
Cant wait Rob!! :)
Posted: Monday 10 July 2017 19:43
by Derik
mmmm
Make love guys.....:-)
Perhaps there wil be a new born :-)
Posted: Monday 10 July 2017 21:07
by Onrust
robgeerts wrote:Well, indeed, I was already working on a spotify-widget, settings page and draggable blocks (instead of arranging via config.js).
Sounds great!
Posted: Tuesday 11 July 2017 21:12
by Onrust
@robgeerts, any chance of looking into the issue I have with graphs, or is this going to be fixed in one of the upcoming betas anyway? :)
Posted: Tuesday 11 July 2017 21:16
by robgeerts
The order of my todo-list (except for the small bugfixes I do in between:
1.) RGB-lamp support (just bought one to play with)
2.) Graph fixes
3.) Etc. etc. ;)
