Dashticz - Show your dashboard and how-to's!
Onrust
Domoticz version: 4.10717
Post by Onrust »
I've been playing with Dasticz last last couple of days (as posted in the General Discussions topic) and had some issues with graphs not being displayed properly. Somehow I managed to fix that, but ran into a different issue with blocks being displayed within the graph after selecting the 'laatste uren' or 'afgelopen maand' view. See screenshots below.
This is the dash I have when opening the page:
This is what I get when selecting 'laatste uren' or 'afgelopen maand'
What have I been doing wrong here?
Other question: How can I make the white surrounding of the secpanel transparent?
My CONFIG.js:
var _LANGUAGE = 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ = 'http://username:[email protected]:xxxx';
var _DOMOTICZ_REFRESH = 10; //in seconds
var _DASHTICZ_REFRESH = 30; //in minutes
var _BACKGROUND_IMAGE = 'brushed.jpg'
var _THEME = 'default'; // default = dashticz default theme
//var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.x.x/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = 'xxxxxx';
var _WEATHER_CITY = 'EHGR';
var _WEATHER_CITYNAME = 'Weer Tilburg'; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY = 'NL';
var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = false; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _USE_BEAUFORT = true; //Bft instead of m/s
var _TRANSLATE_SPEED = false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE = false;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
var _HIDE_SECONDS_IN_STATIONCLOCK = false;
var _CLOCK_BOSS = 'RedBoss';
var _APIKEY_MAPS = 'xxxx';
var _MAPS_LATITUDE = '51.4946086';
var _MAPS_LONGITUDE = '5.2041633';
var _MAPS_ZOOMLEVEL = '10'
var _AUTO_SWIPEBACK_TO = 1; //when no activity, swipe back to main screen after x seconds
var _AUTO_SWIPEBACK_TIME = 900; //seconds
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['type'] = 'blocktitle'
blocks['blocktitle_1']['title'] = 'Verlichting'
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['type'] = 'blocktitle'
blocks['blocktitle_2']['title'] = 'Aanwezig'
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle'
blocks['blocktitle_3']['title'] = 'Deuren/ramen'
blocks[1] = {}
blocks[1]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[1]['title'] = 'Electra verbruik'; //if you want change the name of switch different then domoticz
blocks[1]['icon'] = 'fa-line-chart'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
//blocks[1]['image'] = 'bulb_off.png'; //if you want to show an image instead if icon, place image in img/ folder
blocks[1]['switch'] = true; //if you want to switch the title and data
blocks[1]['hide_data'] = false; //if you want to hide the data of this block
blocks[1]['show_lastupdate'] = false; //if you want to show the last update specific for this block
//blocks[1]['playsound'] = 'sounds/ping.mp3'; //play a sound when a device changes
//blocks[1]['protected'] = true; //protect switching manually in Dashticz
blocks[3] = {}
blocks[3]['width'] = 4;
blocks[3]['title'] = 'Temp buiten';
blocks[3]['switch'] = true;
blocks[3]['hide_data'] = false;
blocks[3]['show_lastupdate'] = false;
blocks[6] = {}
blocks[6]['width'] = 4;
blocks[6]['title'] = 'Temp woonkamer';
blocks[6]['switch'] = true;
blocks[6]['hide_data'] = false;
blocks[6]['show_lastupdate'] = false;
blocks[4] = {}
blocks[4]['width'] = 4;
blocks[4]['title'] = 'Temp verdieping 1';
blocks[4]['switch'] = true;
blocks[4]['hide_data'] = false;
blocks[4]['show_lastupdate'] = false;
blocks[68] = {}
blocks[68]['width'] = 6;
blocks[68]['title'] = 'Woonkamer';
blocks[68]['image'] = 'bulbyellow_on.png';
blocks[68]['switch'] = false;
blocks[68]['hide_data'] = false;
blocks[68]['show_lastupdate'] = false;
blocks[69] = {}
blocks[69]['width'] = 6;
blocks[69]['title'] = 'Voordeur';
blocks[69]['switch'] = false;
blocks[69]['hide_data'] = false;
blocks[69]['show_lastupdate'] = false;
blocks[70] = {}
blocks[70]['width'] = 6;
blocks[70]['title'] = 'Eetkamer';
blocks[70]['switch'] = false;
blocks[70]['hide_data'] = false;
blocks[70]['show_lastupdate'] = false;
blocks[108] = {}
blocks[108]['width'] = 4;
blocks[108]['title'] = 'Vriezer';
blocks[108]['icon'] = 'fa-line-chart';
blocks[108]['switch'] = true;
blocks[108]['hide_data'] = true;
blocks[108]['show_lastupdate'] = false;
blocks[111] = {}
blocks[111]['width'] = 4;
blocks[111]['title'] = 'Marc';
blocks[111]['icon'] = 'fa-male';
blocks[111]['switch'] = false;
blocks[111]['hide_data'] = false;
blocks[111]['show_lastupdate'] = false;
blocks[172] = {}
blocks[172]['width'] = 4;
blocks[172]['title'] = 'Astrid';
blocks[172]['icon'] = 'fa-female';
blocks[172]['switch'] = false;
blocks[172]['hide_data'] = false;
blocks[172]['show_lastupdate'] = false;
blocks[173] = {}
blocks[173]['width'] = 4;
blocks[173]['title'] = 'Thomas';
blocks[173]['icon'] = 'fa-male';
blocks[173]['switch'] = false;
blocks[173]['hide_data'] = false;
blocks[173]['show_lastupdate'] = false;
blocks[114] = {}
blocks[114]['width'] = 6;
blocks[114]['title'] = 'Slapen';
blocks[114]['switch'] = false;
blocks[114]['hide_data'] = false;
blocks[114]['show_lastupdate'] = false;
blocks[144] = {}
blocks[144]['width'] = 6;
blocks[144]['title'] = 'Raam voor';
blocks[144]['switch'] = false;
blocks[144]['hide_data'] = false;
blocks[144]['show_lastupdate'] = false;
blocks[148] = {}
blocks[148]['width'] = 6;
blocks[148]['title'] = 'Slaapkamer voor';
blocks[148]['switch'] = false;
blocks[148]['hide_data'] = false;
blocks[148]['show_lastupdate'] = false;
blocks[151] = {}
blocks[151]['width'] = 6;
blocks[151]['title'] = 'Voordeur';
blocks[151]['switch'] = false;
blocks[151]['hide_data'] = false;
blocks[151]['show_lastupdate'] = false;
blocks[155] = {}
blocks[155]['width'] = 6;
blocks[155]['title'] = 'Tuindeur';
blocks[155]['switch'] = false;
blocks[155]['hide_data'] = false;
blocks[155]['show_lastupdate'] = false;
blocks[174] = {}
blocks[174]['width'] = 12;
blocks[174]['title'] = 'Ventilatie';
blocks[174]['switch'] = true;
blocks[174]['hide_data'] = false;
blocks[174]['show_lastupdate'] = false;
var trashcan = {}
trashcan.afvalwijzer = { maxitems: 1, trashapp: 'mijnafvalwijzer', width:6, zipcode:'xxxx', housenumber:'xx' }
var frames = {}
frames.secpanel = {height:390,frameurl:"http://192.168.x.x:xxxx/secpanel/index.html",width:12}
var buttons = {}
buttons.buienradar = {width:5, isimage:true, refreshimage:3600000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256', url: 'http://www.weeronline.nl/Europa/Nederla ... rg/4058675'}
//buttons.floorplans = {width:6, isimage:false, refresh:10000, image:'', url:'http://192.168.x.x:xxxx/#/Floorplans'}
//buttons.nunl = {width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', url: 'http://www.nu.nl'}
buttons.webcam = {width:12, isimage:true, refresh:1000, image: 'https://xx/record/current.jpg', url: 'https://xx/record/current.jpg'}
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',68,70,69,114,'blocktitle_3',151,155,144,148,'blocktitle_2',111,172,173]
columns[1]['width'] = 3;
columns[2] = {}
columns[2]['blocks'] = ['graph_1','1_1','1_2','108_2','3_1','6_1','4_1',174]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = [frames.secpanel,buttons.webcam]
columns[3]['width'] = 4;
columns[4] = {}
columns[4]['blocks'] = []
columns[4]['width'] = 6;
columns[5] = {}
columns[5]['blocks'] = ['trafficmap',buttons.buienradar,trashcan.afvalwijzer]
columns[5]['width'] = 6;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'brushed.jpg';
//screens[1]['background_morning'] = 'bg_morning.jpg';
//screens[1]['background_noon'] = 'bg_noon.jpg';
//screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[1]['background_night'] = 'bg_night.jpg';
screens[2] = {}
screens[2]['background'] = 'brushed.jpg';
screens[2]['columns'] = [4,5]
And custom.css:
CUSTOM CSS FILE
Hoeken afronden
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
padding-top:15px;
padding-bottom:15px;
border: 7px solid rgba(255,255,255,0)
background: rgba(0,0,0,0.2);
background-clip: padding-box;
border-radius: 15px;
Verkleinen iframes
iframe {
-moz-transform: scale(0.65, 0.65);
-webkit-transform: scale(0.65, 0.65);
-o-transform: scale(0.65, 0.65);
-ms-transform: scale(0.65, 0.65);
-moz-transform-origin: top left;
-webkit-transform-origin: top left;
-o-transform-origin: top left;
-ms-transform-origin: top left;
height:700px !important;
width:50vw !important;
overflow:hidden !important;
Hoogte grafieken
#graphoutput1 { height:282px;}
.trafficmap {
height: 100%;
.col-xs-1.block_trafficmap,
.col-xs-2.block_trafficmap
, .col-xs-3.block_trafficmap, .col-xs-4.block_trafficmap, .col-xs-5.block_trafficmap, .col-xs-6.block_trafficmap, .col-xs-7.block_trafficmap, .col-xs-8.block_trafficmap, .col-xs-9.block_trafficmap, .col-xs-10.block_trafficmap, .col-xs-11.block_trafficmap, .col-xs-12.block_trafficmap {
padding-left: 13px !important;
padding-right: 13px !important;
height:400px !important;
EdwinK
Post by EdwinK »
I like your setup. I don't know how, but I don't have the 'uren' problem anymore. Do you hve the latest beta? Maybe that changed things
Onrust
Post by Onrust »
EdKo66 wrote:I like your setup.
Thnx! :)
EdKo66 wrote:I don't know how, but I don't have the 'uren' problem anymore. Do you hve the latest beta? Maybe that changed things
It's the latest beta I think, I installed it on July 6.
pollefinario
Post by pollefinario »
Found this super forum post yesterday, already working on my own dash.
Does anybody got it working with Sonos yet? That would be great! Thanks
dycati
Post by dycati »
If made my own version of dashticz in Angular because of the Drawbacks of Jquery
Its a work in progress, so NOT everything is supported at this moment.. 8-)
https://github.com/danielalmering/DomoDash
EdwinK
Post by EdwinK »
Great :)
Derik
Post by Derik »
@ Dycati.
Nice job...
Please can you ex plane the ANWB part??
Like this in my config...
dycati
Post by dycati »
Sure just put the following url 'https://www.anwb.nl/feeds/gethf'' on the Settings/Traffic section and it should display the current traffic jams..
You can copy alot of settings from this screenshot https://raw.githubusercontent.com/danie ... ttings.png
jmvdijk
Post by jmvdijk »
dycati wrote:If made my own version of dashticz in Angular because of the Drawbacks of Jquery
https://github.com/danielalmering/dashticz_v3
Can you explain how you add the Spotify module in your Dashboard?
tnx!
dycati
Post by dycati »
Sure first add the 'Spotify' to your blocks then just go to https://developer.spotify.com/my-applic ... plications
And add a application(domoticz) then you will get A Client ID just copy that in your settings.
Then add the correct redirect url like so ''http://192.168.192.22:8887//#" and fill in your username to get the playlist you got at spotify..
If you got any question just pm me!!
PS Just added Google Calendar to beta version...
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Always great to see when other developers like your work and want to create a new and better version!
Although, I dont like you are using the name 'Dashticz v3'... People might get confused, basically my Dashticz and yours are 2 different dashboards... I'm still working on v2 wich will have some new features coming up.
dycati
Post by dycati »
Sure it will give it its own name, no problem
remb0
Post by remb0 »
WOW spotify and a settings page.
Great work. I hope rob will add also the settingspage.
this it the advantage of opensource I think! :)
Derik
Post by Derik »
remb0 wrote:WOW spotify and a settings page.
The settingspage is very nice feature,,, hope rob will...
Or perhaps work together guys..
One great bash better then 2 wit different features..
No hard feelings just a great dash :-)
robgeerts
Post by robgeerts »
Well, indeed, I was already working on a spotify-widget, settings page and draggable blocks (instead of arranging via config.js).
Trigun
Post by Trigun »
Cant wait Rob!! :)
Derik
Post by Derik »
mmmm
Make love guys.....:-)
Perhaps there wil be a new born :-)
Onrust
Post by Onrust »
robgeerts wrote:Well, indeed, I was already working on a spotify-widget, settings page and draggable blocks (instead of arranging via config.js).
Sounds great!
Onrust
Post by Onrust »
@robgeerts, any chance of looking into the issue I have with graphs, or is this going to be fixed in one of the upcoming betas anyway? :)
robgeerts
Post by robgeerts »
The order of my todo-list (except for the small bugfixes I do in between:
1.) RGB-lamp support (just bought one to play with)
2.) Graph fixes
3.) Etc. etc. ;)
